Here's a video of it in action. They're tricky to capture video of (particularly when using a cheap digital camera), but it gives you a rough idea:
This is an incredibly simple project to put together, thanks largely to the LEDs: I use RGB LEDs with color-changing circuitry built right into the package. You just provide power, and the LEDs cycle through red, green, blue, and various combinations thereof. One aspect of these LEDs is that the timing is slightly different in each one, so while they start out in sync, they quickly fall out of phase. I consider this a feature, not a flaw, as it results in the emergence of interesting, seemingly unpredictable patterns.
No soldering is required, just some crimping and a bit of hot glue.
The parts are easy to obtain online, but I also offer kits through Make Magazine's online store, the MakerShed, for $15:
http://www.makershed.com/ProductDetails.asp?ProductCode=MKKM2
Remove these ads by
Signing UpStep 1Parts and Tools
The screen: I used 4 x 3 piece of scrap translucent white plastic. Velum from the paper department of your local art store works perfectly as well.
5 x 4 matboard frame with a 2" x 3" window: You can get a piece of black mat board cut to these dimensions in any framing store for a few bucks, or cut one yourself from suitable material, such as stiff black cardstock.
Battery case for 2 AA batteries w/ wire leads and power switch: These can be purchased online from Jameco, part #216120, and can likely be found at Digikey.com or Mouser.com as well. Similar battery holders can also found at Radio Shack, but you may have to solder a simple power switch into the circuit yourself.
3 RGB color-changing LEDs: I get these here: http://stores.ebay.com/Amigo-Of-China. Look for "5mm RGB LED Slow Colour Change." Make sure you get the clear ones, as the diffused ones don't work as well for this specific project (but you can do other cool things with them!) Everything on this store seems to come with free resistors, which you don't need for this project, but hey, free resistors.
2 butt splices: (tee hee... butt splices). These can be found at Radio Shack; something in the range of 18-20 gauge or thereabouts works well. I use the non-shrink-wrap-coated ones, but the coated ones should work fine. You can also get these from Jameco, part #494469, but the minimum order is 100.
Also shown in the picture: Glue Dots. These come with the kit, and are used as an alternative to hot glue to attach some parts together. These can be found in a craft supply shop (you should get the largest, tackiest (stickiest) ones they have), but a hot glue gun works just as well for these steps, and is nice to have anyway when it comes time to "customize" your LED artwork.
You will also need 2 AA batteries, and some scotch tape.
TOOLS (not shown)
Needle-nosed pliers
Wire clippers and strippers: these may be needed for cutting and trimming the wire leads on the battery case.
Scissors or similar cutting implement if you are going to cut your own screen or mat board.
Hot glue gun: As mentioned above, glue dots can be used instead of hot glue for attaching some parts, but the glue gun is useful for the optional (but highly recommended) step of customizing your artwork.
maybe i will do it
