GARAGE STORAGE SOLUTION
CEILING TOOL STORAGE, USING HINGED PANELS AND PULLY TO SECURE TOOLS OUT OF THE WAY IN CEILING.
Step 1Step 1
Used 1/2" ply panel to form racking, hinged to ceiling set off from wall about 4inches ,this allows further storage behind and prevents board hitting wall.I used piano hinges for strength and they also help prevent warping and twisting of panels.
32 comments
Aug 22, 2011. 7:20 AMBlacksedan47 says:
very nice, the Murphy Bed moved to the shop. i will definately use this for the goodies i dont use as much great idea
May 6, 2011. 4:53 PMreddnekk says:
I am always pleased to find new ideas and suggestions for use in my two-car shop. My wife wants to know when she can put her Ford marquis under cover; I am still teaching her that the ClearCoat paint is intended to take the place of a garage.
So all you fellows with ideas for making a two-car shop more efficient and friendly, please--Keep IT UP!!
Apr 28, 2011. 3:12 PMbluedragonlotus says:
You know, this really is so much more than storage space... it would be a great kind of home security for your garage tools too. In our neighborhood, we have a lot of problem with people breaking into sheds, outbuildings and garages. This system would make it that much more difficult for would be thieves to make off with your tools. Great instructable. :) Thanks for sharing.
May 27, 2010. 7:19 AMchefguru says:
A better idea to REALLY make it a space-saving work-space for a small garage would be to have the work bench surface hinged to the wall so that it could be folded up (or down) and out of the way to give you an almost flat wall.  You could just fold the bench surface down, and support with the legs at the corners, and you're ready to go.
If you designed a bench to fold up, and still had the tool racks spaced 4 inches out from the wall, then you could access your tools with the bench folded up against the wall in case you only needed a tool, but didn't need the whole bench.
I have a 2 car garage, but if I actually want to park 2 cars in it (or 1 car, and my 3 motorcycles), then I don't really have room for a work bench.  However, this might be a really good idea for having the option of actually having a work bench that I would be able to use with hiding tool storage.
Thanks, good idea.
Feb 27, 2011. 4:56 PMacardboardllama says:
theres an instructable thats what you just described
Nov 1, 2006. 4:43 PMIdahoDavid says:
Good idea. BTW the other day I heard about a guy who is actually able to park is car in his garage. What a crazy concept.
Oct 15, 2010. 6:32 PMcaarntedd says:
What the...? No way! My garage will hold four cars plus my motorcycle and tools. (when it's empty)
At the moment the only form of transport inside is my motorcycle. there may also be a skateboard in one of the piles.
Feb 9, 2008. 8:16 AMxcoastie says:
My wife has the same silly idea, so I am the one getting up early to scrape ice and warm up her car to protect my valuable man-cave from her car.
Nov 1, 2006. 8:43 AMleevonk says:
how does that save space? the tools on the wall stick out about 3 inches.. Maybe if you have a multilayered system where you could pully-down different sets of tools over each other.
May 18, 2010. 10:12 PMjeffeb3 says:
I agree.  If I made something like this picture, I would just leave it down all the time.  Maybe you could space it away from the wall by 4", and then just put pegboard on the wall.  You could get twice the storage with something like this.
Nov 1, 2006. 10:34 AMradiorental says:
good point, however I can see this beeing useful to secure your tools if you have kids or sticky fingered neighbours
Dec 13, 2009. 10:00 AMneorazz says:
im thinking ...good idea heres how i might improve it
(when i do this i'll post my instructable )
hinging look at attic retractable stair hinges
ease of use  needs spring system to help with retracting
latching  twist handle in center of panel with offset pull rods that would lock panel in place and act as hinge pins  if these were on both ends the panel could open front or back of work area if items on panel were mounted appropriately
or just reverse the hinge so the panel would open up  behind the walking area of your work area  then its never in the way of  your project
Sep 11, 2008. 10:52 AMklynslis says:
This is a thing of beauty! Not only would it be awesome in my garage, but it would be an incredible asset in my basement studio! Thank you so much!
Aug 2, 2008. 2:30 AMpepitosbazzeguti says:
Yeah ! I've seen something like this in a film of Buster Keaton ! Great work
May 24, 2008. 1:32 PMkaste says:
One more project to add to my list!
Oct 26, 2007. 6:22 PMsmokehill says:
Very nice -- I did something very similar in my basement when I was running out of room to hang tools. Being too cheap to use hinges, I just made loops of "plumber's strap" -- the roll of 1/2"-wide metal strapping with little holes in it -- at the top of the plywood rack, and the whole thing rotated on a piece of old iron pipe left over from replacing our primitive plumbing system. Originally I planned on holding the pipes up there by drilling holes in the floor joists, but at the last minute I had a brainstorm and just drove big nails thru the beams, into the end of each pipe. I had to offset each pipe from its neighbor, of course, to drive in the nails. Since I had a low ceiling I could just move the racks by hand, securing them with an old barrel bolt or a cabinet latch, depending on whatever was handy in the junk drawer at the moment. I always planned on counterweighting the heavy ones with some old sash-weights, but never got around to it. I like the safety feature of your automatic cleats, however. Nice work!
Oct 26, 2007. 6:32 PMsmokehill says:
One other method I used for one rack with very light stuff in it -- screwdrivers, etc Since it weighed so little I didn't even put a latch on it, but just rigged up a couple of Bungee cords that held it up in place. All I had to do was reach up and pull the rack down, grab the screwdriver, and let it go back up by itself (though obviously not just letting go of it and letting it snap back up!). Over time I've had to move the nails the Bungee was attached to, to keep it up in place neatly, and eventually I'll probably have to replace the Bungee. However, it's real handy for tools you use all the time. There are probably a lot of neat variations I never thought of, and maybe someone can expand on this a bit. Another minor stunt I liked was hanging a couple of extension cords overhead, with the female plug hung from a Bungee, similar to the rack. When you need a quick plug-in for the drill, you just reach up & pull it down, and when you're done it goes back up out of the way. The big commercial factories have setups like this on assembly lines, but they cost a LOT of money. And we are MUCH smarter than they are.
May 24, 2008. 1:31 PMkaste says:
Excellent ideas.
Jan 12, 2008. 1:56 PMprincessbunnyrooroo says:
clam cleat - it's a rope cleat that's used primarily in sailing applications - excellent choice for use on this cool project.
Jan 28, 2007. 7:58 PMkruts69 says:
Awesome solution to age old problem. Try using gas struts from old style hatchback car boot. Cheap as chips at auto-wrecker and saves from having string pulley, etc in the way of work space.
Nov 2, 2006. 11:30 AM679x says:
yeah im goin to have todo something like this so i can put my pool table in my garage and my other 2 tvs
Nov 1, 2006. 8:32 PMtheRIAA says:
how bout a in wall revolving tool panel selector... like in overboard
Nov 1, 2006. 3:42 PMCaspar_s says:
Good idea - do you have anything on the ceiling to latch it once it is up there? Like a deadbolt or something. Also maybe something to slow it down when it is released (I just picture someone undoing it and then getting wacked on the back of the head by the falling board)
Nov 1, 2006. 10:36 AMradiorental says:
I would suggest to tack 2x1 along the edges to stop the ply bowing down under the weight of the hardware. And, are those $20 cleats you used?!?!
Nov 1, 2006. 10:20 AMrimar2000 says:
Nice job. In my case, before this I must do CLEANUP and ORDER.
Nov 1, 2006. 8:33 AMmiketinte says:
Maybe you think it might not need an explanation, but that pretty much leaves out the "instruct" portion of an "instructable"
Nov 1, 2006. 8:23 AMkeng says:
Nice! I'd seen them to store things but never as tool racks...GJ!
Nov 1, 2006. 8:21 AMJakeTobak says:
i don't think I'd require any explanation, but one should be present, this being Instructables and all...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Bighead
