DIY external DVD-Drive
The EeePC and I'm sure some other netbooks come with a recovery DVD - problem is that netbooks (understandably) don't have an internal DVD drive, so being me I didn't want to go out and buy an external one, because I simply wouldn't have any use for it . instead, I started looking around for stuff I had laying round the house...
I happen to be using a case and drive with IDE connectors, but SATA should also work
Step 1What you need
- Old unused external HDD/HDD enclosure (or a used one if you want a temporary external Drive)
- Unused DVD drive
- Screwdriver
- Patience
Notice that the connectors inside the enclosure must match the connectors on the DVD Drive for it to work. I happened to have an old IDE drive and an old external HDD which is also IDE connected. I don't know about the modern ones, but i guess it would also work with SATA.
16 comments
Nov 2, 2011. 2:33 AMMRedu says:
Really good guide and has many uses, like installing windows 7 or an OS of your choice to a cheap netbook.
Dec 20, 2010. 9:32 AMpatrickvaz says:
HI,
After this setup, can i hook it on to a TV via usb and does this drive be seen on a TV, like maybe save some movies on the hard drive and play the same to the tv??
Mar 25, 2010. 6:14 AMeddy180 says:
I tried this with 3 different SATA drives, 1 (dvd writer) didnt work. The other two did work!
Oct 28, 2010. 11:18 PMlopipops says:
I think you need to put the DVD's jumper into master
Jan 30, 2010. 3:08 PMtwitsl says:
I looked on ebay and found a ide to usb device. you can use that is you have a power supply.
Dec 4, 2009. 11:51 AMopanocat5 says:
 Nice man!
I was about to pay about £40 for one of those! Now i can get another thing to install on my little netbook as well
Jul 16, 2009. 12:56 AMDJNASHA says:
NICE P.S U CAN GET VANTEC ADAPTER 4 17DOLLERS AT FRY'S
Jul 11, 2009. 6:58 AMgonlgn says:
does it really work same as external?
Jul 7, 2009. 5:05 PMmikedoth says:
I'd put the word "IDE" in the intro to the Instructable.
Jul 8, 2009. 10:37 AMmikedoth says:
Only if you start with a SATA enclosure. But that's my two cents. Good instructable overall, I think i'll try making one.
Jul 7, 2009. 3:54 PMguyfrom7up says:
nice, but typo: on the first page it should say internal, not external, but very useful instructable. But for those who are looking for a cheap solution, while this is certainly cheap, you can also get an external drive ffrom dealextreme for 40 bucks, just letting people know. This is a good alternative, and the best alternative to an expensive 100 dollar external drive.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:wh173y
