This is my first Instructable so bare with me
I looked on here for a hand pump to make but unfortunately there didn’t seem to be an Instructable for it, but lots of people asking how to make one.
What I wanted to do was to build a pump for water to make my own version of a super soaker, but I didn’t want to spend lots of money buying non-return values and the like so I thought I would build it from junk I had hanging around. It works reasonably well, I think you might buy one that pumps better but this isn’t bad for made of junk, it does the job.
Heres a link to an animation of the working pump
www.chrisfrydesign.com/pump.gif
Remove these ads by
Signing UpStep 1What you need
Ok here’s the bits that you will need
Parts
a bike inner tube
Large PVC pipe (I used 35mm)
something to cap the Large PVC pipe with (I used 2 caps from some supplement bottles, whatever will fit that’s plastic, you could cut them out of a plastic sheet) and you will need to make 2 little caps for the valves so you will need some plastic there, maybe some plastic from thick bottle lids or make up tubs or something would be suitable.
Slightly smaller PVC pipe (I used 25mm)
5mm hose connectors
a piece of dowel (I used 16mm)
1 screw that will fit in the dowel without splitting it.
Vaseline (petroleum jelly) for lubricating the pump.
Tools
a drill with various drill bits
a utility knife
hot glue gun and many a few spare glue sticks
lets get making
http://www.instructables.com/id/make-a-manual-vacuum-pump-for-under-%2420-by-convert/
