The solution is to run both ethernet and phone over the same existing cat-5 cable. Every wall jack becomes two jacks, one RJ-11 for phone and one RJ-45 for ethernet. This neat hack could save you a lot of money, as you only have to buy new wall plates and jacks rather than wall plates, jacks, and hundreds of feet of wire.
See how this works in the next step.
Disclaimer: I'm not sure if this is legal. The telephone company won't be pleased if you short your telephone wires together. However, if you do everything right, they won't care. Don't blame me if you shock yourself (unlikely), damage Ethernet devices (also unlikely), damage phones (not as unlikely), damage your house wiring (not too unlikely), or damage your fingers with knives (rather likely).
Remove these ads by
Signing UpStep 1Theory
Cat 5 cable and RJ-45 jacks have eight wires.
Ethernet uses two pairs (four wires), one for send and one for receive.
Telephones use two wires.
Therefore, you can run both ethernet and telephone over the same wire, and still have two wires left over.
In fact, you could run two Ethernet jacks from a single cat-5 cable, or four telephone lines (though I don't know why you would run multiple phone lines.)
This Instructable will focus on changing wall plates from one RJ-45 (Ethernet) jack into one RJ-45 and one RJ-11 (phone) jack.
Note that I have not done extensive testing with cross-talk between phone and ethernet, though I have seen no degradation in the quality of either when both are in use.
Also note that this procedure will not work with PoE (Power over Ethernet) devices. Nothing bad will happen, it just won't transmit power. See step 13 for a possibly unsafe way to keep your PoE and add phone service. Also, it will not work with gigabit ethernet-- gigabit ethernet uses all four pairs. It will work fine at 10/100 Mbps which is sufficient for most people.
Only downside to this is someone trying to plug a computer etc into it.
Ideally should have double cable runs to every panel in a house anyway, and then patch as you need. It's nice to see some places are being cabled like this now - but then seeing single runs makes me die inside ;)
I have no phone at home but have DSL throgh ATT (they call it Dry Loop).
I have my Wireless modem in the home office and connected to phone jack (which is Cat5) in that room and wireless is use around the house (which is wired with cat5 all across).
I would like to use the other jacks in the house as Ethernet outlet to connect my TV media drive to avoid WiFi slowness. they are connected through wifi. How do I connect my cat5 phone jacks to my modem while continue to receive dsl connection?
How do I do that?
If your DSL comes in nowhere near your junction box, and is for some reason wired up to one specific jack, then you will need to somehow get an ethernet line between the DSL modem and the junction box. There, you can place an ethernet switch and plug all of the pre-existing wires into it.
http://www.contact-directconnect.com/images/Smart-Jack.jpg
Data networking, which should be an inherent capability of a well-designed phone cabling system, its completely unsupported by the common "hard-wired" design. If data networking is done, separate 4-pair cables are run to a modular patch panel. The problem with this is that now some wall jacks are just for voice and others are just for data. Each jack is less powerful because of its specialized use. Total system cost must be much higher for a given level of functionality. The system will work, but is neither structured, nor optimal.
The advantage to doing it this way is that it's not permanent so you can reconfigure your panel any which way you want in the future.
I can probably be convinced to post an instructable about making splitters if anybody's interested.
By the way. My knowledge comes from a 40 year career with BELLSouth in Florida and North Carolina.
Most phone have polarity correction built in and hence you won't notice any difference on your phone, but your modem and adsl signals will suffer with reverse polarity.
Phone lines are 48VDC on idle, 90VAC on ring and around 30VAC when in use.
you can check with a multimeter but red should be negative (odd but true) and green should be positive.
If you have a second phone line, black is positive and yellow is negative.
The old 4-conductor, beige jacketed household telephone cables typically used red and green conductors for the first pair, although this is not true of CAT-5A cable which uses eight white wires with various color stripes. Wire pairs are twisted together in CAT-5A cables.
If you don't know what VRMS means, you have no business fooling with this stuff.
The Cat5 cable I'm planning on using is also carrying DSL signal. However, I'm just going to stream movies to the PS3, that means, when I'm downstairs watching movies, I won't be surfing the net.
I'm not looking for gigabit speed, maybe just 50Mbps for the HD movies that I stream; does it look like it's going to work for me? Thanks.
http://www.discount-low-voltage.com/kwikjacksystem.html
Professionals with integrity would not conceive of this as a permanent design.
We actually can compare shades - and if you put green and red side by side you see a difference in shading. But there is no red or green. And we learn tricks too about using striped wires as guides and just generally in worst case scenarios just make sure the "shades" all line up. Just an FYI from a 20 year vet of the tech-age. You should see me with resistors!
He ran circles around the guys that could see colors.
His terminations were better then the non disadvantaged guys.
Now I did not know that he was color blind and once I found out I was truly amazed.
There are a lot of people out there that are handicapped and can overcome the disability and you would never know it.
Personally I try to contract persons with disabilities most of them work better then someone with out a disability.
Manufactures are making Data equipment IDIOT proof so that all that is needed is to run a cable and punch the "wires" down in the slots at both ends with out making sure it is right.
The ports will align themselves to the right pin outs regardless of the (fancy term) Wiremap.
Wiremap is a method to see what wire is to what pin.
Orange pair
Green pair
Data pins
Blue pair
Brown pair
Future use and or grounding for EMI interference.
Structured Cable comes to mind. The cable in a whole provides the stability and the green and orange are twisted more then the blue and brown pairs are. Cat6 has even more done with it. I will not go into a whole explanation of what mathematical science is used to create the cables twisting just know there is.
This basically has to do with magnetism. These pairs are twisted together in counter twisting rotations. If you have two magnets a North magnet and South magnet they repel each others force. That is what is going on inside the cable. That is why the cable has 4 pairs that are lined up the way they are and why each pair is twisted together in better grade cable there is a plastic separator between the pairs(cat6 typically). Splitting out pairs destroys this entire design.
Running cables close to EMI (transformers and such is bad too) is reduced by this design but deliberate placement should be used.
The center pins are reserved for line one teleco but it depends on what you are plugging in. That is where the codes/standards/practices come into place.
EIA/TIA established this years ago (1980s) and we technicians follow these today (2010- and forward) so that one cable can be used with any configuration with out having to tear it up and figure out what the person was thinking that connected the jacks and plugs in the first place.
We follow a strict 568B straight through pattern for a reason. Specialty cables are heavily marked as such. The inexperienced just slap it together and hope it works and disclaimer that it if does not they are not responsible for damages.
It was a simple way of avoiding the disruption of running long cables through busy offices.
Keep up the good work.
Andy.
