Introduction: Gesture Controlled Robotic Arm Using Kinect & Arduino
This is a Simulink Model to Control a Robotic Arm By Gestures that are captured using Kinect. A Robotic Arm is developed using Servo Motors.
Step 1: Things Used in This Project
Hardware components:
  1. Arduino Mega 2560
  2. Microsoft Kinect for Xbox 360
  3. Microsoft Xbox Kinect Adapter
  4. Adafruit Servo Motor
  5. SparkFun USB to Serial Breakout - FT232RL
  6. Gripper
  7. Solderless Breadboard Full Size
  8. Jumper wires (generic)
Software apps and online services:
  1. Arduino IDE
  2. Microsoft Kinect for Windows SDK v1.6
  3. Microsoft Windows SDK 7.1
  4. MATLAB 2013a
Step 2: Story
This is a Simulink Model to Control a Robotic Arm By Gestures that are captured using Kinect Sensor. A Robot Arm is developed using Servo Motors that replicates the Right Arm Shoulder, Elbow and Hand Movements.
My File at Mathworks File Exchange : https://in.mathworks.com/matlabcentral/fileexchan...
A Project By
B.Avinash & J.Karthikeyan
The Zip file contains the Matlab Simulink Support for Kinect and the Simulink Model named "GestureControlledRoboticArm" that WE HAVE CREATED and also the Arduino Code/Wiring Diagram. The Simulink Support for Kinect was downloaded from Mathworks File Exchange and the full credits go to "Takashi Chikamasa" for providing it. We do not own the copyrights or have developed the Simulink Support For Kinect. Simulink
Support for Kinect consists of IMAQ, Image, IR, Depth, Motion and Skeleton blocks to achieve real-time image data acquisition from Kinect devices such as Microsoft Kinect or ASUS Xtion PRO under Simulink simulation environment. It works with 32bit/64bit version of MATLAB R2010b or later in Windows7 32bit/64bit and it requires the following 3rd party software:
[C MEX Compiler] - Microsoft Visual Studio 2010 Express Edition (VC++) - Microsoft Windows SDK 7.1
[To use OpenNI http://openni.ru/ ] - OpenNI - PrimeSense NITE - PrimeSensor Module [To use Microsoft Kinect SDK http://openni.ru/ ] - Microsoft Kinect for Windows SDK v1.6 For more detailed information, please refer to document in the zip file and help of the blocks.
[Optional MATLAB products] - Computer Vision System Toolbox (highly recommended) - DSP System Toolbox (to acquire Kinect Microphone Array data) - Simulink Coder (to generate *.exe file)
Acknowledgements : Kinect Matlab, Simulink Support For Kinect, and Kinect Microsoft Sdk inspired this Project.
Step 3: Custom Parts and Enclosures
Simulink Model
Open the GestureControlledRoboticArm.mdl using Matlab after installing the Simulink Support for Kinect.
Download : GestureControlledRoboticArm.mdl
Matlab Simulink Code & Library Files (Instructions included)
In the .ZIP, you can find the Simulink for Kinect Support developed by Takashi Chikamasa, Mathworks. Inside the "slkinect" folder, you can find the instruction on how to install the library file in Matlab.
Download : Gesture Controlled Robotic Arm Using Matlab Simulink Support For Kinect.zip
Step 4: Schematics - ​Arduino - Servo Connection
The data output (angle) from the matlab software is sent to the arduino via TTL device. The connection from the TTL - Arduino & Arduino - Servo motors are as shown in the diagram.
Step 5: Schematics - ​Simulink Model (Gesture Controlled Robotic Arm)
This is the simulink model we have developed to aquire the data from kinect, convert xyz co-ordinates to angle, decrypt the data and send it to Arduino via Serial Communication.
Step 6: Code - Arduino Program to Receive Angle Data From Matlab
Arduino Program to Receive Angle Data from Matlab - Arduino
The angle output from the Matlab Software is encypted. In the Arduino IDE, we have written a rogram to receive the angle data, decrypt it and send it to the servo motors.
Download : Arduino Code
Step 7: Awards and Recognitions
"Gesture Controlled Robotic Arm Using Kinect (Simulink Support For Kinect) and Arduino" has been chosen in the week's ( 29/10/2016) Pick of the Week! - Matlab Simulink Hardware Challenge 2016
Won the 4th place in "MATLAB International Simulink Hardware Challenge 2016"
http://blogs.mathworks.com/pick/2016/10/28/2016-ma...
https://in.mathworks.com/matlabcentral/fileexchang...
Step 8: Credits
Step 9: Links
akashgupta201287 (author)2017-04-24
First this is an excellent project. I am using kinect xbox 1 sdkv 2.0 and visual studio 2013 desktop app, MATLAB R2016a. When I am running setup_kinectsdk.m file I get the following error.
>> setup_kinectsdk
### Confirming Simulink Support for Kinect installations with Kinect SDK...
### Setting MATLAB path to .\Lib and .\Lib\doc_en directories.
Warning: Name is nonexistent or not a directory: C:\Users\A\Documents\MATLAB\Lib
> In path (line 109)
In addpath (line 88)
In setup_kinectsdk (line 54)
Warning: Name is nonexistent or not a directory: C:\Users\A\Documents\MATLAB\Lib\doc_en
> In path (line 109)
In setup_kinectsdk (line 55)
### Generating C:\Users\A\Documents\MATLAB\Lib\simulinkfornidinfo.m
Error using fclose
Invalid file identifier. Use fopen to generate a valid file identifier.
Error in setup_kinectsdk (line 68)
fclose(fid);
Please help.
Swansong (author)2016-10-29
Awesome project!
avinash15101994 (author)Swansong2016-10-31
Thanks! Please vote this project for Circuit Contest :D
avinash15101994 (author)Swansong2016-10-29
Thanks! :)
ahmet_024102 (author)2016-10-30
this project. this website one number projet.
10 star you deserve
About This Instructable
5,093views
94favorites
License:
More by avinash15101994:Gesture Controlled Robotic Arm Using Kinect & Arduino
Add instructable to:
