Introduction: Garden Fireplace With Bench
How to build a fireplace with a bench for your own garden.
Working time approx. 2 days.
Step 1: Digging In...
Use a pole to establish the center of the fireplace. This will be a reference point so make sure to use a long pole. Use a string and some spraypaint to mark the edge of the fireplace.
Then you can start digging... To find the right height you can add sand and some cobbles. Make sure the height is approved by apropriate authorities (wife, girlfriend, whatever) and then make sure this stays where it is as this will be another reference point for you.
Step 2: Adding Gravel
Use at least 5-7 cm of gravel and stamp it firmly.
Step 3: Adding Sand
Then you can add some sand. Use your 'cobble reference' to determine the amount of sand. I suggest at least 10 cm of sand. Do not stamp it but make sure it is evenly allocated according to your spirit level.
Step 4: Laying Cobbles
Use your spirit level and your 'cobble reference point' to make another two or three reference points at the outer perimeter of the fireplace.
Then make the inner perimeter. Again you should use a string on the reference pole with your chosen radius.
In order to keep the right level at all times you should lay down a few 'spokes' of cobbles wich will turn out helpfull when laying the rest of the cobbles.
You should use a rubber mallet when laying the cobbles.
Step 5: And More Cobbles
Use your reference points and take it away!
I suggest you start from inside and out. Make sure not to add sand between the cobbles yet.
Step 6: Checking Your Own Work
Use something long and strait to check if you have done your work properly. As long as you did not add the sand you can easily move, lower or raise each cobble.
Step 7: Tadaaa....; Fireplace!
Add sand on top of the cobbles, water it down and repeat and repeat. Hope for some rain and then you can walk on your new fireplace.
And now on for the bench...
Step 8: Preparing the Posts
As you can see the bench has 4 parts therefore I need 10 posts. These are approx 100 by 100 mm impregnated.
I wanted the height to be 40 cm above the cobbles so I have made each post 1 meter.
I used my router to round off the edges before painting them.
It is not nessesary to use cement or similar when digging them in as the battens will stiffen the entire construction.
Step 9: Mounting the Battens
I used two screws in each end of each batten
Step 10: Gables
Just for the looks of it I made a small gable in each end, and when ever I look at it I am happy I did.
Step 11: Placing the Hard-wood Rods
Use your reference pole again.
I made this batten my own tool for placing the rods right. Take a good look at the photos to see how it works.
Step 12: Mounting the Rods
I used stainless steel screws to mount the hard-wood rods from below. Make sure you pre-drill!
Step 13: Done!
That is it!
Invite your favorites and enjoy the fire and their admiration!
4 People Made This Project!
BenD4 made it!
RAnnandale made it!
swimspud made it!
AllanS1 made it!
78 Comments
Thanks for sharing this great design! I have a few questions about it though. How did you attach the rod to the stake in the center of the pit. Also, how did you screw on the seat boards from underneath at the points where they sit directly on top of the posts?
Glad you like it!
Screwing the seat boards where they sit on top of the posts was not easy. But from an angle I could predrill through the post and into the board and I had to use an extra long screw.
The rod is attached to the center stake with an old rubber band I had layin around (see img1993). The purpose is simply to keep the rod attached but still so loose that it can rotate a bit when placing the boards.
Thanks for sharing this great design! I have a few questions about it though. How did you attach the rod to the stake in the middle of the pit? Also, how did you screw the hardwood boards in from underneath at the points where they were directly on top of the posts?
What size were the hard wood rods for the top of the bench? Looking to re-create this and was just wondering about thickness/width and length for those
Hi Kyle
They are 22 by 45 mm.
Hi Allan
I work on a danish handyman magazine and we are interested in showing your fireplace with the bench in our magazine. Is it possible that we can lend the fotos from you and show your fireplace, including pictures of the proces, in our magazine Gør Det Selv?
Best regards
Lene Dinsen
Hej Lene
Det må vi kunne finde ud af, skriv til mig på
allans0311 [a] gmail.com
Mvh
Allan
just wondering but how many 1x2's did you use and at what length would you propose for a curve bench
Made it with the vent at the bottom as proposed. Works a charm! Thanks for the idea!
Just don't make me sit on the side hiding all the spiders.
