3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Folddown Workbench
Folddown Workbench
I've been plagued for years with a 1 car garage that did not allow space for a workbench.  I finally decided I've had enough and needed to come up with a workbench that would fold away to allow parking of my wife's car, as well as be sturdier than the 2 plastic sawhorses + piece of plywood I've been using.
Supplies:
5 - 2x4’s
22+ – 3” Wood Screws
18 – 2” Wood screws
3 or 4 – Old door hinges
18 – 1” Wood Screws
2 – 3/8”x3 ¾” Bolts
2 – 3/8” Nylon lock nut (Nyloc nut)
6 – 3/8” Washers
1 – 3/8” – Drill bit
1 – 4’x8’x¾” Sheet of Plywood
2’ – Web strapping (or rope to be used for handle)
Tools:
Saw
Drill
Measuring tape
Level
Step 1Dimensions
Dimensions
Determine desired Length and Height of workbench. For the legs of the bench to fold up inside of the table top, your length will need to be at least twice the height plus some.
The Depth of your workbench will need to be less than your Height. (In my case I had to deal with the Footing extending up past the floor so my Depth was 4” less than my Height) If you get your Height just right, your workbench will rest on the floor when it is folded down.
My dimensions: 79” long, 36” high, 32” deep
4 comments
Sep 27, 2011. 1:14 PMYerboogieman says:
Step 1: Tell your wife to park in the driveway.
Dec 23, 2010. 11:06 AMGermy says:
Nice instructable...I recently made a drop table for extra counterspace in my kitchen.
You might add a removable bolt-on-a-string that can be inserted into a second hole through both legs and frame so that when extended, the leg can't be kicked out accidentally and risk your work crashing down. You could then use the same removable bolt and another hole near the center of the frame to lock the leg in when being stored against the wall.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:jooknon
