3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hanging Bottle Light Bulb
Make a light bulb from an ordinary bottle.
My previous bottle bulb was a failure of the good kind. I learned quite a bit so check it out first before proceeding.
http://www.instructables.com/id/Bottle-Light-Bulb-AKA-Bacardi-Bulb/
This one is simpler to assemble, display and has greater reliability.
Extensive research along with clues from other Instructables members has lead me here...
Please play safe when using compressed gas, deep vacuum in glass vessels and electricity....
Step 1Materials
Materials
Please refer to my bottle bulb instructable...
Again you will need a clean glass bottle. I chose a clear bottle but a colored one would be preferable
A rough service light bulb.
2 part epoxy
some brass welding rod
A refrigeration schrader valve and stem.
a small section of 1 inch nylon rod.
Light wiring, heat shrink tubing and chain.
You will also need a vacuum pump. not a vacuum cleaner
Gauge assembly
Argon and regulator
18 comments
Feb 15, 2012. 7:39 PMDeeg says:
Bravo! I'm very intrigued by your project. I have a couple of questions:
1) Is your bottle-bulb still working?
2) You left a little bit of negative pressure (i.e. a slight vacuum) in the bottle.  Any reason to not leave a slight positive pressure to keep oxygen from leaking into the bottle?
3) How hot does the bottle get?  I was thinking that a moldable plastic like sugru would be easier to plug the neck but it might not be able to stand the heat.
Feb 4, 2012. 1:58 PMArtisanEclectic says:
This is a great project. Have you ever seen this video?
http://www.youtube.com/watch?v=DIGqBb3iZPo&feature=mfu_in_order&list=UL
I have a 1.75 liter Jagermeister bottle that I think would be great for this! Now all I have to do is befriend an A/C tech. lol
Jan 8, 2012. 9:43 PMSIRJAMES09 says:
I have yet to see a rat that a 12 ga. shotgun with deer slugs can not kill....LOL
Jan 2, 2012. 12:01 PMcurvy77 says:
and for added use if you ever get into a fight you have a very hot glass bottle to throw.....(warning may want to wear gloves)
Jan 3, 2012. 4:14 AMcurvy77 says:
VERY BIG RATS!!!! 20 sided die?
Jan 4, 2012. 7:12 PMDrWilliamHorriblePhD says:
Rodents Of Unusual Size? I don't think they exist.
Jan 5, 2012. 4:20 AMcurvy77 says:
thier in the fire swamp.
Jan 4, 2012. 1:15 AMradar48 says:
Perfect ,thanks .But litle , weare need profesinal equipment.
Jan 2, 2012. 12:14 PMcriggie says:
Most incandescent bulbs get awfully hot while running.
From memory something like 90-95% of the power is lost as heat.
What can you say about about heat?
Jan 1, 2012. 4:18 PMlesizz says:
Is there a chance of the bottle under vacuum if a larger bottle us used?
Dec 30, 2011. 10:42 PMrfuller1 says:
Very cool project! I request next one be a electron beam gun with a photo sensative layer! Next step, the boob tube :)
Dec 30, 2011. 10:51 PMrfuller1 says:
Oh come on you know high voltage electronics and higher vacuum means more fun! Especially if you use phosphorescent chemicals too! OK out of line, but it could be fun. Er ya
Dec 30, 2011. 11:20 AMmikeasaurus says:
Awesome, great improvement on your previous work!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
193
Author:Random_Canadian
I seem to keep breaking things....
