Easy Solar Robot Nightlight
 by Amyscrazycrafts
Featured
Step 1: Design Robot
I designed my robot in CorelDRAW and used Boxit to 3-D the design.
I used Boxit 4 times for the head, body, one leg and one arm. Then copied the one leg and one arm so I now have two legs and two arms.
Head:
I measured the solar light and that determined Robbie's minimum head size.  I added an extra inch width to his head because I thought it looked better.
The eyes are lower to account for the solar light height.
The center eye hole circles are sized to hold LEDs (and LED holders) if I wanted to wire them in later.
Body:
The body was just to look good with the head, has the same depth as the head.
I designed the gears and named him "Robbie" the kiddy name for Robot.
Arms:
The arms were designed to look proportional to the body & head.
Depth is half the body depth.
Legs:
The legs are the same depth as the body.
Wanted short legs for better stabilizability.
I have added the file so you can cut the design out on a scrollsaw or have a laser cutter cut the design.  It is just the outline of the robot, so you can add your own face, heart (or gears) and name.  I also have the robot laser cut wood listed on Etsy & Zibbet in my AmysCrazyCrafts store.
Step 4: Bolt Robot Together
You will need at least three washers, one lock washer, one nut and one bolt per joint.
How this setup lays out:
Head of bolt inside arm or leg, Washer, wood, washer, wood, washer, lock washer, nut.
The head has a small plastic tube instead of a washer between the pieces of wood.
Tighten bolt and nut snug.
Step 5: Installing Solar Light
Remove top of solar light.
Line up solar cell with square hole in top of head.
Glue top of solar light to top of head.
Note: may need good quality tape to keep in place.
azharz says: Apr 1, 2012. 5:53 AM
Love this instructable and the Robot is look like the minecraft boy
Exscaly says: Feb 19, 2012. 5:42 AM
Lol! Love the reference. Great idea with the beads.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
