Introduction: Fruit & Nut Truffles
Looking for a healthy treat for Valentine's Day? This is a great alternative to chocolates or sugary candies - and you can make them yourself! These truffles are incredibly simple and easy to make and look as expensive as a box of chocolates!
I will list the four variations you see in the picture but any fruit and nut combo will work.
Strawberry Truffle
1/2 c. dried strawberries (reserve one or two for garnish)
1/2 c. walnuts (reserve one or two for garnish)
1/8 c. oatmeal
Cranberry-Plum Truffle
1/4 c. dried cranberries (reserve one or two for garnish)
1/4 c. dried plums
1/8 c. oatmeal
1/4 c. almonds (reserve one or two for garnish)
Date Truffle
1/2 c. whole pitted dates
1/4 c. raisins
1/2 c. walnuts
1/8 c. oatmeal
Peanut Butter Truffle
1/4 c. peanut butter
1/2 c. raisins
1/4 c. almonds
1/4 c. oatmeal
Step 1: Grind Ingredients
If you are making multiple flavors of truffles and peanut butter is one of them be sure and make that one last. I make one batch and use the food processor again for the next flavor without cleaning. Makes it quick and easy!
***I only show one flavor of truffle mixture in the food processor since all steps are exactly the same for each recipe.
Step 2: Shape the Truffles
Each recipe will make approximately 16 teaspoon sized truffles.
Step 3: Make the Garnishes
Remove from freezer and cut out small squares then remove from the waxed paper. Cut each corner off of the squares shaping the pieces into circles. I added a dragee on top for added decoration. This is optional. ***Reminder - if you do add dragees remove them before eating.
For the walnut garnish: If you cut the ends of the walnut off you will get a natural heart shape. You will get two to four hearts out of each walnut.
For the cranberry garnish: Since dried cranberries are hollow you can cut then into 1/8 inch slices and bend then to make little hearts. This might take a few tries but you will get two or three from each dried cranberry.
For the almond garnish: Cut an almond in half. Keep cutting in half until you have small square shapes that will fit nicely on top of your truffles.
