3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Free Air Conditioning
Technically it should be called a heat exchanger, we lovingly call it the water cooler, but it has been providing us with free cold air for more than 20 years now so it definitely does work.
Shortly after moving here (Montana) I noticed that the water from our well is really cold, under 50 degrees. I built this heat exchanger to take advantage of that cold source for use in the house in the summer and as a byproduct it heats up the water going to the garden a bit before it goes on the plants since the plants didn't seem to care to much for the super cold water. Good benefits all the way around and since I would be pumping the water to water outside anyway the only actual cost is the power to run the box fan that moves the air through the copper piping.
How well does it work? We hit a high temperature in July of 112F, hottest that I can remember. The temperature inside was 76F with the cooler running all the time. I almost didn't want to go out to move the sprinkler.
The disadvantages? Well, you have to move the sprinkler a lot, but it does keep the grass green. Also if the humidity gets high, water will condense on the exchanger the same as on a glass of cold water. So I keep towels underneath it to soak up the moisture. If it gets really muggy I have to change the towels several times a day. I just hang the wet set outside in the heat to dry and rotate the dry ones back under the cooler.
It will take some skill to put it together but once done it is maintenance free, except for the time I left it outside before putting it away for the winter and it froze some leftover water in a pipe and broke it. Make sure to get the water out of it and store it where its above freezing.
Another disadvantage, it isn't pretty, but it is unique and truly "green".
Step 1Check your water temp
check your water temp
For this to work at all you need to have cold incoming water. The colder the better. Get a standard waterproof thermometer and run your outside water for a while and find out what temp it is. This probably will not work in places where you have a municipal water supply unless its from a cold source. Also you need to have enough ground to water so you don't water log your garden and lawn. It will probably work best in rural areas.
With the fan turned off and the water running outside the temp of my copper pipe is 48F (Infrared non contact thermometer reading)
307 comments
1-40 of 307next »
Feb 21, 2012. 8:30 PMtinker234 says:
wow could you use painters tarp for the water leaks in case
Sep 27, 2011. 7:04 AMspafford says:
My question is ... How warm is the water when it reaches the garden? Is the hose laid on the ground after it leaves the cooler(which would make the water hotter)? I was just wondering the temp of the water that is coming out of the "cooler" as to determine if all the "coolness" is extracted from the water. I guess ideally you would only want the coldest air extracted but if the temp on exit is still the same more air flow and a larger "Radiator" could really make cold! Of course, flow rate is a major factor and I wanna couple this with drip irrigation and a large GARDEN :) This is an awesome idea! I had thought about it, but had not put it to work. Much praise 'ol mighty inventor, people such as yourself are the last line of defense in energy corruption.
Jul 11, 2010. 8:31 AMBonzoix says:
For those without a well, couldn't we dig a field in the backyard to run lines through to recool the water to ground temp? Like a DIY geo-thermal A?C unit? Then we would need a pump or an impeller driven by the same motor as the fan... Love the instructable.
Sep 27, 2011. 7:08 AMspafford says:
I think that is an excellent added addition! I think a key I would like to add is to make sure the water remained bacteria free.
Jun 7, 2011. 9:39 AMivelknuf says:
Quick question. It seems you have your "air conditioner" loop connected to the pipe that goes to the exterior faucet(s). Have you thought about connecting it to the main inlet to your house? That way, no matter what your water usage is, the air conditioner will be receiving "coolant".
Aug 21, 2011. 9:36 AMjohnny3h says:
@ Vyger. I STRONGLY SUGGEST that you DO NOT use the TREATED domestic water for your irrigation AND/OR air conditioning as POTABLE water from a domestic system IS VERY EXPENSIVE.
I would use the domestic supply for drinking, cooking, bathing, laundry, etc.
But CONTINUE YOUR WELL OPERATION for a few reasons:
1. In the event of failure of the domestic municipal system your well would be a good emergency back up.
2. In our area [SE Texas} a disused well will "silt in" and become totally unusable, AND COST A SMALL FORTUNE to have it "redrilled."
3. In Texas, due to deteriorating underground aguafer water availability, there is talk of a "freeze" on the installation of any new wells, which means that only those with existing wells will be able to use the underground aquafer water, and thus be FORCED to use the EXPENSIVE TREATED municipal water source(s). So since you have the well established, I would keep it operational.
Jun 14, 2011. 10:40 AMjohnny3h says:
Using TREATED, municipal water IS VERY EXPENSIVE and wasteful of a limited resource. The municipal systems are for POTABLE drinking, cooking and bathing water and such one-time cooling use of that water would be VERY UN-GREEN.
After going on the municipal system for your potable water, CONTINUE to maintain your well and cooling system, AND also use it for ALL IRRIGATION [lawn, garden, etc.] as that will be MUCH LESS EXPENSIVE, and will not tax [overload] your municipal, potable water system. This protection of the capacity of a municipal potable water system is CRITICAL in periods of draught, when most municipalities enact ordinances to RESTRICT water use so they can keep up with damand so that EVERYONE can have potable water.
Aug 23, 2007. 4:20 PMRONE says:
I can't tell which direction you have the water flowing (through the exchanger closest to fan first or last) or which way you have the fan pointed (blowing through the exchanger or sucking through the exchanger), but I wanted to make a note of the most efficient way for the water to flow: Have the coldest water (straight from the well) flow through the last exchanger, and the warmest water flow through the first exchanger - I am using "first" to refer to the first exchanger the air would move through, and "last" to refer to the last exchanger the air would move through. The idea is to set up a counter-current mechanism, just like fish use in their gills for O2/CO2 exchange and all male animals use in their testes to transfer heat from the artery to the vein prior to the blood entering the testicles to keep the temperature lower. Great instructable, by the way!
Aug 21, 2011. 10:50 AMjohnny3h says:
@ RONE.  It's been something like 45 years since I took college Physics, but as I recall, what you are describing is based on one of the principles of Thermodynamics that says something to the effect that, "the greater the DIFFERENCE in temperature, the more RAPID the transfer of heat."
So, yes, I think your suggestion of "counter-flow" would be the better approach.
Jun 12, 2011. 11:23 AMtriumphman says:
I tried to make a wood stove hot water pre-heater like your design, with baseboard tubes. But the elbows were too close to solder. One joint would un-solder when I tried to solder the other side. How do you solder the elbows so they won't leak???? Help!!!!
Aug 21, 2011. 11:05 AMknthms says:
wet rag over joimt to not be soldered
Jun 14, 2011. 10:33 AMjohnny3h says:
I've had this issue before, and the "trick" is to carefully clean and prep ALL surfaces in those two connections, including proper fluxing.
Then preheat the entire section uniformly [requires practice and developed skill] and then when preheated, quickly apply the solder to sweat each joint "almost" simultaneously.
Again, this proces is like walking what in the circus is called a "slack rope," which is difficult but not impossible.
Jun 17, 2011. 8:26 AMtriumphman says:
Yes, I can solder a nice single joint! Its called "sweating" by the plumbers. Shiny & clean copper is the key too. I love it when you get the joint just the right temp. and the solder almost sucks- flows magically into the spaces between the pieces ! What kind - brand of flux do you use?
Aug 21, 2011. 9:23 AMjohnny3h says:
@ triumphman. Sorry, but I'm not where I can check the brand name, BUT... it is a common paste type flux for sweating plumbing that I got at my local [SE Texas] hardware store. It comes in a round blue colored can about 1/2 inch deep by about 2 inches in diameter. Over the last 55+ years I " think" I've used about 2 1/2 cans as "a little bit goes a long way."
Since it is NOT an acid based flux, I use it for all my electrical and electronic soldering also.
Mar 17, 2009. 8:58 PMJollyrgr says:
An idea to add to "The Lightning Stalker's" suggestion. Why not add a water pad like those found in swamp coolers? Use the waste condensate collected in the pan to wet the pad. Simply place the pad in the collection pan so that it wicks up the water and is evaporated.
Aug 21, 2011. 10:39 AMjohnny3h says:
@ Jollyrgr.  Yes, that could be done, BUT... evaporative cooling INSIDE the hyouse would increase the relative HUMIDITY, AND as a result, add to the cooling load, and the evaprative cooling water vapor CONTAINS the heat removed from the air.  Eventually, you would reach an equilibrium temperature HIGHER than if the condensate water were totally REMOVED from the house.
ALSO, the less humidity in the interior air, the "cooler" one will feel because the lower humidity will enhance the evaporation of body moisture [persperation/sweat] which occurs ALL THE TIME, regardles of ambient temperature, especially in summer, but even in the winter.
Aug 16, 2007. 6:48 PMdan says:
you should be able to recycle a radiator from a junkyard car for this, that would be already made in a good size and shape.
Aug 21, 2011. 10:18 AMjohnny3h says:
AND, if one is lucky, it will have the plastic FAN SHROUD [to maximize the efficiency of the fan] AND maybe even an electric fan! With this set-up all one would have to do is provide a 12 volt power source of the right current capacity!
Aug 24, 2007. 6:02 PMdan says:
ooh, thanks for the info and good point about the water pressure for a house-integrated system.
Aug 19, 2007. 1:51 AMironsmiter says:
if you can find a "scrap yard" instead of a parts yard... buy the car radiators, fanshroud, and electric fans from 2-3 cars. DON'T take any out of any geo metros. i know they're JUST the right size, are plentiful, cheap as dirt, andeasy to remove... but my "new" 96 metro @48MPG may oneday need THAT radiator. automotive radiators, with their shouds, tend to be more efficient at heat transfer as an added bonus. Where I am, we have our 114 year old, hand dug well AND city water since the watertable is too poluted with pesticide runoff from Chem-lawn.... And we have the old septic field that hasn't been used in an eternity either... An idea would be... Solar cell->wellpump->radiator/fan->fishpond areator head->septic tank/leech field. Hmm. wonder how much a solar cell, capable of running a 1/4HP well pump would be :-)
Jul 10, 2010. 3:51 PMshortw says:
To run a 1/4 hp motor you would need about a 400 watt solar panel that charges a battery. 1 hp = 756 watts, but on motors that is output , not input. motors have a efficiency of 80%. Also motors require 4 to 10 times the power rating on the name plate of the motor for start-ups
Aug 27, 2007. 12:19 AMPrometheus says:
I have to disagree that car radiators are better for this project as they are not designed to disperse as much heat as the one used here. Also used radiators may be clogged and are automatically contaminated to non-potable-levels, especially junkyard ones. If you had a radiator from a car that had cracked a head or the block, you might be adding petroleum to your list of chemicals that the radiators would leech back into the groundwater when returned to a garden as Vygar does. A typical solar-cell capable of running a typical 1/4hp DC motor would run you about $700
Aug 23, 2007. 4:27 PMTheRevJester says:
Glad to see there's also a fan of the Geos. Screw hybrids. I'll get 5 early 90s Geos and be guaranteed to get at least 1.5 million miles out of them. No battery replacement either!
Aug 22, 2007. 7:21 PMpedxing says:
.25 hp = 186.424968 watts according to google calculator.
Fairly significant, since an 80W panel is quite large.
Nice thing is, you won't need to run it unless it's quite sunny.
How about Solar Cell->well pump->radiator->elevated holding tank
Then drain the tank back into the well at night.
This way you can keep it running, without worrying about running your well dry.
Jul 10, 2010. 4:01 PMshortw says:
Remember, .25 hp is output not input. Solar panel is rated at best output at best conditions at the best time of the year respecting the angle of the sun . Inverters and charge controlers itself eat up power too. And most of all, a lot of losses will be encountered with the battery.
Jul 22, 2011. 1:59 AMOle bally says:
Just thinking...you could use the bottom of beverage cans punched through for your fins!
Aug 21, 2011. 10:12 AMjohnny3h says:
I've always gotten all of the "radiators" I've needed from window air conditioner units discarded at CURBSIDE. Also I've gotten some from discarded compressor/condenser units for whole-house systems, also discarded curbside.
For over 60 years I've been a curbside "recycler," and when living in the "big cities," a "dumpster diver!" LOL. Over the years I've probably "salvaged" MANY THOUSANDS of dollars worth of good, usable "stuff."
It is absolutely incredible what "some" people throw away!!!!!
Aug 4, 2011. 5:58 PMlloydrmc says:
Fantastic! Simple, elegant, effective. Bravo!
Jul 26, 2009. 2:15 AMdominoe says:
coudnt you just used a flushed out car radiator and it would be lighter?
Jul 31, 2011. 7:18 AMjj.inc says:
If you find one that supports the flow that this one does. Which I think you could, then you would also want to double up probably because this one is extremely thick.
Jun 20, 2011. 10:42 AMswpayne says:
Have you thought of adding a tray for the cooler to set in? You could plumb the tray to drain outside the house and not have to switch out towels throughout the day.
Jun 20, 2011. 10:09 AMilpug says:
this is great. heres a simple solution to your condensation problem: get a tub or something and build it onto the bottom of the unit, so the water will leak into that.
Jun 12, 2011. 11:19 AMtriumphman says:
Looks like mankind in Colorado is screwing the people out of their God Given Rights! Anytime I see or hear a story about a Town Government is that they take your taxes and stick it to you. So you are paying to get scr----! My town (NE N.Y.) just decided to stick it to us again! They keep raising our taxes and their salaries but decided to close the Town Hall on Fridays to save themselves money. So all the services we pay for is cut by one day! Nice huh? Yet, if I want a dog, I have to pay them for a license (every year) , or build a shed or doghouse, pay for a permit, they are SOB's, I'm trying to be kind, why I don't know! We need some more Tea Parties folks!!!!
1-40 of 307next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:Vyger
The name comes from the First Star Trek movie, that pretty much says it all.
