Free Energy From Thin Air!
83,246
1,082
226
Posted in TechnologyScience
Introduction: Free Energy From Thin Air!
About: I am a tech maniac; from media, marketing and design to alternative energy and more. Check out my website for links to all my projects.
"Free energy from the air?, Yea, right!" Sardonic skepticism was my first reaction to this unusual concept, as well.
Though, its not so far out there, in fact. Light can be converted to DC current with solar panels, electricity can be converted to magnetism as I did in my last article, in a microphone sound waves are converted to an electrical signal (by vibrating a magnet near a coil), solar rays can even be focused and converted to heat in awesome devices like this! When we think about it, energy is all around us and can be harvested in an enumerable many of ways.
Today, we are going to take a rather novel approach. We are going to build a device specifically designed to sense and capture a particular band of energy which is all around us.
The earth is magnetic and anyone who has ever used a compass knows this. Magnetic bodies in motion produce electricity, we can see this in any alternator, like the one in your car. So, therefore the earth is electric as well as magnetic, by definition.
Can we detect this energy? Yes, we sure can! Ever turn on a radio in the middle of nowhere and heard static? That is your radio picking up naturally occurring energy in the RF spectrum!
Can we use this energy to do work? Absolutely! This has been known for a long time. Crystal radios have been around since before the 1930's and can run with no input energy other than the radio signal. Even when completely isolated, but from the atmosphere, a crystal radio will produce a voltage in the earpiece resulting in a sound (albeit and undesirable one).
Well, this is where it gets interesting...
Can we replicate this effect? Yea, and with modern components like the high quality crystals found in germanium diodes, we can even increase efficiency. By applying this concept as a Crystal Energy Receiver we can take advantage of a wide range of energetic frequencies rather than tuning in to just one.
Can we scale it up? Definitely. Things like micro germanium diodes, high efficiency antennas and compact contemporary capacitors make the components that are required to build a crystal receiver fit in the palm of your hand. While there may or may not be a more efficient way, this renewable energy solution is simple to employ and can be scaled up, or down, indefinitely.
It sounds like we can build a Crystal Energy Receiver. Let's give it a shot...
Step 1: What You'll Need
One of the reasons this particular renewable energy harvesting method is so viable is the relatively few and easy to obtain materials required.
The simplest crystal receiver design needs no power and can be built with only three parts: a coil, a crystal and a resistor. We're going to optimize that design in order to produce a cleaner and more reliable output signal by first polarizing the input amplitude, then rectifying and filtering the signal. Then we'll add an antenna, case and connections.
Get the circuit diagram here
Get the kit here
The parts for the circuit include:
(1) Circuit Board
(1) 10-18 gauge Copper Wire
(2-12+) Ceramic Capacitors (matched)
(2-6+) Electrolytic Capacitors (matched)
*note various types of capacitors can be used
(4) Germanium Crystal Diodes (1A+)
Total Unit Cost: +/- $0.40 (USD, scaled for volume of 1,000+ units )
In addition, you'll probably want to get:
(1) Project box (optional)
(1) Antenna (a loop antenna or elevated antenna is recommended and can be made with copper wire)
The tools you'll need are:
Soldering Iron/ Solder (optional)
Multimeter
Oscilloscope (optional)
That's it. Yup, that's all. Once we've got it all, let's begin.
Step 2: Build the Circuit
We're going to build the simplest version of this circuit variation in order to understand how each component interacts and as a proof of concept.
There are three simple systems at work in the circuit that are composed of capacitors, which store energy, and diodes that direct it.
Energy in the band of radio waves, among others, will vibrate a wire antenna on an atomic level, sending a discernible signal to its lead. This signal will then meet the junction between two ceramic capacitors wired in series. This junction will force positive charge from the wave to travel in one direction and negative charge in the other direction which, when collected again, makes the signal uniform and polar. Connecting the two capacitors in series creates leads on each end; the now positively charged side of one and the now negatively charged side of the other creates a two cell battery.
This next stage of the circuit takes a signal with a net value of zero, adds the absolute values of the positive and negative amplitudes with respect to the origin and produces a positive integer. This concept can be thought of as taking:
(+1) + (-1) + (+1) + (-1) = 0
and converting it to:
| [(+1) + (+1)] | = 2
| [(-1) + (-1)] | = 2
= 4
Isn't math fun?
To each of these leads from our two capacitors in series, we will connect two crystal diodes, one facing each direction, to form what is called a bridge rectifier. A bridge rectifier is a configuration which will convert an alternating current to a direct one by cleverly rerouting the signal.
By connecting the bridge rectifier as shown in the circuit diagram, this direct current from the diodes then charges the electrolytic capacitors. This stage normalizes the amplitude, making the current constant and usable.
Components can easily be twisted together for testing and then soldered to a circuit board to secure.
Step 3: Test and Optimize Your Circuit
To test and analyze our circuit, we'll be using a digital voltmeter and oscilloscope.
By connecting a voltmeter to the output, we'll immediately begin to see a small voltage climbing in the 10-100mV range. If not, we'll want to check our connections and make sure the circuit is not isolated from the environment by taking it outside to a clear area.
Then, by connecting an oscilloscope to the outside leads of our two ceramic capacitor bank, we will see the the polarized signal being captured from the air around us. We can then connect after the diodes to see our varying direct current and then to after the electrolytic capacitors to see a normalized, usable direct current at our output.
We can then optimize the input resistance in two ways. Firstly, we can add additional ceramic capacitors in parallel to our original two and make sure our soldered connections are consistent and thick in this area.
We can optimize the circuit's capacity by adding electrolytic capacitors in parallel to our original two which will allow this circuit to charge slightly when not in use. For this purpose, a charging circuit can also be added here in order to incorporate an optional battery bank.
We can optimize the antenna by attaching loops and coils of copper wire in various positions, store-bought antennas or by stringing some wire up to the highest point you can reach.
We don't have to stop there, either. We can now connect multiple circuits in series to increase voltage or in parallel to increase current. This can be done indefinitely.
Step 4: Add a Case and Antenna
After choosing an antenna in the last step we'll now want to permanently wire it. Whether you choose a compact antenna for portability or a tall fixed antenna for power and range, we will wire it in the same manner according to the diagram in the previous step. Note that the input on the configuration here is grounded to the metallic case, and thus the users hand, and incorporation of longer antennas will require proportionally more substantial grounding.
We will then attach a terminal to the output to allow us to connect this circuit to an electrical device or charging circuit and battery bank.
Next, we will add a case, making sure to isolate exposed leads with non-conductive material especially if mounting in a conductive case. A piece of cardboard secured with glue is sufficient for the circuit's bottom and shrink wrap or electrical tape can be used in the case of any additional exposed leads. Drill two holes in your enclosure, one for the antenna or antenna lead and another for your output terminals. You can then insert your components, fasten the enclosure and your device is ready to use!
Step 5: Your Crystal Energy Receiver Is Complete!
Your Crystal Energy Receiver is now complete and ready to use!
I built a portable version, for proof of concept and demonstration purposes. However, you can go as big as you want- to passively charge batteries or run equipment remotely; or go as small as you want- to power sensors, RFID devices, small electronics and more.
I used this harvested energy to easily power a low-consumption quartz clock, a digital chronograph with integrated circuits and LCD and was even able to momentarily rotate a small dc motor.
Because of its simplicity this device is a durable, efficient and reasonably effective method of harvesting radiant energy in a simple, replicable and sustainable way. I humbly hope that the contributions made here, and by those reading, can be one day used by people worldwide to conveniently capture free energy.
Thanks for checking out my project and I look forward to seeing everyone's variations, suggestions and improvements!
  • Casting Contest
    Casting Contest
  • Make it Move Contest
  • Microcontroller Contest
6 Questions
i have a question so if you have a piezo film and you vibrate it using a magnetic beam will it create enough energy to charge a phone.
Interesting question!
Piezoelectrics is another fascinating way to generate electricity. A piezo film can generate electricity from movement alone. However a typical piezoelectric generator generates a mere 5 mJ of energy. (5.28mJ)
An iPhone, for example, has a battery capacity of 5.45 watt hours.
The 5.28mJ output of a piezo converts to 0.000001466666666667 Wh.
That means it would take one piezo 3.89 million hours to charge a phone, or it would require 3.89 million piezos to charge a phone in one hour.
Cool idea but probably not the most efficient solution. Thanks for posting.
Give this project a try. It may be a more effective solution and you can get a parts kit here:
http://drewpauldesigns.com/crystal-energy-receiver-kit-2/
is it possible to shrink the size of the model down to a phone case and if you dont use an antenna can it still collect RF waves and then use a volt booster to boost it up to somewhere around 5 volts and can charge a phone and if i have the antenna in plastic can RF waves go through plastic
Yes, absolutely. The circuit can easily be miniaturized however to achieve the output of 5v needed to charge a mobile device, you would need an antenae that is quite large.
what amount of volts would be neccesary to charge a smart phone
Ηello. I would like to post a question. I was getting 1.5volts steadily, from one capicitor and then it dropped to 0.100. The antenna was in the same place!
Thank you
For your biggest setup you have made so far, what was the maximum output in watts? (ignoring any sudden peaks is wattage)
@DrewPaulDesigns: Thank you for answering so quickly. A couple more questions:
1. Are you situated close to overhead powerlines?(like in a city)
2. How does antennae orientation effect the power output(vertical vs. horizontal)?
3. Are you saying that it is receiving natural EMR, artificial, or a mixture of both?
Thank you for the interesting 'ible, it sounds fairly doable and worthwhile.
1 more answer
Due to the power condition feature of the capacitors, output is typically normalized. The highest output I have produced o this scale, though, has been in the area of 10-12V, 10-20mA.
can i use your model for a project im working on that i will sell
it is a smaller model using the same mechanics but is a phone case and can be used to create energy to charge the phone using alternate energy resulting in less pollution caused by phone chargers it is just an idea i guess
Cool! What type of project are you working on?
226 Comments
Thank you for sharing the Instructables. I followed your circuit diagram, but the maximum voltage I got is only 0.5mA. I'm not sure what I can do with this tiny amount of voltage. How much voltage does the clock need? Any recommendations what I could do different to harvest more energy?
http://yeseul-itp.tumblr.com/post/172782433467/har...
1: what rating capacitors (ceramic)?
2: what rating capacitor (electrolytic)?
3. why both types of capacitors and not one type?
4. You've mentioned grounding to earth, but where is the grounding line?
5. Looking to make this a kids' project to charge a phone so expanding these size isn't a problem at all.
Thanks for checking out my project. A lot of these questions are covered in the Instructable but I will answer them briefly for you.
The ceramic capacitors used are 104s and their purpose is to polarize the charge. Electrolytic caps are 50v rated and are used to hold the charge in order to provide a usable current. In this example the ground is connected to the case, and thus grounded through the users hand. Scaling this up for that purpose will require a more significant antennae, ground and wiring up multiple circuits in series which is covered in more detail in the article.
Let me know if you have any other questions and be sure to post your project pictures here when you're done for everyone to see!
can is use your model for a project im working on
Hi Drew,
I looked through your website, and I was thoroughly impressed with your drive to create innovative projects.
I had one question about this project - what is the frequency range/rating of the antenna that you used in steps 4-5? I couldn't find it in the Instructable, and I'm sure a few others would be interested in the characteristics of the antenna used as well.
Thanks in advance, Rob
http://is.gd/aerialpower
Can you ship to Hong Kong when I bought it? How can I contact you?
http://is.gd/battchar2
http://is.gd/portablebatterycharger
Hey,how much maximum voltage can be obtained at the output by adiing capacitors in parallel....????
Thanks for checking out the project. Great question. Adding capacitors will only increase the capacity (mAh). If you want to increase voltage you can build multiple circuits in parallel and make sure your antennae is as tall as possible.
I dont want to place my antenna on roof top.I want a min of 5 volt and max of 20 volts and a portable circuit.So what shud i add to the circuit for getting it.??? and what kind of antenna shud i make..??
Can u please send me a video of how your project is working..??
sir, why the first kit show value 0.75v and the second kit show value 3.50v,
what is different make? (coil turn, coil component, total component, etc..)
What a nice instructable! But I have few questions though, if you don't mind.
How long did it take you to complete the project?
How much did it cost you?
Would it be realizable for the duration of one month only (for a beginner)?
And most of all, Could you tell me about the output (after testing)?
Thank you :)
Thank for checking out my instructable! This project can be done in an afternoon and the kit can be found here: http://www.drewpauldesigns.com/crystal-energy-receiver-kit.html
Before getting started you will also want to get a soldering iron and take some time to practice with it.
Just follow the instructable carefully and you will have no problem.
You can get everything you need here: http://www.drewpauldesigns.com/crystal-energy-receiver-kit.html
Thank you, I can't wait to start it :)
But before, I just want to know the testing result (voltage, current...)
So cool, right? Give it a try! Its easy, fun and the results are astounding!
