3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Firesteel, forged vikingstyle
This Instructable will show you how to make a firesteel. This kind of firesteel was used by the vikings to light a fire. In a later 'ible I will show exactly how to do that. This 'ible will just show how to forge the steel, not how to use it.
Step 1Tools
Tools
  • last photo ←
Tools needed
Hammer- any hammer at around 500g-1000g will do
tongs - you need something to hold the hot steel while hammering it. A smiths tongs is best, but you can do with a welding clamp or any other tongs with a good grip.
Round tongs - To make the eye on the steel you need a round tongs.
Anvil - any small anvil will do, if you don't have a anvil a heavy hammerhead, some railroad track or a flat stone can be used.
Forge - you need some kind of heatsource to heat you steel. I use a reconstruction of a viking forge. But you can build a simple forge from clay. Or use a gas burner.
Bucket of water - To harden the steel you need some water to quick cool the steel.
Angle grinder - needed to prepare the steel before forging
Safety gear
ear protectors and goggles - I use this when using the angle grinder.
To work the bellows it is best to have a slave or an apprentice :-)
http://www.youtube.com/watch?v=vLmFFfZ6lSw
18 comments
Dec 18, 2011. 6:24 PMThe Metal One says:
ok i dont have an actual anvil...i use I-beam steel with a hardened plate welded to the face and sides. how might i accomplish the curves in this piece? build some special extra-large round tongs or what?
Jan 22, 2012. 1:17 PMThe Metal One says:
Thank you kind sir, that helped me tremendously
im about to purchase an old 200 lb upright horn anvil, so the waterpipe bending jig is about to be a thing of the past.
Nov 18, 2011. 3:29 PMvopo says:
I have read that dipping in oil makes it stronger, but you look like you know what you're doing :)
Nov 19, 2011. 8:58 AMshakeval says:
the oil doesn't boil and flash off at so low a temp like water, this also insulates the metal some as all the flashing steam around the red hot metal forms a barrier, the oil has to be shot up to a much higher temp and so disperses the heat out of the metal a lot faster than water, in doing so the metal cools faster and that results in a harder and less malleable metal, will hold a good cutting edge.
Nov 11, 2011. 4:29 PMPfarmkid says:
do you do a lot with the boy scouts
Sep 4, 2011. 8:04 AMjinxleah says:
I need to make one of these! Wonderful 'ible.
Sep 4, 2011. 7:22 AMsplazem says:
Vikings! Metal! Great job!
Aug 29, 2011. 9:15 PMChicken Spit says:
I love the old railroad track anvils. A teacher gave one to me last year and Its been good enough. It sure was fun getting that home on the bus!
Aug 26, 2011. 2:48 PMDon,t try this at home says:
I love all of your instructables do you know when you are gonna post "how to prepare tinderfungus and make a fire The Viking Way"?
Aug 27, 2011. 12:27 AMlennartinstructables says:
excellent instruction! love the foto's! going to try this in my little forge the next time!greetings!
Aug 26, 2011. 9:47 AMVenomousFish. says:
In your next 'ible, please provide instructions on growing a sweet braided beard.
Aug 25, 2011. 5:00 PMstringstretcher says:
Firstly, I love your steels! Secondly, my son was at the Jamboree, and saw this tent! Thirdly, is the steel just held in the fingers, or more like a brass knuckle? And do you strike the flint with the flat of the steel or with a sharp edge? I use a Swedish fire steel, but would love to use a flint!
Forresten, Jag bor i Vasteras! (men befinner mig i Texas for tillfallet... ingen a,o,o!! ) Kul instructable, tusen tack.
Aug 25, 2011. 11:04 AMJobar007 says:
If possible, could you explain how to draw the steel out?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
221
Author:morfmir(Random stuff)
