Build an Electric Motorcycle on a budget
The Goal of this project was to convert a classic motorcycle into a clean, quiet, electric daily driver that would reduce the amount of automobile pollution caused by my short to mid-range driving trips.
COST: $1,000
RANGE: 40 Miles
SPEED: 40mph with current sprocket setup
CURB WEIGHT: 320ish Pounds, around 50 more than original
RECHARGE COST: Less then a Penny per mile
Ahhh yes, The Electric Dream! Clean, Quiet, and best of all not a drop of Gas!
There is a lot of great information on current Electric Motorcycle Instructables, but I still ran into some snags and made some mistakes along the way. So I will do my best to cover where I went wrong to save you some time, money, and effort. When the build was over a book called Build your own Electric Motorcycle was published, Needed less to say its a resource I wish I had along the way.
Also, by no means am I an expert. In fact, the only class I failed in college was "introduction to electronics" . In saying that, I am looking forward to any comments or feedback on how to improve my project. Also follow me on Twitter or on my Electric Motorcycle Blog to  keep up with my current projects and Electric Motorcycle News.
Step 1What you need
What you need
Here is a list of what you will need and how to find it:
A Plan: This is the best question to ask yourself before going out and buying anything.
How far, how fast, how much? To get a good idea of this, spend some time on: http://www.evalbum.com/type/MTCY - its got 1000's of Electric Motorcycle conversions with pictures of the bikes and the components used to make them.
1.Donor Motorcycle or a rolling chassis - Check Ebay and Craigslist. Personally, I like to set up an RSS feed from my craigslist search, otherwise I browse for way to long when my ADD kicks in. I found my 1967 Honda Dream(ca160) on craigslist for $275, with frozen motor, but hey, I don't need that anyway.
2. Electric motor - There are lots of options out there, but I recommend a Brushed 48v Etek Briggs and Stration due to its price, power, and availability on eBay. The original is no longer in production so your options are to buy a used motor or get a clone. Also, if you have a local golf shop go talk to someone there - they are gear-heads too! These guys will like you and they will like your project. So see if they can cut you a deal on an electric motor, there will be plenty of just sitting around.
3. Batteries again, consult your plan. My plan was 30+ range, so I picked up some deep cycle batteries at walmart for $62 a piece. They are 12v 105 aH. Looking back, I wish I would have gone with some smaller and lighter batteries. I really don't need the amount of range these current deep cycle batteries provide.
4. A motor controller that delivers/regulates the energy from the battery to the motor. Think of this as a transmission. I found a Curtis 48volt 300 amp controller on eBay for $150.
5. A twist grip throttle that sends an electric signal to the controller - which determines how much energy is sent to the motor from the batteries. Most popular is the Magura Twist grip, available on ebay.
6. A battery charger to re-charge your batteries for continual (cyclic) use. I am still working on finding the best charger for my ride, but I would like to do something that could be out on board.
7. A high-current switch or Contact Buy this on eBay or at a Golf Cart shop. This part makes the loud "click" sound when your turn on a golf cart.
8. A high-current fuse to limit the amount of energy drawn from the batteries in case of a short/failure. Typically = to Control max amperage. I got a 2 300amp fuses on eBay for $19 bucks
9. A large gear ratio to reduce the amount of current required when accelerating (this can be accomplished with a large custom rear sprocket and a small front gear/pinion on the motor). My current gear ratio is 3:1, optimal would be 4:1+
Optional stuff: instrumentation, speedo, ammeter, or a way to judge batteries state of charge.
72 comments
1-40 of 72next »
Sep 4, 2009. 2:55 PMllanyort says:
don't they have a kilowatt meter that plugs into an outlet and then you can plug in your electrical device into that and measure the amount of electricity you will have used ? I plan on using this method and reimbursing my boss. im thinking its gonna be a few cents a day.
Jan 22, 2012. 9:09 AMrandomray says:
Hmmmm , I could probably do something like that , They don't say anything about the guys pluging in the heaters on the private diesel trucks .
Aug 15, 2011. 4:32 PMbbroughton says:
I really appreciate your sharing your input with us. I have always wanted to do this and now that I am out of college and have the extra money I think I will begin pretty soon. I realize that using lithium batteries might be more expensive but do you think it would change the way you built the bike?
Great song on the video by the way!
Jul 19, 2009. 12:54 PMjayeshshinai says:
my friend made one wid an imported 1000watt motor...mounted it on a cutson 2' aluminium pipe frame wid d rear mono shock. i checked d motors used on evalbum.com, n none of them use "watts" as specifications..so wt specs do i havta tell my dealer for a motor running on 36volts, with enuf torque to move a bike (and 2 riders) weighing a total of 170kg? clearly m not so gud wid electronics...any suggestions?
Sep 4, 2009. 10:37 PMsoulvoid says:
no trying to be rude but you need to learn how to type so everyone can read what your talking about. it took me 3 times to read over your comment to figure out what you were trying to ask. lol
Apr 13, 2011. 11:57 AMjayeshshinai says:
i knw its pretty late for me to reply...ill try not eating up my words this time.
A friend of mine had got him shipped a 1000watt motor, he mounted it on a custom 2" aluminium bicycle frame which had a single rear shock absorber(soft tail bike).
hope it makes sense now,
Apr 17, 2010. 5:19 AMLance Mt. says:
How would we tell through this what momentum and acceleration could be achieved?
For instance in he's case lets assume its 36 Volt, 1000 Watt, 3000 RPM, 35.6 amp, and 170kg. We understand that that it will have 1000w going through it,  as long as its a brushless dc. Do we need more information to complete this? I looked up something similar, and the shaft was 3/8” X1.25". Width is about 3/4 of length on this particular model.   Steel is generally .290 pound/ cubic inch.
Ok, from this we can probably work out how much weight it is spinning at 3000rpm using a 60 joules/ 60 watts per second.
9.5mm (D) x 31.75 (L)
19mm x Pi = 59.6902
                        59.6902 x 31.75 = Volume
                                                          Volume = 1895.16576mm3
 Volume x 0.78 g/mm3 = 1478.2292992568733614600199043514 g
                                          =  14.78 kg
  The motor is using 1000w to turn 14.78 kg at  3000rpm
     To save my head more ache. I'm going to pretend the weight is 147.8 kg. At a 1:1 ratio this would turn 300rpm. which is  5 rotations a second still, without gearing.  How do we work that out? I'll get a base to work off.
Oh.. It seems I could have skipped a fair bit of this by using the equation:
MPH = RPM * Tire Diameter / Gear Ratio * 336
MPH = 3000 x 4064mm inch (Average) / 1:1 x 336 = 4096512000mm/per sec maybe?
MPH = 3000 x 40.64cm / 1 x 336 = 40,965,120 cm/per sec
 OR 254.5 mph. This just doesn't seem right at all, remember. I'm doing this as I go along. Perhaps Inches will do it.
MPH = 3000 x 16inch / 1 x 336 = 16,128,000 mph.
OHHHHHHHHH I see what I have done, I haven't put the answer at the front of the equation. Would that mean that I should reverse the current equation to get my answer?
Back to finding the base. Ideally I would like 1kg x 1w (1J) = x amount of metres
Some useful points through my searching
"100 kW is roughly equivalent to 134 horsepower"  - 13.4 horsepower, however...
"One horsepower for rating electric motors is equal to 746 watts."
"In terms of mechanical energy, one watt is the rate at which work is done when an object is moved at a speed of one meter per second against a force of one newton. 1W = 1Js-1 = 1kgm2s-3 = 1Nms-1"
Apr 17, 2010. 5:58 AMLance Mt. says:
 That Equation is killing me. I'm only in year 9, it doesn't make sense to me. The 336 constant must have to take into consideration gravity, air resistance as it rises, even ground ie.
But it does not take into consideration of weight, or little things like where the force is applied and so on.
I have much to learn, but for another night.
Mar 15, 2011. 12:00 PMarivera-2 says:
Will this motorcycle work in the rain??
Oct 4, 2009. 5:15 PMsolivant says:
what about a break system?
Feb 8, 2011. 6:52 PMFurtherThanTesla says:
Shorting the moroe terminals will cause the motor to generate power, and then eat the power in reverse- meaning, it will resist any movment and convert it into heat. Using PWM, you can vary the strength of this effect, and voila! you have breaks!
Dec 9, 2010. 10:07 AMuberdum05 says:
Just flip the thing into reverse and just gently apply the throttle :)
Feb 8, 2011. 6:49 PMFurtherThanTesla says:
Just wanted to say, how awesome this project is. Not only is it a nicey made electric bike, but i think it looks pretty cool too! I am concidering building a high-efficiency streamlined 3-wheeled solar car. But I want one that goes fast. So, i am intending to use the Etek motor, and a pair of 1kw panels. I came to this instructable because i need an electric car before i can have a solar car! and this is exactly the setup i wanted. Figured i would go look at someone whose been there before I spend $500 on the Etek.
Nov 20, 2010. 5:00 AMmtm101097 says:
This may be a stupid question, but why not use rotating light dimmer as your throttle control? They probably make very large ones capable of the power required. BTW nice instructable
Feb 8, 2011. 6:44 PMFurtherThanTesla says:
Sorry, but no. That motor draws more than 5 killowatts. there is no light dimmer (mabye other than expensive industrial-grade ones) that is made to handle that load. Also, Dimmers are made to work on AC power. The motor on that bike is DC. and, lastly, that motor is for a lower voltage than what dimmers are made for, so it would draw more amps. a 5kw dimmer made for 5kw couldnt handle 300 amps at 48v.
Jan 25, 2011. 5:54 PMzack247 says:
this is very cool! i am taking a welding class next year and now i am thinking of making a frame for a more-or-less motorcycle shaped vehicle, if i can get that part done, i am going to use this instructable and make a bike of my own!
PS: in step 2, its donor, not doner :)
Jan 2, 2011. 2:52 PMsn0manX says:
just wonderin, do you still happen to have the gas tank?
Oct 13, 2010. 7:42 AMAlternateLives says:
What is the horsepower of the unit? sure, going 40 mph is all well and good, but if you can't get up hills, the speed won't make much difference.
Sep 13, 2010. 10:04 AMiloveairsoftstuff says:
Is it really neccesary to use a controller box? im sorry if this is a stupid question, but I am on a low budget and to save some money, i thought that i could just use a potentiometer. what would be the most beneficial method if cost is an issue?
Sep 30, 2010. 1:26 AMskaar says:
... k... a potentiometer, huge, expensive, heavy, and not terribly efficient, compared to a controller box that handles the same power. but it depends on the kind and size of motor, some absolutely refuse to run at anything less than a certain voltage, and with a potentiometer, you'll have a choice, top speed, or stopped.
so... potentiometer
size-less battery space
expense-depending on what kind of power you want, you may end up going to something industrial
weight-requires more battery to haul it around, see size issue conflict
looking around, there's this http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=1625807-1-ND 511 bucks new, 811 watt capability, about 4x6x16" long. you can. alternately, get the same watts from a computer power supply, specialise it to work with only one voltage, get rid of the transformer, and use it as a controller instead of a supply... it could fit in half the space comfortably. there's a certain pleasure in making everything yourself, if you can.
Feb 4, 2010. 4:49 PMspiceyweasel says:
I am new to the whole EV concept, but something has been nagging me. Why do all these EV bikes exclude the transmission? Wouldn't your bikes benefit from having a taller gear ratio? I need to be able to cruise effortlessly at 70mph for at least three hours. Can you please enlighten me about the omission? Also, why do you have a smaller sprocket driving a bigger one on the wheel? Does the electric motor have that much zip?
Aug 17, 2010. 5:41 AMwobbler says:
You are asking a lot. 70mph for 3 hours implies at least a 210miles range, 4/5 times what most bikes are achieving. This range is impossible I would suspect on a motorbike with any current battery technology even at lower speeds. In addition unfortunately, the drag due to air resistance increases by the cube of the velocity, so a bike travelling at 70mph has 8 times the air resistance from the 35mph most of these go at, thus making it even more problematic. The technology will get there though.
Mar 16, 2010. 8:21 PM1zork says:
Transmissions are torque multipliers. The torque of much smaller electric motors exceed that of internal combustion engines. Speed can be accomplished with gearing. The choice is yours.
3 hours at 70 mph requires some considerable battery capacity. One way to reduce the required power and battery capacity is to build a bike similar to the AAR "Gator" style bike. Approximately 1/2 as much power required, and hence 1/2 the battery capacity.
Oct 7, 2010. 10:45 PMspiceyweasel says:
That bike looks like a three wheeled go cart a buddy of mine helped me build several years ago out of a Suzuki Hayabusa and a Malibu Grand Prix racing cart. It was insanely fast and too scary to enjoy.
Aug 21, 2010. 2:05 PMspiceyweasel says:
I was going to base my bike on the Fat Bike design....similar to very early Harley Davidson's only with an aluminum frame and wheels to reduce weight. Also, I am working on a proprietary front hub with a permanent magnet generator built into it to produce electricity while the bike is in motion. I don't know if it will help meet my range requirements, but it should help a bit. So, basically, I'll have an over sized bicycle with independent front and rear suspension and moderate sized tires built on the lightest, cheapest frame I can build....no storage save for a back pack....and the bare minimum lights to get it D.O.T. approved as a street cycle so I can hit the freeways. I'll check out the AAR Gator to see if it meets my criteria. Thanks.
Oct 7, 2010. 8:50 PMKrazeecain says:
Your custom front hub generator will only be useful for regenerative braking. Otherwise, if you let it generate power while you're riding, you'll only be wasting energy, as the generator will be slowing you down, so you'd have to apply more power to go faster. It's a vicious cycle that'd only serve to reduce your range in the end.
Oct 7, 2010. 10:43 PMspiceyweasel says:
Is that due to the added weight? I don't foresee a friction problem. Basically, I'm looking for something to continually charge a bank of capacitors to keep my power levels up and take the stress off the batteries. I'll figure something out.
Oct 7, 2010. 11:45 PMKrazeecain says:
No it's not from the weight. Ok, put it this way. How is your motorcycle moving? From the electric power in the batteries, which is turned into momentum, pushing your bike forward. When you add a generator to the front wheel, you're turning that forward motion back into electricity again. You're slowing down the bike, and turning its momentum back into electricity. It's much more efficient to just leave the bike's momentum alone.
Oct 8, 2010. 7:24 AMspiceyweasel says:
I'm a bit confused. There is no friction created in the production of said electricity, is there? The batteries provide electricity which produce momentum....momentum pushes the bike forward, causing the front hub (which is NOT being used for propulsion) to create electricity, which feeds the batteries and capacitors, which push the bike forward. I don't see anything in that thread of logic which would slow the bike down. One thing I can't help noticing is that these designs invariably use small sprockets to drive a larger rear wheel sprocket. Perhaps a change in gear ratios might help a bit? I'll tweak it until I get it right.
Oct 8, 2010. 12:12 PMKrazeecain says:
Isaac Newton: "energy cannot be created or destroyed, it can only change forms". It has nothing to do with friction, but with that law of physics. By suggesting that the front hub is giving you some free extra power, you are suggesting that energy can be created for free. Energy is never free, it always has to come from somewhere. Your front hub would be getting this energy from the momentum of the bike. That's how the regenerative braking works in hybrid cars, by letting the motor generate electricity, the car slows down. So, what have now is an energy loop, or cycle. The energy starts of as electricity in the batteries, which the motor turns into momentum. Now your hub is turning some of this momentum back into electricity, which is turned back into momentum, and the cycle goes on. No energy is gained or saved, it is in fact wasted, because of the numerous inefficiencies that plague all machines.
Oct 8, 2010. 3:07 PMspiceyweasel says:
So, what you are saying is, if I put a motor on the front hub, it WILL create some sort of friction....because SOMETHING has to cause the front wheel to slow down, if I am reading your words correctly. That's odd, since I don't feel any resistance against my hand when I crank a motor by hand. The shaft turns freely and produces electricity without a problem. There's that pesky physics again, trying to convince this poor bumble bee I can't fly.
Oct 8, 2010. 8:04 PMKrazeecain says:
It's turning freely because there is no load, try attaching a dead battery to it, or a light bulb and there will be noticeable resistance.
Oct 9, 2010. 6:21 AMspiceyweasel says:
Ah.....resistance. I will see what I can do about it.
Dec 27, 2010. 8:24 PMMaximusPsychosis says:
Yeah, magnetic resistance, its when there is a load on the coils, it pushes (and also pulls when they move away) against the magnets used, which in turn puts a load on the system... In a perfect setup, you'll lose about 10% energy over trying to keep speeds up and putting a load on. It would be a good idea to use it for regen, or "engine breaking" because you are obtaining the energy off the momentum when you want to slow it down.
energy is a funny thing, it bleeds out everywhere, sound, movement, light and heat..
Nov 4, 2009. 2:48 AMniuthon says:
yeah, where are the brake handles?
ps - great job!
Nov 24, 2009. 5:21 AMPKM says:
It's a geared bike- the front brake is on the right handlebar (step 3 image 4) and the rear brake is the right foot pedal (step 2 image 1).  The clutch is missing because it's unnecessary for a single-gear electric bike.
1-40 of 72next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:JoeMurphy(Check Out My Site)
I have always loved to take things apart. Now I am working to put them back together. Follow my latest project on Twitter @joe_murphy Also Check out my newest business at mercury11.com
