ESP8266: DHT22 to MYSQL and HighCharts
Introduction: ESP8266: DHT22 to MYSQL and HighCharts
I will tell you how I did to get an ESP8266-01 to read data from DHT22 and send it to an MYSQL database then view the data with HighCharts
Features that I will add later is HighStocks
You need below items:
ESP8266 ESP-01
ESP8266flasher, also called NODEMCU FIRMWARE PROGRAMMER, attached in Step 1
LUA Loader, attached in Step 3
If you want to use the sleep function you need to solder before start, see step 2
NODEMCU website
HighCharts demo
EDIT 150826: Updated INIT.LUA. added "--" before "end)" line after -- node.dsleep(sleep*60*1000*1000)
EDIT 150924: new ESP8266Flasher version, corrected errors in readdht22.lua, renamed to readdht22_test.lua for testing purpose
EDIT 151005: updated readdht22_test.lua(removed timer) and readdht22.lua(change so timer repeats)
Step 1: Flash ESP8266 With Firmware
ESP8266 -> TTL
TX -> RX
RX -> TX
The USB-TTL that I used had the possibility to select power, I used 3.3V
Plug-in USB-TTL to your computer, wait until your PC have installed drivers for USB-TTL
Start ESP8266Flasher.
I used version 1.0.5619.5450 of ESP8266Flasher EDIT 20150924
I used version 0.9.5 20150318 firmware, build-in ESP8266Flasher
Advanced->Baudrate 230400, Flash size 4MByte, Flash speed 40MHz, SPI Mode DIO
Select COM-port and press Flash. If the connection is correct you will get a QR-code at bottom left
When it is ready, green check appear in bottom left, close ESP8266Flasher
Step 2: Connect ESP8266 to DHT22
Unplug USB-TTL, so the power is disconnected, we dont want to damage anything
Disconnect GPIO0 from GND
ESP8266 -> DHT22
GPIO2 -> Data
If you want to use Sleep function you need to solder RESET to leg 8 on ESP8266 chip
Step 3: Upload Test Code to ESP8266
Before we send any data to an MYSQL we must test so that the ESP8266 can read from DHT22
I used LUA Loader version 0.87
Start LUA Loader
Select COM-port, Settings->Comm Port Settings
Click on Connect, upper right field should be green if you have connection
Click on Restart, middle right side
You should now see some text poping up, if not you have something wrong with the firmware in ESP8266 or the connection is not correct
To upload a file click on Upload file, bottom right
Upload dht22.lua and readdht22_test.lua
dht22.lua: to communication to dht22 sensor
readdht22_test.lua: read data from sensor and print it to the screen in LUA
When you have uploaded those two files select readdht22_test.lua from the yellow section and click dofile
Now you should see two lines
Humidity: xx.x %
Temperature: xx.x deg C
For every press on dofile you should see values from sensor
Step 4: Prepare MYSQL Database
I am using a WAMPServer 2.5 with Apache 2.4.9, PHP 5.5.12 and MYSQL 5.6.17
I don't know so much about PHP and MYSQL so please comment if some information is missing or wrong
Create a user named "user" and the password must be "password", these can be changed later on if wanted
Attached is an export from the database that I am using
Database name is dht22 and datatable name is temphumi
column 1 is date
column 2 is temp
column 3 is humidity
Step 5: Test PHP File
This is my dht22.php, download dht22.txt and rename to dht22.php, it seems to be blocked to download .php files, save it in the root of www on your webserver
change IP adress inside file, now it is, change to IP where your webserver is installed
test it in your webserver by typing, e.g. "" [ENTER]
open your MYSQL database and now you must see a date, temp and humi values
Step 6: Upload Final Code to ESP8266
change WiFi settings in top of file, SSID, Password and IP
readdht22.lua: read data from sensor and write to MYSQL
if you want to use Sleep function you have to remove -- from init.lua file
--tmr.alarm(1, gsleep*1000, 0, function()
-- print("timer1 trigger dsleep")
Step 7: VIew Data With HighCharts
Download files. Save .js files to a sub folder named JS and txt files in the folder above JS, rename txt to php
Access temphumi.php with a web browser, if everything is OK you should see data that ES8266 has sent
will be updated soon
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Can you make a video of this tutorial ...
    Thanks in Advance...
    hi, thanx for this very interesting post :) , I just wonder where is your webserver ? is it the same PC that you're working on , or some external Webserver. I just installed XAMPP in my PC and for the IP that I use to execute php files I use "localhost" instead of "" that you're using, what do I have to do to work with it... and thanx in advance
    Hi , I'm having the following problem if use LUALoader to run readdht22_test.lua , it does not return the temperature test and humudidade . I downloaded the Espplorer as recommended by one of the visitors, and send it returns dht22.lua > dofile ( " dht22.lua " ) ; dht22.lua : 12 : table index is nil
    You might want to update the PHP script, as it uses the long outdated "mysql" functions. Now you are supposed to use "mysqli". Other than that, this is a really well written Instructable.
    Finally I get it working... DHT22 is OK :)
    I build custom nodeMCU firmware in:
    Flashed float version with build in support for DHT modules, after that there is no need to use dht22.lua :) ...and test.lua is this:
    pin = 4
    status, temp, humi, temp_dec, humi_dec =
    if status == dht.OK then
    print("DHT Temperature:"..temp..";".."Humidity:"..humi)
    elseif status == dht.ERROR_CHECKSUM then
    print( "DHT Checksum error." )
    elseif status == dht.ERROR_TIMEOUT then
    print( "DHT timed out." )
    For uploading LUA files I used ESPlorer at
    It's much more user friendly than LuaLoader... and it's much more faster :)
    Hi flopp999,
    I have some trouble at Step 3. Firmware has been flashed successfully, both LUA files were also uploaded with no problems, but if I press dofile I get only "dofile(readdht22_test.lua)" and date-time but no values.
    Is it possible to somehow test DHT22 sensor? Or, write some RAW data from it instead of calculating temp and humi?
    Many thanks ;)
    For creating MySQL table better use this code:
    `temp` varchar(255) NOT NULL,
    `humi` varchar(255) NOT NULL,
    PRIMARY KEY (`dt`)
    Yours exported table will also work, but you have there exported one row of data.
    Also very strange stuff is the primary key and never ever use DATE for filed NAME. It is the name of MySQL function and may couse troubles in the future ;)
    Thanks kubik256. As you may understand I am very new to MySQL, very good information.
    Do you mean that primary key cannot be "DATE" column or it is the name of column that is strange as primary key?
    *filed do you mean field?
    I mean field ;)
    A key can be that field, but you should better choose another name and don't use names of MySQL inner functions, coz it can cause some troubles ;)
    And in your sql file it is not PRIMARY KEY... but you have there these two lines at the bottom of a table spec:
    UNIQUE KEY `datum_2` (`date`),
    KEY `datum` (`date`)
    But there is no field with name "datum_2" ;)
    Better use something like this:
    PRIMARY KEY (`dt`)
    And also quotes can be omitted if you are using short names with no special chars ;) After that it can look like this:
    PRIMARY KEY (dt)
    The PRIMARY KEY have to be used, because Unique key columns are allowed to hold NULL values. The values in a PRIMARY KEY column, however, can never be NULL ....and you don't want any NULL value in date-time stamp ;)
    hmm why is this guy connecting the last pin for deep sleep ?
