Easy Steampunk Top Hat by treese1
What you will need:
- Costume top hat (available at party city or other costume stores
- 2 push button lights
- elastic headband
- hot glue gun
- Gold/copper wire
- wire cutter
- Gold paint
- feathers
- brown fabric
- lots and lots of gears
The idea with this is to just hot glue everything into the place you want it along the brim of the hat or along the top.
We decided to create brass goggles out of push button lights and use wiring and gears to decorate them.
Depending on what you find, you can add stovepipes, stopwatches, lights, coils, really anything you want onto your steampunk hat.
Penolopy Bulnick says: Jan 17, 2013. 2:18 PM
Cool! I really like all the details. You should enter this into the Holiday Gifts Contest!
karossii says: Dec 26, 2012. 2:30 PM
That's not a top hat, but a fedora...
Lorddrake says: Dec 27, 2012. 5:30 PM
is it a fedora or a Stingy Brim Pork Pie Hat?
treese1 (author) says: Dec 27, 2012. 6:49 PM
definitely not a fedora. I think it may look that way because of the lens I was using to take the picture and the size of the "goggles", but it is in reality a top hat.
karossii says: Dec 27, 2012. 9:26 PM
No, one of the defining features of a top hat is the fact it has straight sides; they do not slope in or out in the slightest. The circumference at the base and at the crown will be identical, with no curves or slopes between. That hat, which looks strikingly like a fedora, may be some other type of hat, but it is definitely not a top hat...
Lorddrake says: Dec 28, 2012. 4:23 AM
I have to disagree .. a top hat does not necessarily have to have straight sides.  in fact many tended to flair out towards the top. I believe the hat you are thinking of is the stovepipe hat.  While very similar there are subtle difference. Stovepipe hats are taller than top hats.  They are generally considered a more casual everyday hat whereas the tophat is more for formal affair, the stovepipe hats have a flat brim rather than an upturned brim, and most importantly the straight sides as opposed to the flair that top hats have.
treese1 (author) says: Dec 27, 2012. 11:33 PM
I'm glad to have the advice of a head-wear aficionado. I'll take that into account when building Mark II. Thank you, sir.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
