Fix Headphone broken cable at speaker end (No/low sound from one side) by Medley123
Hey guys i just fixed my headphone witch i thought was forever lost and wanted to share what i did.
The problem i had was that i was getting lower sound from the right speaker, almost minimal.
The cause: The wire got cut in the entrance of the speakers
Solution: Dispose cable section and resolder
[[[WARNING:]]]
Check for guarantee first before breaking it even more!. Im just a simple amateur,  did it because the headphones where cheap and if i broke them it wasnt such a loss.
Youl need a Soldering iron and Electric tape
Step 1: Finding the problem
Ok First we are going to see if we can locate the location of the problem. So that if the problem is in the jack or other place we dont start cutting things unnecessarily.
Plug the headphones and put them in your ears and start wiggling the cable in the red circled areas to see if you can locate where the cable is loose. The volume should go up or down suddenly when you hit the spot
Sometimes you wont find nothing.
steph1978 says: Mar 6, 2013. 9:50 AM
Why electric tape, why not normal tape ?
bo5 says: May 21, 2012. 10:59 AM
wouldn't be nice to put some images up of how its done? As in with knife and solder and stuff?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
