3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dell Inspiron 600M reborn as a Homemade Tablet pc
  • last photo ←
Goal:
Convert a Dell Inspiron 600m laptop to a touch screen tablet.
Specs:
Windows XP Tablet PC Edition 2005 SP3
1.8Ghz Pentium 4m
14" LCD touch screen
32MB ATI Radeon 9000
2GB RAM DDR PC2700
64GB SSD 2.5" ide interface
internal USB hub
Bluetooth reciever
GPS Reciever
2 Batteries  Primary Dell Battery and secondary CD-ROM bay battery (7+ hours runtime)
Results:
Boots in 15 Sec., Firefox launches in under 1 sec.
Changed:
WIFI antennas and locations for better reception and relocate power button.
Removed:
Palm rest, Keyboard, trackpad and buttons, modem, PCMCIA Slot Cage and HDD Cage.
Parts:
Most of the parts were purchased via eBay.com
Dell Inspiron 600m in decent condition. (had on hand)                         eBay.com -$50.00-$100.00
Wireless mouse (had no hand)        eBay.com -$10.00-$50.00
Globalsat USG-ND100 USB Dongle GPS Receiver for Laptops          $40.95
Kingspec 2.5'' IDE PATA MLC 64GB SSD PC Disk Hi-speed                $144.05
SECONDARY MEDIA BAY BATTERY INSPIRON 500m 600m              $34.95
14.3" inch USB Panel Kit Set Add Touch Screen Function                     $50.99
Vantec UGT-MH304 USB 2.0 4 Port Mini HUB Mini Power                    $12.99
2GB DDR PC2700 Unbuffered NON-ECC DDR333 Crucial.com        $84.00
Extra plastic
Wire (USB cable works great from an old mouse)
Heat-sinks
Docking Station:
Old 20" LCD monitor stand (had on hand)
Dell Docking Station Port Replicator (had on hand)
Tools:
Solder iron & solder
Good set of screw drivers
Razor blade –sharp knife
Dremel tool –good assortment of bits
Hot glue gun –lots of glue sticks. (Isopropyl alcohol releases the glue)
pliers, snips, forceps, tweezers and wire strippers are all helpful
J-B KWIK Weld
Update 12/20/11
This computer was quickly become my web-surf ‘n machine. I have 24Mbps DSL in combination with this Solid State tablet web pages render instantly and videos are smooth. I've only drained the battery a few times, and that was on purpose.  And a cool interface, it’s like having a 8.5” X 11” trackpad. I do use the mouse sometimes but for the most part just the touch screen. Win XP SP3 includes a bunch of new games including Internet Backgammon. Which is one of my favorites, the touch screen is perfect for that game.
The computer barely gets warm after watching TED Talks videos for an hour. I ran a burn-in test using BurnInTest from PassMark software and the computer passed every test.  Also I have added heat-sinks to the RAM both DIMMs both sides. This is a 6 year old computer with pretty impressive performance in it's new configuration.
I do have a fair investment in both time and materials in this project. I think it was worth it. I’ll use the computer and the knowledge I gained from building it for years. I’ve been thinking about my next tablet maybe a Mac?
Update: 12/05/11
Added a few more heat-sinks over the chipset and video processor.
Update: 12/04/11
A few more mods inspired by a USB hub failure. The GPS dongle was drawing too much power and killed the hub. So I found another hub (powered). Had to do some cutting and relocating of 1 USB port. I can pull 5 volts dc off the PCMCIA slot to power the USB hub. That’s next… I have also removed the SSD housing and added the 2 green heat-sinks from an old video card. And added the black heat-sink for the processor.
My name is Brian --> briPad
A few OS tweaks for better SSD performance that should be noted:
1.          Disable winXP prefetcher
              http://support.microsoft.com/kb/307498
              search for Disable_Prefetcher.reg
2.          Disable the 8.3 Name Creation on NTFS Partitions:
              fsutil.exe behavior set disable8dot3 1
3.          Disable timestamp for last access to a file to speed up Windows
              fsutil behavior set disablelastaccess 1
4.           Turn off Indexing on All Drives
               fsutil usn deletejournal /d c:
5.           Turn off Virtual Memory
               Set to No Paging file
6.           Disable Write Cache and Power Protected:
               http://support.microsoft.com/kb/Q811392
               c:\dskcache +p c:
7.           Verify write caching is disabled:
               Device Manager --> Disk drives --> Policies un-check Enable write caching on the disk
8.           Disable Services:
              Error Reporting Service
              Help and Support
              Remote Registery
9.           Disable System Restore:
              Set to: Turn off System Restore
10.        Disable Windows Hibernation
             Power Option Properties -Un-check Enable hibernation
11.        XPLite to clean up Windows update caches:
              http://www.litepc.com/xplite.html
WOW. Nearly the fastest computer I’ve used. And I have quite a few fast computers.
46 comments
1-40 of 46next »
May 22, 2012. 8:46 PMwedged_mind says:
Hey there, I'd just like to say that this is an awesome Instructable and just need to ask a small question.
Is the touch screen kit you're using is multi-touch capable? Been toying around with the idea of my own laptop to tablet conversion project and I came across this little program, BlueStacks (bluestacks.com) that allowed you to run Android apps natively on a PC. While others who have attempted this sort of project all say that you're not really losing much by not having multi-touch on a laptop-tablet running on Windows 7, I think it becomes somewhat necessary now that I plan to run Android apps on it.
Could really use an answer on this as I've been looking for a touch screen kit that's multi-touch and capacitive for quite some time now but to no avail.
May 22, 2012. 11:39 PMwedged_mind says:
Shiny! Multi-touch!
Another question though, I read through the comment and you mentioned it responding to a pencil eraser and I'm wondering now if it's really capacitive. Don't they require a special capacitive stylus? I would have been willing to settle for resistive multi-touch but the idea that the touch screen you're using might actually be capacitive is really exciting. Are you certain it's capacitive?
I had the same idea as well! But I was unsure as to whether I'm actually capable of integrating the sensors. The guy running the carbon fiber tablet was able to fit in an accelerometer but doesn't provide any real guide as to how to integrate it into the setup, unfortunately.
Thanks! I'm really excited to get working on this once the details have been sorted out and the parts are ordered and landed!
Apr 30, 2012. 9:56 AMjlawrie says:
I found 14.1" Capacitive touch screen kit here:
http://kingtouch.en.made-in-china.com/product-group/LMVmWwobnARS/-HOT-Capacitive-Touch-Screen-catalog-1.html
It is however a Chinese supplier but after exhausting all of the USA Suppliers I was refereed to them by a company called North American Semiconductor.
I will be posting my Tablet build after i get all of the other components collected. Am having a hard time finding a way to Encase it all after.
Like how this guy did his, but i just don't know...
http://carbontablet.blogspot.ca/
Apr 26, 2012. 4:52 PMherendinger13 says:
I have an old 600m that I was considering modding as you have, but my screen is broken. I was looking to see if maybe I couldn't just replace it directly with a different manufacturer's screen instead of having to buy the new 600m screen and a touch kit. I found a Gateway m275 screen on ebay that is the same size so I looked up the specs. I'm not sure if you would know offhand whether crossing brands like this is possible, but I found out that almost all of the specs of the two screens were either identical or extremely similar. The signal interface was a different pin configuration, instead of the 600m's LVDS-30P1C6B-030C, the Gateway's was LVDS-30P1C6B-030B. For the life of me I don't know the difference, or if there is any substantial difference. No idea if you could help me out on this one but I thought I would ask, thanks for reading!
Apr 26, 2012. 9:13 PMherendinger13 says:
Okay thanks, I've decided to go with the Dell LCD due to possible inverter compatibility issues. The ones I saw were about 30 bucks and yeah I'm def prepared to spend some money on this, still cheaper than buying a brand new tablet. I'll keep you posted on my progress, (although I prob won't be starting this for a couple weeks hooray college finals). Thanks for the response and the advice, hopefully I'll have some luck with this. If you're willing to part with one of your panels maybe we can discuss that in the future as well
Mar 1, 2012. 1:45 AMpulkit_singal says:
Can you please tell how can I change the laptop screen to a new screen (HD LED)? From where I can easily get it ?
Dec 28, 2011. 7:56 PMaccount3r2 says:
That laptop looks almost exactly like the laptop I am using, a Dell Latitude D600! Same shell, but the lights are a bit different. Nice 'ible, by the way, I was thinking about doing this on my old(er) laptop, but that laptop is very old and heavy. It lasts about 30 min. max on battery and is ~2.5 in. thick at about 10 lbs. I don't think that would make a very good tablet... http://support.dell.com/support/edocs/systems/psyd/
Feb 8, 2012. 10:29 PMGavinReynolds says:
I for one actually dont care about thinner. Thinner = smaller fan = noisier cooling.
And I want better screens in tablet pc, with good black values and contrast, matte displays, good res...there are virtually NO laptop displays for sale right now that arent glosse, and dont have the awful color shift and awful black levels (black = grey? Also, make laptops feel less plastic...and there are alternatives to aluminium, if you're eyeing that macbook.
Dec 18, 2011. 11:19 PMsk8addict says:
Question for you, I'm thinking about doing this as an alternative way to hold my e-textbooks and take notes during my classes at my university, do you use a stylus with it? or can you recommend any that could work well with this setup?
Dec 19, 2011. 7:11 PMsk8addict says:
alright and does the xp tablet edition come with any "tablet oriented" programs like can you write out notes, say to use as a replacement for a notebook for myself?
Dec 19, 2011. 9:02 PMsk8addict says:
alright thanks for the info, ill let you know if i start on it any time soon'
Dec 15, 2011. 8:28 PMzeosrule says:
Im currently doing this and I have a few questons
1. Where and how did you relocate the power button
2. Is the touchscreen under the screen bezel
3. How did you fill the side gaps
Im doing this on my old D610
Dec 16, 2011. 6:22 AMzeosrule says:
Thank you. Also was it easy to flip the latch around backwards?
Dec 16, 2011. 6:50 PMzeosrule says:
I have a new problem I need to deal with, how did you add the internal USB port?
Dec 16, 2011. 9:42 PMzeosrule says:
I was thinking more like the internal bluetooth cable do you think that would work
Dec 17, 2011. 8:16 AMzeosrule says:
What I meant was the bluetooth connections fdirst four pins are USB. Do you think those 4 pins would work. I dont have the bluetooth modual installed.
Dec 17, 2011. 11:09 AMzeosrule says:
K thanks for all your help
Nov 28, 2011. 1:02 PMTrevolution says:
Just curious, what internal USB hub did you use? I have a dell latitude D610 sitting around I thought about converting into one. Maybe make a custom case since I work in a metal fab shop with lasers. Also, how did you connect the USB hub to the motherboard? Thank you very much for your time, awesome job.
Nov 26, 2011. 12:47 PMdmcdonell says:
I agree with ho'connell, post instructions! Still can't see, or understand, how you got the base from the rest of the laptop, at least from the pics.
Nov 26, 2011. 2:12 PMdmcdonell says:
ah, so the digitizer (the black base) is part of the kit? I do see how you flipped the screen!
Nov 27, 2011. 7:36 AMdmcdonell says:
Pardon me if I sound clueless telluridetech, I have taken apart laptops in the past. I guess what I'm asking is: is the digitizer part of the kit, or the laptop? I'm referring to the part that is the base in pics 6 and 7, I can't seem to visualize it on the original laptop configuration.
Nov 28, 2011. 9:18 AMdmcdonell says:
ah, ok, it was the docking station that was throwing me off, that is impressive too!
Nov 26, 2011. 7:08 AMdmcdonell says:
this is awesome, gotta try it, can it work with other models/brands?
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:telluridetech
