3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Earth Box from a Plastic Barrel
What can you do with empty 55 gallon plastic barrels? Why not recycle them into an attractive low maintenance container garden. Earth boxes are self watering containers which take the work out of gardening while providing healthier plants and more vegetables. While there are other earth box designs, my goal was to remake plastic barrels into attractive pots which could be placed anywhere around your house. Here's how you do it.
Step 1Materials
Materials
A 55 gallon plastic barrel and a plastic tube are the main components of the earth barrel. I used an empty barrel we get soap in at work and the tube is a recycled plastic leg from a storage shelf. Both were free and looking for a new job. My cost per earth barrel was about $4 because I painted them and already had the tools. One can of spray paint will put 2 coats on 2 planters.
List of things you'll need:
55 gal barrel
1 1/2" PVC pipe 20" long
4 zip ties
10 long aluminum rivets
3/4" PVC plug
Spray paint for plastic (optional)
Plastic epoxy to fill punctures if necessary
Old towels -- it's impossible to get these barrels completely empty so you will make a small mess when cutting your barrel
Tools: drill and bits, jigsaw, hole saw, riveter, crescent wrench, Sharpy, pliers
34 comments
Apr 8, 2012. 5:16 AMdana-dxb says:
woooooooooooooow thats just wht i did !!!!
great maids thinkalaike looool
i had some mats so
this is the castle of my dreams hehehe
May 24, 2011. 12:58 PMCeaseFire says:
Lattice plant support added.
Feb 14, 2011. 4:39 PMPizzapie500 says:
Where'd you get the 55 Gallon Drum? I tried my local carwash but they were out, so they said come next week; out. Come again next week; out. Last time I went; out. So yeah, I really don't know where to get them. Do they have them at resturants?
May 24, 2011. 1:01 PMCeaseFire says:
Beverage companies have them, flavoring companies (snow cone flavor providers) have them. Look in local papers and they're often offered at $10 each.
I also found some that laundry mats owners were selling.
May 24, 2011. 12:56 PMCeaseFire says:
My newest version of the 55-gallon self-watering planters. I used plastic lattice, held together with plastic zip-ties for safety and for more plant support to cover the wires I string from drum to drum. I've grown watermelon, cantaloupe, tomatoes and this year a giant, bushel gourd.
The soil mixture I like most is 5 cups lime and 5 cups 8-8-8 fertilizer per container. I put the fertilizer inside old stockings so that I can easily remove it at the end of the season (removing salts). Next spring, I use the same 5 cups lime/5 cups 8-8-8 fertilizer. Works great.
Feb 1, 2011. 10:50 AMRixyFisk says:
one thing we use that works well is a skill saw attached to some two-by-fours at the right length adn angle that rotates around the barrel. its kinda hard to describe but it works fast and effectively. you can seem some pics of our earthbarrels on our site: http://barrelsupply.ucoz.com/index/0-2
Dec 8, 2010. 7:28 PMRonyon says:
I've built the 5 gallon version, but instead of a container for a soil wick, I used plastic screen, poked through a hole in the bottom of the top bucket and stapled in place.
Worked great, so I'm wondering if a fabric "bag" of some kind affixed to the top rim of a single barrel, and filled with soil,would work?
Aug 20, 2010. 10:48 PMjman4117 says:
Excellent! I used this but had to modify it slightly to work with my barrels. Mine have the lip top and bottom, so I had to cut one of them off. Also, have you tried using a table saw with this? I've made two, and the one a jigsaw, and the second with my table saw. I got much more accurate cuts on it, and it went much faster.
Aug 20, 2010. 1:34 PMflove101 says:
Incredible! Awesome! Now to source 55 gal drum.
Feb 9, 2010. 8:25 AMthe rural independent says:
Awesome instruct able.  I also use a variation of Earth Boxes.  Mine cost more though, they are made from large Rubber Made type containers.
I use a about 4-5 inches of river rock below the dirt (on top of the separator) to allow heavy rain water to drain down easily and also roots can navigate quite easily downward to get to the water. Someone told me this actually makes for a quicker growing and longer root system - not sure if it does or not.
If anybody wants a look at a much more complex raised bed garden utilizing these principals, check out the "wicking bed" here:
www.theruralindependent.com/
Jan 20, 2010. 11:57 AMdaisyrock1 says:
I think even I can do this with such nice instructions!  Great ible, fav'd and am definitely going to try next month (a little closer to spring).  Thanks for sharing :)
Jun 27, 2009. 7:21 AMCeaseFire says:
I used your idea to make a "full-size version" I used a 5 gallon barrel for the soil wick and used the barrel top for the soil platform. Works great1 Thanks for the idea!
Jul 8, 2009. 6:52 AMCeaseFire says:
The barrels of water/soil are so heavy, I figured thy would support a lot of weight. I drilled holes in the edges and strung wire from barrel to barrel. I plan on the 3 cantaloupe plants going all the way to the gas tank! So far, so good.
Apr 23, 2009. 9:59 AMshoppe says:
This is a terrific idea! I'm looking forward to making these. But I was wondering, rather than ensuring that the barrel top is leak free with plugs and patches, and then using the barrel bottom as the separator screen, could you use the barrel top instead as the separator screen and take advantage of the already leak-free molded barrel bottom for the main container?
Apr 23, 2009. 11:38 AMshoppe says:
That's great! Once again you've worked everything out for me. I suspected that the top might not fit within the bottom. And I agree with you that using the top as a base is more aesthetically pleasing. Another thought just occurred to me: How about if I laid in cloth landscaping fabric before adding the soil to prevent the soil from falling through the holes in the separator screen? Would the fabric impede the way the water wicks up or would it stop the roots ability to get to the water? Thanks again.
Jun 27, 2009. 6:45 AMCeaseFire says:
Holes in the separator screen are for aeration, but mostly to allow excess water to drain from the soil (in case it rains for ages and lots of water gets into the soil from the openings around the plants).
May 24, 2009. 11:34 AMCeaseFire says:
Wondereful idea. I want to make some, but will put them on casters so they can move around. Also, the ring holding the plastic on is a good afterthought. If you wrapped the plastic over the ring and temporarily held it with tape, you could lower the ring (ring on inside of plastic and black plastic showing only) to make a neater edge -- harder to explain than to do.
Jun 27, 2009. 6:33 AMCeaseFire says:
(removed by author or community request)
Jun 27, 2009. 6:01 AMTnT101 says:
I LOVE this idea. Sure beats the standard planter that requires drainage holes on the bottom. No stains on my deck! You can even install tubing to direct overflow off deck or between floorboards.
Apr 22, 2009. 2:51 PMel_wombato says:
Very ingenious. After seeing the earthbox/earthtainer I was wondering if a barrel would make a good candidate. Looks like I have my answer (and I already use 2 as rain barrels). Does the separator screen really support all that weight? It seems like it would be too much. Granted, a barrel is much thicker than the plastic bins these are usually made out of.
Apr 20, 2009. 8:42 AMiPodGuy says:
Speechless... Awesome..... Fav'd.
Apr 6, 2009. 3:37 PMdolabil66 says:
Nice Job !! Great Instructable ! I was planning on making a bucket planter , I`m going to follow your plans when I do
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:kentdvm
