Introduction: Easy IronMan Arc Reactor Necklace
Today I will show you how to make a easy IronMan arc reactor necklace out of a DVD drive motor and a blue LED.
Step 1: Tools and Parts
The tools and parts you need are:
- DVD motor
- Long piece of wire
- To small Neodymium magnets
- Wire stripers
- Pliers
- Hot Glue gun
- Drill
- Grinder
Step 2: Removing Your Rotor With Windings
First you pry the off the stator (or case) of the motor. I used a flathead screwdriver to pry it off. Now grind the bottom of the center piece and drill or tap out the center piece from the rotor.
Step 3: LED and Hot Glue
Now grind the LED down to about 1mm from the metal inside the LED and Hot Glue the LED in the rotor. Sand down the dome of Hot Glue to make it look more realistic.
Step 4: Power and Wire
Cut and strip the wires and connect it to the LED and Hot Glue the wires in place. Twist the wire on the magnet and Hot Glue it in place then mark the polarities on the magnet. Connect the button cell batteries between the magnets and it will light up. If it dose not light up check the polarities and the LED connections.
Step 5: Have Fun
Now go and show off your new IronMan Arc Reactor necklace to your friends and family. Show me what you improved and have fun.
Formlabs Contest
Make it Glow!
Enchanted Objects
