Introduction: Daddy Daughter D6 Ring
She gets twigs and wildflowers caught in her hair and she leaps into my arms just like she did back when she was littler and I was stronger.
She is also into dragons, big time. She loves MTG cards, though neither of us really knows how to play. I figure D&D will be the next phase she will go through. So why not be prepared with a 6-sided die... ring?
Step 1: Life Is Not Black and White: D6
There are so many trivial decisions to be made in the course of a day. When life is too subtle for coin flips, roll a D6!
You will need:
A brass nut larger diameter than your finger (but not much larger) ($1.55)
A socket that will fit it
A drill and bits
A round file or round grinding stone
A center punch ($5)
Sandpapers
Total cost for me was $7.34
First you should freehand the dots onto the sides with a Sharpie where you want the number divots to be. I decided that I wanted the faces to be more gem-like and not overtly dice-like so I planned my own divot layout.
The sides should have a specific order so that no consecutive numbers are adjacent but the opposite sides should add up to 7. From left to right as you go around the ring you should see: 1, 5, 3, 6, 2, 4. This took us an embarrassingly long time to figure out.
Second use a center punch to put divots into the marks. This is an important step because these divots will keep the drill bit from skipping over the faces, marring them.
If you don't have a center punch then I hope you'll buy one. They are indispensable and only cost about $5. You could keep one in your glove box in case of emergency-- nothing would break a car window better than a spring-loaded center punch.
Step 2: One Ring to Roll Them All
Next use a small-ish drill bit to round out the divots. I used my drill press so that I could make the depth of the holes perfectly uniform. Viv thought the shiny little holes were so beautiful!
All that remains to do is to bore out the inside. I recommend using a drill bit the size of the finger you're aiming to fit. If you don't have that you can slowly grind the threads away with a round grinding stone drill bit. This can be slow going and heats up your ring something fierce so try something that cuts like a twist bit or a coarse round file rather than something that grinds.
Give it a polish.
No one's going to carry a die around with them but that doesn't mean there isn't a use for one in just about every situation. Who gets the last cookie? Should I buy that girl a drink? Where should we stop to eat?
And for a few bucks and a little work you'll be able to sport a ring like Claramecium's D6.
Second Prize in the
Jewelry Contest
Toy Contest
Epilog Challenge V
