Step 4The Final product and files
Q1-Q3 BC548
LED1-LED3 5mm High Intensity Blue LED
LED4-LED12 5mm High Intensity Red LED
LED13-LED18 5mm High Intensity Orange LED
LED19-LED27 5mm High Intensity Green LED
R1-R4 100k 1/4w Resistor
Q4 32.768 kHz Crystal
C1 4.7uF 10V Electrolytic Capacitor
C2,C3 10pF Ceramic Capacitor
IC1 ATMEGA16 AVR Microcontroller
IC2,IC3 TD62304 Darlington Transistor Arrays (these could be replaced with standard transistors)
S1-S3 Momentary Push Buttons
Enjoy! and vote for me!
tixclock.zip70 KB| « Previous Step | Download PDFView All Steps | Next Step » |
JP2 is the programming connector
this is the first time i see this kind of this clock
was it 12:34 then 12:35?
did i read it right?
i will try to make one like it
Very nice clock indeed.
I noticed that you only supply the .bas file in the zip.
To get the HEX file to program into the AVR, you will need the BASCOM (?) compiler to produce the HEX file.
Could you also supply the HEX file for the AVR?
As for the square grids, you prob could use those square led matrixes, sold on eBay or @ Sparkfun.
Thanks,
Stephen
Where do you bought the square reflector?On internet I can't find it :(
As for the cost, its hard to say, some of bits like the reflector I had lying around, along with the transistors and IC's.
You can buy LED's quite cheaply on the likes of E-Bay etc. So I can't really put a dollar figure on it.
Excuse me can you tell me how do you programme the clock, via usb?
