Detouchable Converter Board for ESP-07 and 12 With Pogo Pins
Published
Introduction: Detouchable Converter Board for ESP-07 and 12 With Pogo Pins
I made a Detouchable Converter Board.
For example, a converter for 2mm pitched SMD ESP-07 or ESP-12.
It can mount on 2.54mm pitched breadboard as a 16 pins DIP.
http://neo-sahara.com/wp/detouchable_esp8266
Step 1:
Double sided PCB.
Step 2:
These are the Pogo Pins.
They will be solderd on the PCB.
Step 3:
Pogo Pins and pin headers are soldered.
The Detouchable Converter Board set on a breadboard need only the space as 16pins DIP.
Step 4:
ESP-07 is mounted on the board and can be unmounted easily.
Step 5:
ESP-12 can be also mounted.
Step 6:
How to mount a module.
Step 7:
How to unmount.
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    5 Comments
    Simply perfect.
    For myself I thouht to contact the ESP-12 from below and fix it with a bar, but from the side is of course more stable and easy to adjust.
    It seems a very good solution for programming and testing a ESP-12 before productive use. Of course for prototyping I will use a NodeMCU. But as soon as a prototype ans its software works, I will simply put a naked ESP-12 into this holder, to program it before soldering to the circuit.
    It reminds me of the nice Epromer and the Textool-Socet It had for my C64. Youth come back :-)
    That's just what I was looking for :-)
    Can you explain the purpose?
    wow, its super, please can you share files for pcb?
