3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Instant Furniture
Instant Furniture
Furniture that's quick and easy to build out of stuff you find on your island.
I'll be adding to this collection as time goes on.
There are also a few furniture tricks scattered among my Fifty Handy Tricks
Furniture that interests me is usually what Wade Tarzia would call Nomad Furniture
Step 1African Two-Board Folding Chair
These chairs are found all over Africa, at least wherever tourists go.
They're really comfortable, look great, and last forever.
This one is unusually small for the type, but is plenty comfortable.
As you can see from the drawing (picture 4) both boards are 12" wide and 3 feet long.
The slot is 11" from the bottom of the backboard.
The narrow part of the seat board is 4.25" wide.
For more details of construction, check out Jesse's Plank Chair
56 comments
1-40 of 56next »
Oct 19, 2011. 7:39 AMchuckr44 says:
About the 2 piece chair. Is 3/4 inch pine really going to hold my big fat, 180lb butt? Or should I use 1 inch thick oak instead? I'd love to make one of these.
Oct 19, 2011. 6:59 AMEmmettO says:
I didn't know these were also made in Africa. I've always heard of them called "Stargazers" because when you sit back in one you're looking up at the stars. I have also heard of them called "Bog Chairs" because there was one found in a bog up north in europe and that it was made by Vikings.
I make these.
Oct 18, 2011. 4:27 PMdragonsniper says:
LOL video for the cardboard box chair "is that comfortable?... Hell yea" LOL
Jun 12, 2011. 3:22 PMpdub77 says:
What is this type of chair called? I would really like to research it a bit.
Jun 12, 2011. 7:18 AMExocetid says:
liruke gave perfect directions and measurement specs.
A few comments:
The wire is just to hold the initial assembly together to verify everything was cut and drilled correctly. The chair is held together with threaded rod, but might be done with rope or even wire. The stresses are shear except at the ends, but a good knot would do with rope. Rope or wire would give the chair more "give".
The chair is made from 9--1 1/2 x 1 1/8 "sticks" if you go the 2x4 route. Any stick lumber near those dimensions will work. I have an unlimited supply of bamboo, which i plan to make one of these chairs with.
May 16, 2011. 10:24 PMdmarsh55 says:
This is a similar construction to a 'Holy Book' stand I got back in the '70's.
May 11, 2009. 8:49 PMd_oliver says:
Do you have a list of materials? measurements?
Aug 27, 2009. 6:54 PMliruke says:
You start with three six foot 2x4s ( I used pressure treated pine), ripped into nine equal 1 1/2 x 1 1/8 pieces. By judicious measuring, this should yield the following: Seat: (A) 6 pieces 15" long ) each piece has two 1/4" holes (B) 2 pieces 35" long ) drilled in the center of the wider side.Measure from the same end: 1st hole 1 1/2"; 2nd hole 12". (C) 9 pieces 9 5/8" long: Two holes, 1 1/2" from each end. Back: (D) 4 pieces 31 1/2" long) Each piece has two holes, at (E) 2 pieces 29" long ) 1 1/2" and 25" measured (F) 2 pieces 42" long ) from the same end. All held together with 9 gauge galvanized wire.. Align seat pieces as : A-A-B-A-A-B-A-A and hold together loosely at top with a length of wire through the upper (1 1/2" holes); At the lower (12")holes, intersperse each piece with a length of C. That is: C-A-C-A-C-B-C-A-C-A-C-B-C-A-C-A-C. Wire and set aside. Align back pieces in the order F-D-E-D-D-E-D-F, and again hold together loosely with a wire through the holes which are 1 1/2 from the end. Now marry the two parts by threading wire through the remaining holes, with the C pieces acting as the connectors. The new joint should have the configuration: C-F-C-D-C-E-C-D-C-D-C-E-C-D-C-F-C. Draw all wires tight, cut off and secure ends somehow (I threaded them and used cap nuts). Now take it all apart, sand as appropriate, finish as desired and reassemble. Note that this darn things folds too!
Apr 24, 2011. 9:26 AMzanne101 says:
Great project.
Could you explain further, or give a photo, of what you used and how to finish off the wires?
It's probably a "DUH!", but right now I don't know how to do this.
Thanks
Apr 28, 2011. 4:46 PMzanne101 says:
I thought I should expand on my confusion -it's with your statement "It's held together with four threaded rods with nuts and washers on the ends', but later on you say it's all held together with 9 gauge wire.
I must be missing something. :-}
Sep 1, 2009. 2:34 PMclarei says:
Thank you so much for sharing. It is a beautiful chair. Where could I find the specs for this chair? I would like to know how high off the floor the seat is and the instructions can be revised to make it a little taller. Although very comfortable, the pictures seem to show an extgremely low chair. Thank you! cr
Oct 17, 2010. 12:41 AMjoshfromga says:
Mr. Anderson, your Instructables are awe-inspiring. i always look forward to seeing new projects from you. i love the instant cardboard chair! i finally know of someone else who does that. i will certainly be putting some of your ideas to use next time i build up enough motivation to rearrange and downsize my belongings.
Apr 25, 2010. 6:43 AMronnocoman says:
You can simplify construction. Instead of the hole, cut a slot the thickness of the wood in each piece so they slide together like the seperaters in a cardboard wine case.
Sep 2, 2010. 12:39 PMWildrat says:
It will not be near as strong as the authors chair. You may end up with a broken tailbone or more or less.
Apr 22, 2010. 7:22 AMwachi says:
My first laugh as well. Thanks!
Apr 6, 2010. 9:39 AMpinecone89 says:
i've been doing this in my dorm room and a really easy way to make them stay together and stable is zip ties. those little plastic ties that are really cheap and readily available at hardware stores will hold them together even if you load them with books. just put about two to each side through the holes in the sides of the crates
Mar 22, 2010. 7:14 AMsprockette says:
my family created campfire seating out of an old staircase we took off of the cottage...
just sawed it into 3-stair pieces and attached thick planks to the backs and sides to hold it up. it works great.
Oct 3, 2009. 12:30 PMbaneat says:
You say they're sturdy. If they're set up, will a fairly well made one withstand a 70kg man crashing onto it? serious question, because it looks like it would snap at the join
Feb 8, 2010. 11:38 AMashnman2 says:
I made one of these a test piece also out of cheap 1/2 inch plywood. It held my weight no problem. Im close to 200 lbs. I would not use plywood but I had some scrap wood laying around. I am going to make a nice one now with real wood and do some nice wood carving on it,.
Feb 1, 2010. 10:06 AMshnixter says:
i just made one from acrappy woodworm infested plank (prototype version) and it takes my weight just fine - i weigh 16.5 stone , i think thats about 220 pounds? they are suprisingly strong and  again suprisingly comfortable!
Oct 3, 2009. 12:32 PMbaneat says:
I mean the african chieftain chair
Oct 24, 2009. 4:22 PMeulaliaaaa! says:
I saw this in National Treasure!
Just saying.
Aug 22, 2009. 3:51 AMTurnpike7a says:
measurements for the base pieces?
Aug 22, 2009. 3:53 AMTurnpike7a says:
i have one of these chairs, everyone in my family fights over who gets to sit in it
Aug 22, 2009. 3:46 AMTurnpike7a says:
There is a debate weather or not vikings used this style of chair as well
Jun 29, 2009. 10:04 AMRHeimpel says:
http://www.popularmechanics.com/home_journal/workshop/4226197.html
This style is a benjamin franklin library chair, plans at the link above
Jun 12, 2009. 8:24 AMellendxyz says:
My first laugh of the day. Thanks!
May 7, 2009. 8:39 PMpea_jay says:
For everyone looking for plans for the ladder chair: There's a plan on the Popular Mechanics site for the ladder chair (Step 10). I saw it a couple months ago.
link: http://www.popularmechanics.com/home_journal/workshop/4226197.html?series=20 (or look for the 3D workshop).
May 11, 2009. 10:57 AMhxh103 says:
awesome, thanks for the link Also, for anyone building the two-board chair, make sure to get hardwood
May 4, 2009. 8:40 PMhxh103 says:
I want that ladder - chair sooooo bad. I can kinda guess what I will need to make it, but are there arny plans/measurement to work with? That would be awesome if it's out there somewhere...
Mar 30, 2009. 3:43 PMforced_to_make_an_account says:
Is there a picture of the chair folded up?
Mar 21, 2009. 10:34 AMfreakmarks says:
do you know if this would work with masonite boards?
Jan 27, 2009. 1:49 AMsensoryhouse says:
i made this video on mid-century modern design (Eames Era)
Jan 17, 2009. 7:09 PMspanky62 says:
I think I found acpl, of those chairs by drunken mistake 1 time after moving , very comfy .LOL, good job . I needed a laugh , thanks
Nov 15, 2008. 7:33 PMbobbyjkl says:
Can you post more on 10? Blueprints, etc would be helpful
Oct 31, 2008. 7:51 PMscafool says:
Actually a library chair. Something to sit on as you read, after you got that rare book down from the top shelf. I think it is an English design. They are still made and the mass produced version sells for about $150.00.
Sep 25, 2008. 6:05 PMPumpkin$ says:
lol i made a lean-to, with a poker table, and chairs out of............................................ FIBERBOARD!
Sep 6, 2008. 1:27 AM12much says:
There's one on the deck from a houseboat along the way walking from trainstation Amsterdam, Holland to Sience Center NEMO. I love the simplicty.
Aug 26, 2008. 5:51 AMporkdemon says:
i work on a packing bench and theres some great makeshift furniture there, theres cardboard boxes taped together with chipboard tops, theres shelves made of cardboard, its awesome.
1-40 of 56next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
