Check out the Graffiti Research Lab site and watch the DIY Electro-Graf Vid or the G.R.L. flickr group for more on the elctro-graf.
Remove these ads by
Signing UpStep 1Materials/Parts List
PARTS
Part: Super Shield conductive spray-paint
Vendor: Less EMF
Average cost: $22 per can
Notes: this is the secret weapon.
Part: spray-paint, color your choice
Vendor: I use Krylon from the local hardware store
Average cost: $22.50 for 6 cans
Notes: use what you like.
Part: Magnet paint
Vendor(s): Less EMF for premixed indoor paint called Magic Wall or Magically Magnetic, Inc. for paint additive. This additive can be mixed with indoor or outdoor primer sealer.
Average cost: Magic Wall @ $29.95/quart; Magnet paint additive @ $15/quart and primer sealer @ $8.50/quart
Notes: I used Zinnser BULLS-EYE primer 1-2-3 primer sealer for the base paint on the outdoor electro-graf proto. It's the good stuff. Your local hardware store is sure to have a thick outdoor primer that will work. You can get worse paint for less money. Note: Don't believe the hype. The paint itself is not magnetic. It is just metallic and magnets adhere to it.
Part: 10mm LEDs. The color choice is yours.
Vendor: Again, it's my crew Denny, Ann, et al. @ HB Electronic Components.
Avg. Cost: $0.20 per LED
Notes: you can use smaller LEDs, but it's just not my taste.
Part: 1/8" Dia. x 1/16" Thick NdFeB Disc Magnet, Ni-Cu-Ni plated
Vendor: Amazing Magnets
Cost: $9.00 per 100 magnets
Notes: Cost reductions for larger quantities
Part: Power supply.
This will vary based on number and types of LEDs, circuit design and environment. You must supply the LEDs with >= 3 volts DC power. Depending primarily on the number of LEDs, you can use anything from a $2 9 Volt to a $50 dollar car battery to a regulated 500 Watt power supply if the proper current limiting components are used. In the lab I use a regulated DC power supply. We will discuss this more in the following steps.
Parts: Tape
Vendor: your local hardware store should have painter's tape and masking tape. Get both.
Cost: $2-$5/ per 60 yard roll
Notes: 3M painter's tape is blue and has less adhesion than masking tape. Both tapes are useful in different situations.
Parts: 5 minute epoxy
Vendor: your local hardware store should have 5 minute epoxy
Cost: $5 dollars for one tube
Notes: This is some delightful shit. Get the kind in the two part dispenser.
Part: Stencil materials -- Acetate, Manila Folders.
Vendor: Your local art store or office store should have acetate, cardboard and file folders.
Avg. Cost: $10 for a 25' x 12 ft. roll of acetate, folders and cardboard vary in price and is often found for free.
Part: Stranded wire
Vendor: Jameco
Cost: $3 per roll
Notes: any 18-24 AWG stranded hook-up wire will work. Solid core wire is too brittle.
OPTIONAL
Part: 1/4 or 1/2 Watt resistors, the choice of value is yours
Vendor: Jameco
Avg. Cost: $1 for 100 pieces
Part: 3/4" Foil Tape
Vendor: Newark In One
Avg. Cost: $18 per roll
Part: Conductive Epoxy
Cost: $32.00
Notes: The epoxy is optional. It is used to attach magnets to electronic components and wire.
Part: you can add electronic components to create LED sequences, animation, solar power, etc. You may need stranded wire for connecting your LED traces to various power sources.
TOOLS:
a respirator, a mutimeter, paint brushes, containers for mixing paints, exacto blades, clay
| « Previous Step | View All Steps | Next Step » |
I have never managed to get solder to hold to anything outside of copper and the leads of the electronics... I've tried to solder (carefully) to those 3volt button cell batteries and I couldn't get the solder to hold, I have also tried to solder to steel and couldn't get that to work either.
The one redeeming quality to that show! Lol.
2. The Curie Temperature of rare-earth magnets is 500 degrees F. This is the point at which the magnetic field of a magnetic material will reach zero due to heat excitation. The magnetic field will be significantly decreased with temperatures greater than 176 degrees F. Due to the high thermal conductivity and the small size of the magnets, you WILL damage them if you solder using any technique. No soldering technique will prevent this damage. You must introduce heat to the magnet to cause the solder to flow. I will note I have a hand soldering certification from NASA and from Mi-6, which is to say I have a good deal of experience with current materials and techniques.
3. Sockmaster you're beaking rule #2: don't damage the hardware.
(I'm sorry guys, but I just have to post this--meant in fun!--or my head will explode!)
YOU CANNOT DO x.
look! look! i'm doing x!
NO, x IS IMPOSSIBLE.
but i've been doing x for some time now.
YOU ARE MISTAKEN.
(posts picture inflagrante-del-X-o)
YOU ARE VIOLATING THE LAWS OF NATURE (BUT KEEP PRACTICING)
(all humor aside this is still a way-cool project and very inspiring!)
See http://www.maxim-ic.com/1-Wire.cfm for the list of one-wire products. I don't work for Maxim, just thought this would be a nifty addition.
