GE Adora Lint Filter Cleanout
This instructable will walk you through how to clean out the lint filter on your GE Adora washing machine. This is entirely doable by the end user, but the manual for the washing machine does not give these instructions, and the technical assistance number will not give you this information.
Essentially, if your GE Adora washing machine won't drain, your lint filter is probably full, and preventing the washer from fully draining.
This is something that GE wants you to pay a technician to do. That means a service call that usually has an 8-hour window. It may be a week out, as well. That leaves you with wet laundry, and out possibly several hundred dollars (not counting lost time at work).
From start to finish, this will take you about 30 minutes if you're careful and take your time.
Please let me know if your experience differs from what I've detailed, and I'll update.
Step 1Assemble your tools.
To complete this project, you'll need a philips-head screwdriver or a nut driver, a catch basin, and a towel.
42 comments
1-40 of 42next »
Jun 21, 2010. 5:47 PMwfm1950 says:
WHOA! NO TOOLS REQUIRED! I have one of these GE washers that was delivered in Nov. 2008. There is a small, plastic panel at the bottom of the lower panel that is discussed in this instructable. It just pops out, giving access to the filter. Check your unit before going to the trouble of trying to unscrew those impossible screws at the bottom.
Dec 6, 2011. 12:57 PMdano042 says:
The newer version of this Washing machine has a little access door to this now.
Making it easier to work on.
Nov 27, 2011. 9:35 PMkbacheller says:
I am adept at cleaning the lint filter on the washer. Over the past four years I do it about every six months. Daughter works at vet clinic, we have nine dogs. . . .I have retrieved bullets, ear plugs, change, a five dollar bill . . .great and easy solution. But this time it didn't fix the problem. I cleaned the filter, did one load of laundry, sluggish switching between wash, spin, rinse, spin. Now another load and it won't drain at all. Is there any other place in the washer that might need cleaned? Something I can fix myself? College son is now out of college, married and gone. College daughter is the assistant. I unplugged the power cord hoping the machine would miraculously "reset" after a brief holiday, but no go.
Nov 11, 2011. 7:01 PMbarnoult says:
2 of the screws are rusted on. Noticed that it is a hex head also, so am going to the store to get the proper size wrench and will try that. Unless you have any other suggestions.
Sep 21, 2011. 9:25 PMkeneisha says:
Wow this is awesome. My husband would never believe I did this all by my self.. well with the online help from this post. I cleaned out bowrets, hair, money keys.... just when I thought I had to call some one out to repair this, at 11:30 at night , I did it all by my self! I am proud of me,.... yea me!!!!
Jan 9, 2011. 5:43 PMRalCon says:
your info and pics helped with cleaning out the lint filter, thanks. got out $3 bucks in change, Lego pcs, and a bunch of gunk. but I'm still having trouble. I put in a beach towel & 3 face cloths to test it out. put it on speed wash, normal soil level. the machine ran fine until the last few minutes, then it stopped. I took everything out and ran it again. got down to 1 minute and stopped. now nothing is happening. only the words "door locked" are illuminated. the power light or stand by light don't go on. i tried unplugging to see if something would rest and nothing happened. any suggestions?
Dec 5, 2010. 7:02 PMmoosetooth says:
Great Instructable. This procedure will work for a Whirlpool Duet washer as well.
Nov 7, 2010. 4:27 PM-Q- says:
I thought I'd add a little of our experience here. A few times my wife used the Purex 3-in-1 Washer/Dryer sheets. The first time I found out about this filter, quite a while ago, there was one in there. But... I didn't know what it was :D So I figured it was a filter and I cleaned off the dog hair and pennies and laid it back in there nice and lined up on the filter! Hehe. Tonight I went back in there and now there were two (plus the normal change and LEGOs thing).
So if you use Purex 3-in-1 Sheets with this washer make sure they make it out and into the dryer and if one isn't accounted for then check down here! ;)
Jun 19, 2010. 7:21 AMkaewiu says:
Took me forever to figure this out on my own. Owners manual is worthless. Your pictures and description are wonderful, but I do not have the pedestal base so it is messy and time consuming. After looking at your procedure, I think I will raise my machine. I have always had GE washers but never again. This is a major design flaw IMHO.
Jan 13, 2010. 9:12 AMkbacheller says:
Thank you for taking time to post this help-fix solution!  My college son thought I was nuts, but volunteered to help me anyway.  He now thinks I am amazing!
Nov 5, 2009. 9:28 AMbridgebe says:
Thank you so very much for the help was able to fix wash in just a min or two after waiting and thinking about calling the repair service....I for sure going to be come a member ............................Bev
Oct 8, 2009. 8:05 AMjtkaler says:
My appreciation as well... Followed these simple instructions and took less than 10 minutes. One thing to be aware of is that if your machine is not draining at all, it will as soon as you take out the filter ;-)
Aug 16, 2009. 6:34 AMa2zvp says:
Thank you for the great advice. My washer quit also wouldnt respond to any thing.Just said door locked. Decided to follow advice here and clean out the filter. Removed 2.00 in change a bic lighter and a bunch of stones. But it was too late, something broke the fins off inside the pump. Called sears they said 200 for the pump plus labor if that was all that was wrong.Then called a parts store in akron ohio. They had it for 130.00 Went to pick it up and the owner let me in on a little secret. This pump is exactly the same one as the top loaders.He told me to change the front housing with my old one( three screws and 2 minutes of my time) Total cost was 38.00. Put it back together and works fine.Saved a lot of money Thanks again
Aug 9, 2009. 1:06 PMdrumz says:
Thanks a tone for the guide. It worked perfectly! I can't (well really I can (corporate america sucks building in service after it's sold and making basic maintenance "invisible")) believe they would make the tolerance so tight on those three screws to open the panel! I had to pry it up to get the holes to align to refasten it! What a joke! So I just put in the center one figuring I will be cleaning this filter again and don't need to spend a half-hour putting the panel on again. But you were a big savior so thanks again!
May 5, 2009. 5:30 PMmikenjodi says:
You are the best!!! Saved this chick some $$ and proved to my husband I'm not just a dumb girl ;-) After begging him for a week and a half to look at it for me, I found your instructions online - which worked perfect - and I'm back in business without his help! Lots of lint, a nylon, crayons and some legos - no wonder it wasn't draining. Thanks so much for this help!!
May 1, 2009. 4:05 PMRunTotoRun says:
You are my new best friend! After reading dozens of comments on other sites about the 3 week wait for GE service, I thought for sure this was going to be a nightmare... not so. It was a piece of cake. Job done in under 30 minutes. Thanks a million... (and shame on GE for trying to make $ on a service call for something so simple)
Feb 11, 2009. 6:35 AMjemi15 says:
We have been fighting the not draining battle for a month and getting frustrated with dripping wet clothes. We did not want to pay someone to fix it b/c of the obviously high cost. We are going to try this and hopefully it will work. We'll let you know....
Jan 28, 2009. 7:29 AMhouseofdixon says:
Wish i would have seen this how-to before i did it last night...i had water everywhere...My filter looked almost exactly like that, though i had a mechanical pencil stuck in there as well...
Jan 26, 2009. 7:46 AMnixfix says:
Thanks for the tip! mine had the usual hairy linty goo, a straw, a tie wrap, bobby pins, a cross, four keys and $14.14 in change. I'm just about to wash a load now, here's hoping that was the only problem
Dec 20, 2008. 6:47 PMjdoepke says:
Those instructions are perfect and saved us a TON of cash!!! Thank you!!! We were horrified to find a pair of underwear, dollar bill, a couple bucks in change as well as our daughter's hairclips, chapsticks and some twigs. Thanks again for the info!!!
Nov 15, 2008. 8:22 PMemandrae says:
Elvisisdead, A million thanks! We were having serious issues with our GE Adora washer not completing the spin cycle and emptying. Your instructions saved us a lot of $$. The filter was completely clogged and there was all sorts of interesting things besides lint in there... a quarter, a crayon, a paper clip, wads of paper, and plastic candy wrappers. All signs that we do indeed have three kids. Cleaning the filter was easy and your instructions were great. Thanks!
Oct 26, 2008. 9:12 AMrhmeshel says:
I cleaned the lint trap, thank you to all that recommended it. I am still having a start/pause door unlock problem. Any other ideas? There has to be another problem someplace.
Oct 28, 2008. 7:32 AMrhmeshel says:
I called GE service and they replaced the board and ordered a part for the door lock sensor.
Jul 7, 2008. 4:15 PMchristinecalc says:
Thank you so much. Finding this information was awesome! My husband is so proud of me for finding out how to clean the filter. I can't believe that they don't say anything about this in the manual. It totally fixed the problems I was having!
Jun 23, 2008. 9:53 AMwsrdpc says:
When we had this problem in warranty a tech from home depot came out and cleaned the filter out for us. He also showed me how to do this. If you hold the pipe closed just behind the filter you only will have a little water come out and just make sure you have a trash can close by. That way you don't have all that water draining out and it won't have to refill with water every time you do clothes. We leave the front panel off and I check the filter about once a month. I don't find much but with little ones I have to be careful because of baby clothes in the filter. Also he recommended that you be careful of how much soap you put in as it will also not drain properly.
May 16, 2008. 8:55 PMyankee2 says:
Thank you soooooo much. My 13 y/o son and I just completed cleaning the lint filter...nasty. It was so simple with your great instructions. I found a dollar bill and $2.50 in change plus lots and lots of nasty. Thanks for saving me money and providing such great step by step instructions. GE should definitely include this information in the manual.
Feb 23, 2008. 8:41 PMtrabran says:
Thank you!!!! I just finished cleaning out my filter and found 55 cents, an eraser, a few computer screws, some ponytail holders, and lots of NASTY! The machine is running now and I can hear it draining. This information should definitely be included in the troubleshooting section of the manual. This was so easy and not worth paying someone else to do for me!!!
Feb 4, 2008. 6:12 PMhauker says:
WOW!! I am so happy I found this info. Guaranteed problem solver...that was gross, and I am amazed at how much change was in there, along with one of my daughter's earings that has been missing (obviously). Thank you so much for saving me the cost of a repairman's visit!!
Jan 28, 2008. 3:32 PMGorillazMiko says:
That clog at the end it NASTY! Look at all that change too! Pesos! PESOS!!! Hahaha. Nice job, awesome work!
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:elvisisdead
