3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Extremely Easy L.E.D. Installation
This may possibly be the easiest installation of L.E.D. (Light Emitting Diode) Lights in the world, if not THE best. In just a few simple steps, YOU can make a small portable L.E.D. installation that will last for ages! It is especially useful in applications such as remote control cars and small, tight spaces.
Step 1Materials
All you need in this instructable are three simple materials that you will easily find in an electronics store as well as some tools including scissors.
You will need:
1. L.E.D. (Light Emitting Diode) Light
2. 1.5V Button Cell (found in watches)
3. Electrical Tape
16 comments
Jan 14, 2011. 9:31 AMilpug says:
this is just a throwie...
Feb 9, 2010. 7:52 AMjonmhartwig says:
a "throwie" is the same thing only instead of just using electrical tape you put a magnet in with it so you can literally throw the LED and it will stick to a metal surface. a lot of people use this to make light art in down town city areas.
Nov 11, 2009. 9:25 AMSmall Things says:
 Isn't this exactly the same as an LED Throwie
May 26, 2008. 6:41 AMaike says:
how long does the led light in hours? cause I want to get them in my pc case :D
Sep 1, 2009. 8:28 AMcristiSpecialfx says:
Hello there,
if is a good LED , then it might take you 2 ages..about 100 000 h life @ normal power and spec. For an average one , I think about 35 - 50 000 h is a good approximation... We work with Luxeon II LED's, the manufacture gave us a full 3 years warranty ... check out on http://specialfx.ro/html/led_pixel_wall.html something we did with this Luxeon type LEDs... Maybe the post will help.
Best regards,
Cris
Aug 19, 2009. 12:59 PMaleinlegs says:
there is one huge problem to this, you cant turn the light off with out tearing the entire thing apart, or just letting the battery die out!
Aug 13, 2008. 11:52 PMmattccc says:
good job
Feb 15, 2008. 2:16 PMAnkush says:
Wow, simple yet elegant.
Feb 5, 2008. 8:42 AMbduffman says:
o by the way it would be easy to add a switch to throwies just no one dose get led wire then switch then attack to positive side of battary then negative to negative and bam done all u would have to do would be wire negative and wire positive to switch then tape then put it together like normal and the postive wont touch the battary only the tape
Jan 13, 2008. 6:25 AMklee27x says:
Just wanted to point out that the particular battery in your intructable appears to be a 2032 lithium 3V coin cell, or a similar lithium watch cell. A 1.5V alkaline button cells would barely light up a red led for a short time, and would not light up any other color, other than infrared.
Jan 13, 2008. 4:36 AMKiteman says:
As other have said, you've never heard of throwies, but this is still a nicely-done Instructable. We've now had throwies, floaties, sinkies and (I think) blinkies - the next thing that needs to be added to the genre are throwies with switches, or even remote-controlled throwies. Anyone?
Jan 12, 2008. 5:54 PMGorillazMiko says:
Nice job, these are extremely easy to do, they're just like LED Throwies, without the magnet. These are good, but I like to add in a resistor so the LED doesn't burn out.
Jan 12, 2008. 5:53 PMPatrik says:
Also have a look at Graffiti Research Lab's instructable on LED Throwies. Just add a little magnet, repeat a few hundred times, and you're ready for some LED graffiti!
PS: here's the parts list they used, copied from the link above. With the right choice of supplier, they got it down to less than half a dollar per cell:
Part: 10mm Diffused LED
Vendor: HB Electronic Components
Average cost: $0.20 avg per LED
Notes: Cost reductions for larger quantities. Comes in red, blue, amber, white in both diffused and clear. Diffused works better than water clear for the Throwie application. HB has even created a Throwies packs page with deals on 10mm LEDs and lithium batteries!
Part: CR2032 3V Lithium Batteries
Vendor: CheapBatteries.com
Cost: $0.25 per battery
Notes: Cost reductions for larger quantities. With the 2032 Lithium batter, depending on the weather and the LED color, your Throwie should last around 1 -2 weeks.
Jan 12, 2008. 5:51 PMledzep567 says:
silly, theres no magnet involved!
Jan 12, 2008. 5:50 PMthearchitect says:
So I assume the word 'throwies' doesn't mean anything to you?.. :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:hazmatt_05
