iImage Information
This miter joint is close to fitting, but it has a slight gap on the inside of the corner. Few things diminish a good wood project like miters with visible gaps. It is a great feeling to make a picture frame or install molding and have tight, clean miters.
Step 1A quick and easy solution to miter joint gaps
iImage Information
Firmly clamp the members of the joint at the angle needed, in this case a 90 degree corner. Gently run a fine tooth saw down the joint between the two pieces. A back saw or a dovetail saw works perfectly. When finished, slide the members of the joint together and fasten in place with glue or nails.
I think I got it out of a woodworking magazine. You set the miter gauge for your 45ish cut, make two corners, put them together, then trim your ends without moving the miter gauge adjustment. Getting all of your angles correct involves flipping pieces over somewhere in the process. This is the big drawback of this technique if you are cutting moldings that aren't flat on both faces.
Another trick is to err on the side of the outside being the gap, then run a metal rod on the outside closing up the gap. Wood is somewhat flexible in this regard :)
I bought a gadget at a yard sale that sort of relies on your method Phil. I got it so cheap I just bought it for the saw it came with:
http://www.magicmitre.co.uk/
Donw
From this day forth, all of my mitre joints shall be nanometre-perfect.
Can you point me to a place i can get one of those clamps ??
I might have to make my own if i cant find one
I checked your profile before answering and see you are in the UK. I just checked and you can get similar clamps (or cramps) here if you cannot find them where you buy tools locally. They cost a little over four pounds in the UK. The clamp in the photos is adjustable for almost any angle. I bought it at a local hardware store in the USA back in the 1960's.
Yes, this is really a handy way to make miters fit. Several serious woodworkers I know have long been aware of it, too.
Thank you for your comment. I hope you are able to post the Instructables you have in mind and to do it soon. All the best to you.
Hopefully it should work but if not i shall invest in a better one
Your pound stores must be based on the same idea as our dollar stores, although you do not get much there for a dollar these days.
http://books.google.com/books?id=hZkBAAAAYAAJ&dq=woodwork+for+secondary+schools&printsec=frontcover&source=bl&ots=FBVQr4N_Gk&sig=TqadpMrsipNuSYI7YxioyAOrQlM&hl=en&ei=xNdAS_WHCI30McSwqKcF&sa=X&oi=book_result&ct=result&resnum=1&ved=0CBUQ6AEwAA#v=onepage&q=&f=false
