I looked on-line for what was available that would have some legs to it so I wouldn't have to keep turning the camera on and off all of the time; thus missing all of the great shot. If I had a nickel for every time..........
"Oh son! Can you do that funny thing again so papa can record it on the video camera? Make sure not to hurt yourself this time."
After thinking about it for a while, I came up with the idea of making my own battery!
After reading Tim Anderson's Lost Your Charger? How to Charge any Battery Survival-Style, I decided to make an instructable of how I did it.
WARNING: Just because I have not blown up my camera yet with this external battery pack, doesn't mean you won't blow yours up. If you do create a battery pack such as this, and you do blow up your camera, it isn't my fault! I didn't tell you to do it nor did I twist your arm about it.
Remove these ads by
Signing UpStep 1: Specifications
My camera's external power supply has an output of 8.4 volts and 1.5 amps. Rechargeable batteries put out 1.2 volts. After some high powered calculations, I found that 7 rechargeable batteries would put out exactly 8.4 volts! What luck.
I wasn't too worried about the current output of the batteries. They are 2500mAh and hoped the extra current would not burn out anything in my camera. (So far, so good!)
By looking at the plug on the external power supply, I was able to find the polarity being delivered to the camera. In my case, the barrel is negative and the inside is positive. This is important to know when you wire up your new plug and hook it up to the battery pack.
I also matched the plug from the external battery pack. It turns out that I have a size "H" coaxial.
Visit Our Store »
Go Pro Today »
So there is a real reason for this.
i really dont see how this would ever cause any damage to a camera or laptop that this is connected to
just as long as you don't go too high with the voltage it will be ok
and even if you too high with the voltage,the worst thing that could possibly happen is that the camera will not be able to charge for a few minutes,worst case scenario,the camera blows a fuse on the inside
by the way,i made myself one for my psp,it uses 4 batteries not 8,5.2 volts,instead of neoprene,i used a wall wart(transformer)'s plastic casing,and the cable that i used was the exact same size as the one for the psp's connector!
its working perfectly for me now
i meant to BIG not that
Actually, 2500mAh is the capacity of your batteries.
It means that your batteries can provide 2500mA for 1 hour.
There is no "extra current". Just "extra capacity".
That's the camera who set the current.
If it consumes 100mA, your battery pack will provide 100mA for 25 hours.
If it consumes 250mA, your battery pack will provide 250mA for 10 hours.
If it consumes 500mA, your battery pack will provide 500mA for 5 hours.
The main thing one has to worry about is the voltage.
=o)
That's exactly how I was planning to improve one of my (ugly) instructables (here).
As I did not have access to a battery holder, and as I wanted to make my extra battery pack the cheapest possible and the most compact possible, I used AAA batteries and soldered them together ...
Though, the version 2 I was planning to make was exactly like you did.
You saved my time ;-)
Actually, I don't need to make version 2. You did it for me !! ;o)
An other idea I got (for a version 3) was to make a battery pack wearable like a "life-jacket". =o)
