Simple, turn it into something you can heat your house with, firelogs.
Materials and Tools
1. Russian Thistle, about 1/2 cubic yard of freshly pulled will be enough for one log when its dried
2. Shredded paper from your shredder, any other type of cardboard or cardstock. The residual ligin in the paper helps bind the log together.
3.A 5 gallon plastic bucket and water
4. A plastic flower window box as a mold
5. An electric drill(1/2") with a stucco mixing paddle.
6. A piece of plywood that fits over the top of the window box
7. Cinder block
(Optional)A garden chipper and wheat paste .
Free Heat.pdf(612x842) 88 KB
Remove these ads by
Signing UpStep 1Do the Crunch
Large wood gasifier
I'm sure it would burn this material. Look into briquetting or pelletizing.
Oh and Peguiono don't forget solar energy.
Coal is carbon-positive as it's a fossil fuel, whereas these plants took their carbon out of the air so are more or less carbon-neutral, but burning sun-dried plant matter can release more smoke, particles and other airborne nasties than coal. Think of the difference in the smoke between a bonfire burning garden waste, and a charcoal barbecue with no food on it yet.
Which is "better" is entirely subjective, and based on your priorities. This fuel is more renewable than coal (it seems to renew itself without being asked!) but is worse for local clean air.
I've always wondered if a field full of a crop like this (fast-growing burnable biomass) could power a CHP stirling engine, letting you go off-grid using only your weeds for fuel. Of course, you'd need a field of biefuel crops to fuel the tractor to harvest the field of thistles, and then....
There may be super high tech artificially aspirated furnaces that burn extremely hot and reduce the soot-type pollution from burning plant matter, though, which would be even better.
As an additional note, there has never been a serious problem with any nuclear power plant where basic common sense and safety protocols were followed.
Chernobyl...don't get me started on the idiocy that caused that disaster, there are just way too many levels of wrong that went into causing that.
Japan...who in their right mind would put a reactor on a fault line, in (or out of) a highly seismically active area? You're just asking for a containment breach at the bare minimum.
Three Mile Island...not a disaster-you could have camped right outside of the plant for the entire leak and not have had any problems. Yes, a large number of "radiation sickness" cases were reported...but NO deaths. Initial signs of radiation sickness are indistinguishable from the common flu...but you DON'T (or very, very rarely) get better. If you were to do a statistical analysis you'd find that the number of "radiation sickness" cases were no higher than the number of people in the same given population that would have had the flu. This was a classic case of jumping to conclusions without having any (much less all) of the facts.
Sabotage/terrorism *IS* a valid concern currently as a successful strike could create a second Chernobyl and that alone in my mind would be enough of a risk to limit nuclear power use as local populations densities would probably be much higher than those in Prypiat. The fallout both literally and globally would be nasty.
regardless of safety and spent fuel re-processing in modern reactors (which are few so far), it still takes a hell of a lot of fossil fuel to run a reactor. it's not truely "clean" yet. Problem not solved. yet.
Radioactive means its emiting radiation, that makes it not waste in my mind, but useful, some (plutonium) can be reprocessed into new fuels, and I do not get why for the rest, if it is radioactive why they cannot harness that power rather than bury it?
Stop calling it waste an use it.. what the US does with its nuclear by products? encase them in glass and bury them, not even reprocessing the plutonium!!! how dumb is that? (very since its done in the rest of the world, I think japan even ships it to the UK to be reprocessed, well last time I looked).
The fact is nuclear power is here to stay, and if done right, waste is negligable.
Sorry but I do think many people are mislead when it comes to nuclear power, they do not understand it so they fear it because of the waste....
