Electric Mountain Board
The goal was an electric conversion with minimum damage to the board and the ability to remove the system for standard riding.
Step 1Parts and Tools
Parts and Tools
I tried to get as many parts as I could locally but most had to be ordered online. The prices are approximately what I paid. Total cost of the project not including the board was about: $350
Board: MBS Core 95 from MBS Mountainboards. $300
Brakes: MBS V5 Brake Kit also from MBS Mountainboards. $60
Motor: 24V 300W Electric scooter motor from my local scooter shop. $30
Sprocket and Chain: Scooter sprocket and #25 chain also from my local scooter shop. $20
Steel pieces: 16ga sheet steel, perforated square tube (14ga), perforated bar and two flat bars (14ga) from Lowes. $20
The batteries, charger, controller and throttle were all ordered from Monster Scooter Parts.
Batteries: Two 12V 10 Ah scooter batteries. $65
Charger: 24V 1.6 Amp XLR Battery Charger and XLR charging socket. $38
Controller: 24V 500W Universal Voltage and Speed Controller. $33
Throttle: Generic 4-wire thumb throttle. $13
Other parts: Wire, electrical tape, wire connectors, nuts and bolts, zip ties, tie down straps. $35
Tools Used:
Socket set
Sawhorses
Hacksaw
Hammer
Adjustable wrenches
Hex key wrenches
Pliers
Clamps
Drill and bits
Jigsaw and blades
Metal files
Wire stripper
Chainbreaker - $30 from Monster Scooter Parts
173 comments
1-40 of 173next »
Feb 4, 2012. 1:00 PMchopstx says:
If possible, could you provide a close up of the drive wheel with the sprocket? I want to see how you mounted the sprocket. Thanks!
Dec 15, 2011. 10:01 PMrandymonster says:
i built one of these and have two more frames welded would anyone want to buy a complete 24volt 900watt version on a steel frame?
Oct 7, 2011. 6:32 AMbutty15 says:
this is probably a stupid question but i ride goofy ( right foot foward) so if i buil this would i need the motor on the otherside e.g rear wheel drive?
Oct 11, 2011. 9:33 AMbutty15 says:
thanks
Sep 9, 2011. 1:39 PMchopstx says:
Great idea, now im hooked after watching videos on youtube of these things.... :)
I have a lot of questions tho before i start spending money on the wrong stuff.
Is your setup 1 wheel drive? Do you need 2 motors(one on each wheel) and 4 batteries to make 2wd version? Wouldnt the board always turn with 1wd?
Would a Atom 90 be suitable for this?
If I am 140 pounds could i get away with a 400 watt motor? And still have good torque and speed? This would just be used for going around the neighborhood and on trails, not legit mountain boarding.
any way I can use a lever handle for throttle?
Thanks alot and great 'ible!
Sep 10, 2011. 10:49 AMchopstx says:
thanks! do you have any experience using rc motors and esc's instead of scooter stuff?
Sep 12, 2011. 4:40 PMchopstx says:
Yeah I think that if they will electronically work together, I would like to use a 750 watt scooter motor with a rc esc and controller.
I still have some research to do so if anybody that sees this has tips, tricks, or info that could help me build an electric mountainboard, I would greatly appreciate it!
Apr 30, 2011. 1:13 PMmountainboardpro says:
do u know of a way to make the board go 20 mph without raising the price to much?
Apr 30, 2011. 1:23 PMmountainboardpro says:
Hey, Vurp
do u know if a 24 volt baterie would work instead of 2 12 volts and would it affect the speed and the other parts?
Aug 30, 2010. 3:10 AMshadowman2 says:
How about putting a 300 watt(low rpm) motor on each wheel (yay for 4x4!!) And 20 laptop li-ion batteries underneath the board. This would be pricey, but the looks and power.. Maybe even a large capacitor as Bowmaster suggested (for double power at startup, since the motors would be direct-drive to the wheel. I wanna build this three years from now when i return to Canada.
Aug 30, 2010. 3:21 AMshadowman2 says:
Or maybe 2 1kw motors on each axle with chains!
Oct 25, 2010. 12:32 AMmnbouchet says:
This has already been done :D :
http://m.youtube.com/index?desktop_uri=%2F&gl=FR#/watch?xl=xl_blazer&v=X7g6eaY21t8
Can't even begin to grasp how awesome this is....
Nov 28, 2010. 11:02 AMKommieCid says:
Your link seems to be malfunctioning sir/madam, it may require revising
Nov 28, 2010. 11:59 AMmnbouchet says:
You seem to be correct :D Here's a working one:
http://www.youtube.com/watch?v=X7g6eaY21t8&feature=related
enjoy, the guy who has made the board posted other videos ;)
Sep 10, 2010. 1:56 PMsheen110 says:
hi vurp, could you help ,me out here ? iv damaged the thumb throttle when dismantling it and dont have a clue how it was wired
inside it has blue, orange,yellow and red
orange and yellow are contected fine and it lights up but red blue and white are cut. would you be able to remember how its supposed to be . ? i havethe same throttle as you.
shaun
Apr 24, 2010. 4:35 PMnitram135 says:
 I have 2 12 volt batteries that are in series that i want to connect to a 24 volt controller but when the controller touches the battery, i get a lot of sparks. Does any1 know why?
Aug 5, 2010. 7:52 AMinventor1995 says:
The leads in the connector may be bent and could be touching the two polarities of the battery together causing a short circuit.
May 17, 2010. 8:30 PMslivka says:
Make sure you got the polarity right.  Also if the batteries are discharged the can draw a lot of current at the begging.
Apr 15, 2008. 10:48 AMSystemZERO says:
What's the top speed on this beast?
Apr 16, 2008. 9:58 AMSpokehedz says:
Make the gear on the motor bigger. That'll increase the speed, but will reduce the torque--something electric motors have plenty of anyway.
Jun 8, 2010. 3:16 PMarf200 says:
or lower the gear on the tire. same efect though
Apr 17, 2008. 5:06 PMcomputerwiz_222 says:
True, but the more torque you demand, the shorter the battery life and the take off speed will be slightly slower because the motor has to build up "momentum" In other words, the motor has to overcome the stopped friction. Friction when the device is stopped, is much higher than when the device is already moving.
Apr 17, 2008. 6:44 PMSpokehedz says:
Why not push off with your foot for the first couple of feet, and then turn on the motor gradually as you help it along with your foot?
Apr 18, 2008. 5:24 PMcrakdos says:
That's how mine works, but it is still not fast enough. I guess its time to make another one
Apr 18, 2008. 7:27 PMcomputerwiz_222 says:
well I guess you'll have to *sigh* {sarcasm} I love building stuff lol
Apr 18, 2008. 5:07 AMcomputerwiz_222 says:
lol that i never thought of that... Plus, why wouldn't you. When you skateboard, you push off...
Apr 18, 2008. 3:42 AMbtop says:
Heh, thats a good idea. Get yourself moving and then let the motor do the rest.
May 21, 2010. 4:17 AMh3x_your_nightmare says:
dude this is a cool project...but! you should upgrade it ;) first of all...try to put that regulator with all the wires into a box to protect it from mud, dirt and humidity and then move one of that two batteries on the front of board ;) you should try a disk brake system if it's possible ;) sorry for my writing problems ;) i'm from Romania ;) peace
May 8, 2010. 7:02 PMarf200 says:
how many teeth does the sprocket have?
Mar 26, 2010. 12:53 PMZxxxY says:
i have Nidec 50m bldc motor. its 24 volts and 6 amps. can i use it? will resuls be good if i use it?
Dec 30, 2009. 11:44 AMAntleredguy says:
 I was wondering, could this motor work? www.hobbycity.com/hobbycity/store/uh_viewItem.asp Also, would it be possible to design some system where the wheel is directly powered rather than through a chain?
Thanks,
Nick
1-40 of 173next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Vurp
