Introduction: DIY Tesseract's Cube
The Tesseract (also called the Cosmic Cube) is a crystalline cube-shaped containment vessel for an Infinity Stone possessing unlimited energy.
The Tesseract is one of the most powerful artifacts in the universe. It holds great power that is almost unlimited. The Tesseract can open rifts through space. The Tesseract can also show visions of the future, which may or may not come true. The people who have seen this power are the Red Skull, Eric Selvig, and Hawkeye, when the latter two were under the control of the Chitauri scepter.
It cannot be held by mortal hands. Anyone who does so will be disintegrated, their remains sent to another world, as evidenced with what happened to Red Skull.
The day I saw " Avengers : Initiative " I became fan of Tesseract's Cube. So I decided to make my own Tesseract's cube .
Below is one of Simplest and Cheapest method to make one .
Step 1: Supplies
The following things are required :-
- Cardboard
- A Transparent Plastic Sheet ( I got it from a plastic folder )
- Colourful Paper
- A Blue LED Bulb
- Wires
- A Pair of Scissors
- Battery
- A Small Switch
- Pen
- Scale
- Bubble Wrap (after using a lot of materials I found that bubble wrap gives the best effect)
Step 2: Cutting
Cut the Cardboard in the form of a Rectangle with four equal parts.
Step 3: Solder the LED
Solder the wire and the LED.
Step 4: Making the Centre Part
Crush the Bubble Wrap into a ball and put the LED in the centre of it and tape it .
Step 5: Making the Base
Fold the Cardboard to make the Base and then Stick the Edges.
Step 6: Making the Cube
Draw lines on the Plastic Sheet in the manner as shown above.
Step 7: Cut and Stick
Cut and stick the edges of the Sheet to form an open Cube.
Step 8: Assemble
Now insert the open Cube in the Cardboard and then put the bubble wrap (with LED inside it) inside the cube.
Step 9: Finalising
Glue the whole thing together then complete the circuit by attaching a Battery and a Switch and cover the cardboard with paper.
Step 10: Turn It on
Turn it on . In day light it looks normal but the real magic begins when lights are turned off !!
Heroes and Villains Contest
Halloween Props Contest 2016
Trash to Treasure Challenge
Summer Fun Contest 2016
