loading
Really light up your next dinner party with a table that glows in the dark!
Photoluminescent (glow) powder mixed with clear casting resin fills the naturally formed voids in Pecky Cypress hardwood, creating a unique and stunning table. The glow powder charges up in sunlight and emits a cool blue glow when in partial or complete darkness.
Placing this table near a window will allow it to collect rays from the setting sun and then set off a pleasant glow from the transition from twilight to evening. Making your own is fun as you can customize it in any way you want. Instead of using hardwood you can use the technique of adding glow powder to resin to cast in all kinds of fun ways.
Let's make!
Step 1: Materials
The type of wood I used for this table is known as 'pecky cypress', which is regular cypress that has been naturally damaged with a fungal growth inside causing sections to rot - wiki on taxadium distichum (cypress).
These damaged pockets can be easily removed and create cavities in the wood which are perfect for filling with resin and glow powder. The pockets of damaged (rotten) cypress are soft and can easily be removed with compressed air and some light digging with a hand tool.
Aside from Pecky Cypress, we'll need:
Step 2: Mill wood
The wood comes from the mill to the store in rough shape, it's up to you as the consume to decide how you want the product to look. In North America most board lumber is sold in board feet.
Knowing I was going to make a table top by joining a few boards, I grabbed a few lengths of the Pecky Cypress and used a jointer to square the edges of both sides of the board. These clean edges will make a great surface to bond the planks together.
Step 3: Cut planks to size
With the board edges finished I could cut the boards to the correct length.
After marking each board to the desired finished length I cut them down to size with a sled on the table saw.
Step 4: Join planks to make a board
Using a plate joiner (biscuit cutter) I cut indents into the boards, then I glued in biscuits and clamped the boards together. To ensure the boards stayed even while being clamped I used a few scraps of straight wood on the top and bottom of the boards.
I let the glue dry overnight.
Step 5: Dig out fungus rot
The damaged pockets of wood in Pecky Cypress can be easily removed by gently digging with small tools to clean out the cavities.
Starting with a vacuum I gently pushed a flat-headed screwdriver into each rotted cavity to dislodge the rot and remove it. After, I used compressed air to blast out any remaining debris and ensure the cavity was clear of detritus.
This can get very messy and dusty, so wear proper safety equipment.
Step 6: Sand surface
After the glue has dried I sanded down the surface with a course 80 grit sandpaper on a random orbital sander. This cleaned up the transition between the glued boards. After, I brushed the surface clean to remove any dust. We'll need a super clean surface before we can move on to casting with resin.
Step 7: Mask and prepare board for resin
Before casting resin we need to ensure the table will be able to retain the medium. Since some of the cavities in the boards go all the through the entire underside was taped off, that way any resin that goes to the bottom will pool and not leak out.
To keep the resin from oozing out the ends I put scrap strips of thick acrylic along both ends. I didn't worry about the sides, as these boards didn't have any open cavities along the sides. The acrylic scraps were clamped into place and a short border of masking tape was put along the sides, just in case any resin migrated.
Step 8: Resin and glow powder
I used clear casting resin, which is a 1:1 ratio type - meaning you don't need to measure out specific amount of catalyst, just equal parts resin and catalyst. I prefer this method as I'm not very careful and have mixed up the mix ratio before. This resin is super easy to use and begins to set in about 7 minutes.
There's plenty of glow in the dark powder colours available, I chose blue glow in the dark powder which I got online. I'd recommend using more glow powder than less, as the effect is much more striking.
For my 41"x22" table I used 64 oz (2 liters) of casting resin and about 3.5 ounces (100 g) of glow powder. Yours measurements will probably vary.
Step 9: Prepare resin
To mix my resin I used large unwaxed paper cups. Pour equal portions of resin and catalyst into separate cups, ensuring to fill cups less than halfway full. Pour a portion of glow powder into either cup and mix thoroughly.
Know that when you combine the two liquids of the resin the chemical reaction will start, allowing you only about 5-7 minutes of working time before the resin sets.
When you're ready add the catalyst to the resin and briskly stir until the two liquids are one homogeneous mixture. Ensure to scrape the stir stick, and the sides and bottom of the cup. Pour the stirred mixture into the catalyst cup and continue stirring. The entire mixing process should take less than 2 minutes to ensure you have enough time to pour the resin without it setting.
Step 10: Pour resin
With your resin mixed it can be poured into the cavities of the Pecky Cypress. Since the resin is not viscous enough to suspend the glow in the powder I had to take quick breaks from pouring to stir the mixture to ensure even glow powder distribution.
Gently pour the glow resin into all wood cavities. You may find that the resin gets absorbed into the wood, or that some cavities are slower to fill, this is normal. You can apply another layer of resin over previously poured sections.
I poured in smaller measures, about 10 pours in all. This process took about an hour to complete. I let the resin cure completely overnight.
Step 11: Let resin cure, then reveal
After allowing the resin to cure completely overnight the acrylic edges and masking tape can be removed.
The resin won't stick to the acrylic, allowing it to be easily peeled from the ends. The masking tape was a little more tricky, but can be easily removed with a little patience.
Step 12: Preliminary glow test
Eager to test out the results I took the cast resin table top outside and let it soak in some sunshine for about 5 minutes, then quickly took it inside an enclosed area and turn off the lights. The effect was incredible!
Picture 1 shows the table with the additional resin spill over in complete darkness. There is no photo trickery here, this picture is exactly as it appeared when the lights were off. If anything, the effect in person was more vibrant.
Picture 2 shows the same table top with the door slightly ajar, allowing some natural light to enter into the room. Here you can see the resin spill over next to the vibrant blue and grain of the wood.
Step 13: Clean up edges
Along the edges where the resin touched the acrylic or masking tape were small sections of raised resin due to capillary action. Even though the edges are going to be routed smooth, removing these raised edges now makes the sanding process easier. I used a sharp knife to cut away the raised edges.
Step 14: Rough sanding
I have access to a 25" drum sander. This sander has a very rough grit and is great at plowing through large flat pieces like table tops. However, this machine is totally not required and you can work the table top to a smooth finish by just using a power sander.
I fed this table top through multiple times, each time raising the bed a small amount until the entire surface was level.
Step 15: After a few passes
After a few passes through the drum sander the table surface has been leveled and the resin spill over high spots are removed. Now we need to bring the resin surface back to a high gloss, and smooth out the wood surface.
Step 16: Finish sanding
Using a random orbital sander I sanded from rough grit all the way up to 400 grit.
Since the drum sander I used had a 80 grit sandpaper, I started at 120 grit then stepped up progressively until I was at 400. Spending enough time with each grit of sandpaper to ensure a uniform finish.
Step 17: Fence for routing
After the surface was sanded I could turn my attention to the edges. Though my router bit had an end bearing to keep distance from the table edge, the holey nature of Pecky Cypress made uniform distance on the edge impossible with an end bearing, meaning the blade of the router would occasional dig into the table more where there was a cavity on the table edge. To solve this I made a fence for the router.
With the rounderover bit installed in the router I measured the distance from the edge of the end bearing to the edge of the router base, this distance would be the setback for the fence. I clamped a straight edge fence at this setback perpendicular to the edge of the table sides.
Step 18: Routing edges
With the fence installed I could run the router over the table edges to make a nice rounded edge.
Step 19: Polyurethane finish
After routing and sanding I could finally apply a durable glossy polyurethane finish. In a well ventilated area I applied a coat with a foam brush and allowed it to dry completely.
Step 20: Wet sand
To achieve a high-gloss finish I wet sanded in between coats of polyurethane. Once one coat was completely dry I sprayed the surface lightly with water, then used a 1200 grit sandpaper to smooth out any brush strokes from the previous coat of polyurethane.
The surface was then cleaned and dried completely before applying another coat of polyurethane. This process was repeated several time to achieve a very high gloss finish.
Step 21: Paint leg anchor plate
With the top finished I could turn my attention to the base. I used retro hairpin table legs for my table (the ones in the link were cheaper to buy with a table top than just the legs). These legs bolt into the table bottom. Since this table design is different than the one the legs were designed for I had to make a new way to anchor them to the table.
To hide the leg attachment and really keep the focus on the glowing table top I decided to paint the leg anchor plate flat black.
Step 22: Transfer anchor openings
Once the paint on the leg anchors was dry I placed the anchor plates on the underside of the table and transferred the opening location to the table. An opening was drilled at the marks, ensuring to only drill as deep as the anchor nuts.
Step 23: Add anchor nuts + plate
The anchor nuts were installed in the openings, then the anchor plate was installed over the anchor nuts. Since the Pecky Cypress had irregular cavities some minor tweaks were needed to ensure the bolts and anchor plates had sufficient coverage on the underside of the table.
I used E-6000 Industrial Strength Adhesive which bonds almost anything to anything else permanently. This stuff is nasty, but magic.
Step 24: Attach legs
When the adhesive has dried completely the hairpin legs can be installed. Align the legs and screw in the anchor bolts to secure the legs to the underside of the table.
Step 25: Place your table + glow!
Your table is all set to glow the night away. This glow powder needs UV light in order to activate, so dusk is a great time to enjoy the transition.
This table has a really neat effect, and looks great even in twilight. Depending on how much UV exposure your table has it can glow for up to 20 minutes.
<p>Buy it: <a href="http://www.etsy.com/ca/shop/mikeasaurus" target="_blank">www.etsy.com/ca/shop/mikeasaurus</a></p>
<p>My problem with my work, an din the bidness I ran for a few decades, is that I never, ever, ask what I, or my work's, worth. I know the scale/metric for calculating but I can never get myself to do it.</p><p>The table's amazing and I thought, if I were to sell one....$900. (Which I know is slave wages).</p><p>How do you do with it at that price point???</p><p>I especially dug your leg mounting system...</p><p>cheers</p>
Does staying the wood ahead of time affect the resins sticking?
<p>Hola</p><p>Vivo en Chile y quisiera saber donde puedo comprar</p><ul><br><li><a href="http://amzn.to/1nSb1DK" rel="nofollow">blue glow in the dark powder</a><li><a href="http://www.amazon.com/gp/product/B004Y46G10/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B004Y46G10&linkCode=as2&tag=wwwmichaelsau-20&linkId=TI2XDYBDSCXA5J3Y" rel="nofollow">clear casting resin (I used the 1:1 ratio type)</a></ul><p>o con que otros nombres lo puedo encontrar</p><p>Gracias</p>
did you use all of the 128 ounces of casting resin?
Hey how much did your original slab of wood cost, wanna know what im getti into before i dive in and try
<p>I first made blue resin infill tables 4 years ago and was initially quite miffed to have the idea stolen by quite a lot of people, however once i got over myself (i know, bit of a Diva moment!) its actually really cool to see new ideas and this is a fantastic instructable. I'd have never have thought of using the glow powder and don't have similar wood to you available nearby (i only use local hardwoods)-Kudos for doing such a good job. </p><p>I'm not sure if this helps anyone but Silicone sheet is good to cast on as the resin peels straight off it, or melamine board (as long as there is zero texture). Did you consider just taking the Epoxy right over the full board rather than having to sand it back? </p><p>Sanding resin is one of the jobs i like the least! I've seen it planed but it can chip if you get it wrong/are unlucky so we sand ours too. </p>
<p>Epoxy resin in tables has been around a long time. However, new methods and styles push the envelope on what's possible - and with so many more platforms to share the results there's always going to be ideas and techniques borrowed from one designer to another. That said, your tables look amazing and I haven't seen anyone tackle such bright colors before. </p><p>I chose not to cover the entire thing with resin because I wanted to have the texture of wood. Though I like the way epoxy looks, I covered my <a href="https://www.instructables.com/id/Lumberjack-table/" target="_blank">lumberjack table</a> with it, it can get scratched over time and look hazy. With glow resin the luminescence isn't hampered by scratches or haziness. You're spot on about sanding resin, it's the worst!</p>
<p>when I use 500g resin, how much glow powder I need?</p>
<p>Your mileage may vary, so best to to a few test pieces to dial in what you like the best. Please share your pictures when you're done!</p>
<p>How much resin do you need for a 1.20x60cm plate?</p>
Finally got it to charge in the day light
<p>Nice work, Alan! It looks great, lights on or off! The purple is a good choice, such a bold color. Thanks for sharing!</p>
Super fun project! Made a bowl with no power tools, but casting the epoxy on a rounded surface was a nightmare. Worth every blister, thanks for the great instructions
Awesome job Alan! Would love Tom see a a pic of the lights off so we can see it glowing!!
Finally was able to let it charge in the sunlight. I can't believe how bright it glows
<p>Will be awesome for my backyard...</p>
<p>Hi Mike, just one question for you about the glow power, about how many<br> grams did you use in the table? I'm going to make one for my graduation<br> booth table since I'm focusing on fantasy styled environments like the <br>movie 'Avatar'. Also anything I should do if this is going to be in a <br>lit room to get the maximum effect without it being in the dark? Thank <br>you so much!!!</p>
<p>Experimentation is your friend. Try a few test pours with different amounts of glow powder on a scrap piece to dial in your ideal amount. Good luck!</p>
<p>this table is the dogs dangly bits its awesome bud</p>
This is incredibly AWESOME!!!!! Love it :) Keep up the good work Mike :D
<p>Hi Mike. I'm going to do a concrete layer on my dining room table. I love the look of this glow in the dark method. So I was thinking of making random channels/grooves in the cement before it dries and adding the glow in the dark element. Also, I would like to do more of a cobalt blue, but the brand you recommend has a purple/blue selection, not just a cobalt blue. It sounds to me like you would need to use more of the pigment to get to the blue side of the product. Do you have any knowledge of the color application, or should I try to find another brand that carries a cobalt blue color? My dining room has windows on 2 sides, would that be sufficient light to activate the glow? Do you think my ideas would work with the cement?</p>
<p>Fun idea! This should totally work with concrete, but I recommend letting the concrete completely cure before doing the glow resin. Also, do a test piece before committing to a table.</p><p>The link I give goes to a store that has a few choices of color. Be careful as some colors look different in daylight than they do at night. </p><p>I think your table location as you describe it should be enough to glow. Most incandescent bulbs also charge the glow powder. <br>Good luck, I can't wait to see your results! :)</p>
<p>Step 7: What sort of paper is used to contain the resin? This seems like an important point, given the wrong type would adhere and be a fuss to remove later. </p>
<p>From step 7</p><blockquote>To keep the resin from oozing out the ends I put <strong>scrap strips of thick acrylic along both ends</strong>. I didn't worry about the sides, as these boards didn't have any open cavities along the sides. The acrylic scraps were clamped into place and a <strong>short border of masking tape</strong> was put along the sides, just in case any resin migrated.</blockquote>
<p>Hi Mike,</p><p>Really, really love the table. I'm going to try something similar and have been conducting tests using the glow powder and resin linked in your article. However, I can't get anything that matches the glow intensity of yours. I've been testing the ratio of resin to glow powder using your ratio in addition to one with increasing glow powder, in addition to the depth of the void that is being filled. I'm wondering how deep your voids are and whether that's the variable I'm missing? I'm also wondering how opaque yours are during daylight? I'm guessing that the glow powder concentration can actually get too high, making the resin too opaque and therefore limiting the amount, or depth, of light that can get in and out.</p><p>Also, I was theorising how I could increase the glow and wondered whether you'd experimented with mirrors? Given the glow resin will emit light in all directions when excited, less then 50% of the emitted light will be visible as the rest will go into the walls and floor of the void. If broken parts of a mirror were lined on the floor of the void, it would reflect this lost light back out to the viewer. I will try it with some broken mirror shards, but wondered whether you had first.</p><p>Any suggestions would be appreciated.</p><p>Cheers,</p><p>P</p>
<p>The glow powder is heavier than what the resin can support, so it will sink to the bottom of the voids. A great trick is to do multiple pours, one to fill the voids most of the way with resin and another after the first is hardened with the glow powder so it's closer to the surface. My table voids are opaque during daylight hours, it's a bone-white color. </p><p>I think you'd really have to be overdoing it to have too much glow powder in your resin, the ratios I show work just fine. Adding mirrors I think is unnecessary .</p><p>I'd love to see some of your results and it's great that you're doing test pieces before committing. Good luck!</p>
<p>Question; I see you went from sanding to coating with poly. But what if you wanted to stain the wood with a color, then poly. Are there any other steps you'd need to take in order to do this? Or any other considerations on using stain?</p>
<p>After sanding you could easily add a stain, then coat with poly to protect the wood. I'd suggest trying a sample on a scrap piece of the same wood, just to dial in the process.</p><p>I'd love to see pictures when you're finished. Good luck!</p>
<p>Hey! Awesome product! I'd like to try new application with rock but will the powder work with basic epoxy resin? like &quot;west system&quot;</p>
<p>Yes, any epoxy resin should work. I'd do a small test casting before committing to the final piece. Please share pictures when you're done. Good luck!</p>
Thank you so much for the inspiration! Here is my take on the table
<p>The table came out great, and those large voids look amazing!</p><p>Thanks for sharing pictures. You rock!</p>
<p>I tried to order the powder but you don't seem to be delivering where I live... is there a way have it delivered to west indies? </p>
<p>Thanks so much for sharing this project, it really inspired me to do something myself. My daughter needed a small stereo cabinet, and I took the opportunity to make it even better than she expected. </p><p>The cabinet is fairly small, 18&quot; x 26&quot; x 15&quot;, made largely of maple with a live-end pear-wood top. I asked her to draw a design for me, transposed it to the side, and carved out the picture with a Dremel tool. I filled it with the epoxy/glow powder combo, and sanded it down. I poured it on a little thick, but with the help of a belt sander and time for the resin to harden (about 4 days), I was able to get it nice and smooth. She was really pleased with the result. I included some photos from before the final sanding and varnishing.</p>
<p>Wow! The live edge top is great, but the glow design really sets this piece off. I love how you and your daughter collaborated to make this happen, and I know she's going to love it for years to come.</p><p>Thanks for sharing the story and pictures!</p>
When I first saw your work, I knew I had to make one of my own! The wood wasn't to hard to find. Luckily I work at a lumber mill, so I got two six foot planks for free. Your instructions were really easy to follow! After a few weeks of hard work it was finally finished.Thank you for great ideas and instructions!
<p>Looks great! I am still amazed by my glow table, so I know you'll be enjoying the effect for a while to come. Also, there's no better feeling than an amazing thing you made yourself.</p><p>Thanks for sharing pictures and your story!</p>
Thanks Mike! And yes It's a good feeling too accomplish something beautiful with your own two hands! I'm looking forward for my next projects. I'm going to make a bigger table using 7/4 Pecky cypress and a curve ball that my wife gave me.. A round table!
<p>Please post pictures when you're done. Good luck!</p>
Absolutely beautiful and very easy to understand instructable! Thank you so much for sharing! I can't wait to try this!
<p>I admire your work with this table, looks great and the glow effect is realy awesome.</p><p>A while ago I acquired a walnut slab with beautiful natural cracks adn decided to fill it with epoxy resin. I got a little to excited doing that and the resin boiled, but in my opinion it looks pretty good. Of course it was sanded, water polished, and at the end covered with clear lacquer. Hope you like it.</p><p>Regards from Poland<br>Gabriel</p>
<p>Wow! Thanks for sharing, it looks great.</p><p>Epoxy resin can boil if it's poured too thick. Bes tto do 2-3 pours for larger voids to get a clear casting. however, I think it looks really nice the way it is here. Great work!</p>
<p>I'm happy that you like it. And yes I've learned to pour smaller amout of epoxy. Now, working on another table with about 44mmtthick slab I poured it 8 or 9 times so it should be perfectly clear when finnished. As soon as it's done there will be a nice gallery picturing the progress of creation.</p><p>Thanks again!</p><p>Regards</p><p>G</p>
<p>Hi Mike. Thank you so much for your instructions. I have been wanting to make a glow in the dark table since I came across your instructions some time ago. A friends wedding finally gave me the excuse I needed. As a complete amateur with limited woodworking experience I found the instructions easy to follow. A friend helped me by sourcing a large plank of sweet chestnut (no pecky cypress in the UK?!), saw it &amp; join 2 pieces for the table to be the gift so I could make a river for teh resin down the middle. I made 2 - one a prototype to make all my mistakes on first. I had only 2 problems was there was a bit of a delay in getting the resin, as was difficult to get large volume in the UK, so had to order from the US and my damming of the resin wasn't effective on the prototype due to unseen cracks going all the way through the wood which meant I resined the plank to the floor, but all sorted. I finished them with 2-3 coats of teak oil rather than varnish which will hopefully mellow over time. Didn't get a photo of the finished gift table glowing in the dark due to my poor photography skills, but some here of the tables, glowing table tops &amp; finished prototype table in semi daylight.</p>
<p>Both tables look amazing! Thanks for sharing your work.</p><p>Pecky Cypress is difficult to source, but any wood with voids will work (and can look just as good, as you have shown). Buying resin online is the best way I've found to reliably get the quantity you need, there's loads of types but <a href="http://www.amazon.com/gp/product/B004Y46G10/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B004Y46G10&linkCode=as2&tag=wwwmichaelsau-20&linkId=TI2XDYBDSCXA5J3Y" target="_blank">this is what I used</a>.</p><p>Love the pictures, thanks again for sharing them. Enjoy the Pro Membership!</p>
I love the idea and had one question. thinking of making a patio table and was wondering what type of finish, outdoor varnish has a UV blocker in it so was wondering your suggestions.
<p>Mike, I love the concept. I would love to do this just for the color and not the glow effect. What powder could I use? I am thinking countertops in a kitchen.</p>
<p>A <a href="http://amzn.to/2bzzcl7" target="_blank">powder pigment</a> would be fine. Always cast a small test before committing to the final project. I'd love to see your results! A colorful countertop sounds so nice.</p>
<p>Will this type of epoxy work, and do I need to buy a full gallon of this. This is for 16 oz.</p><p><a href="https://www.michaels.com/easy-cast-clear-casting-epoxy/10408248.html" rel="nofollow">https://www.michaels.com/easy-cast-clear-casting-epoxy/10408248.html</a></p>
About This Instructable
3,096,981views
6,646favorites
License:
Bio: I'm Mike and I make crazy things at Instructables HQ in San Francisco. Follow me and try a few of my projects for yourself!
More by mikeasaurus:Easy Table Saw Projects 5 Ways to Remove a Stripped Screw Easy Waterproof Clothing
Add instructable to:
