The idea is to catch the wifi waves that pass near your laptop without reaching it, and make them bounce into your wireless antenna.
I use it standing behind my laptop when i'm.. reading my mail..
..to make it.. load faster..
**hmm...**
..yeah..
It actually nearly doubled the signal strength i got from a certain access point.
It's really easy you'll see, so get into it right now!
Remove these ads by
Signing UpStep 1Gathering materials
-Aluminium paper
-A big cardboard sheet
-some light pipe
-Duct tape
-Some other cheaper adhesive tape
-some screws
-a wood bit
-some (pretty soft) metal parts you can cut and bend
-tools: screwdriver, saw
http://www.powermicrowave.com
http://www.powermicrowave.com/2wen/2w-en.html
http://www.powermicrowave.com/en/4w-en.html
Im gonna try it to improve the wireless signal coming to my sleepout.
Focus is important. Simply divide the width by 4 and you have your focus - Or use the 45 degree reflection points for the focus. You will also find that orienting your antenna 90 degrees with respect to your diagram will also boost your signal quality by a significant amount.
http://www.ctforumgroup.com/forum/viewtopic.php?f=36&t=19202&sid=27f6b605012f2cb9b3f94733115c0345
Tips:
-If you spread the sides the focus point moves away from the reflector
-if you close them to focus point moves in towards the reflector
Experiment! And let me know what you got! =)
Guys the idea is to focus all the waves in a focus point where you're supposed to have either your laptop or your real antenna. If you spread the sides the focus point moves away from the reflector and you can have your antenna/laptop further away from the reflector. It all depends on how much space you got.
I hope it works for you! Let me know what happened =)
