Homemade tobacco pipe
This Instructable is about how to make your own tobacco pipes at home. I didn't want to spend a lot of money for a tobacco pipe, so I decided to make one myself. Here is how I did just that.
Step 1You will need...
You will need...
What you will need to make your own tobacco pipe:
- 1 Block of Bruyere wood
- 1 ferule
- different kind of grater
- a saw
- pencil
- a drill with different gimlets (Hand auger)
- one circle
- a Dremel like tool
- sand paper
- milling cutter min. 18 mm
- time (you will need a lot of it)
- a idea
75 comments
1-40 of 75next »
Apr 13, 2011. 8:02 PMlaurent123 says:
you are a very talented person im only 14 and a instructable on wooden swords brought me here but for the past 3 months ive been making and crafting my own pipes out of wood, clay, ceramic, and many other materals and ve enjoyed it very much so than you for geting me into the one thing i look forward to after school and thank you for the great hobie
Mar 24, 2010. 8:17 PMChaseAwesome says:
 Would poplar work as the wood for the bowl?
Jun 3, 2011. 1:43 AMPwag says:
Pretty sure it'd be too soft. I burn wood in my wood stove and poplar goes up like paper.
Apr 5, 2011. 2:19 PMhealbr says:
It is also very easy to make the pipe all one piece,
the hardes part is shaping.
Nov 23, 2010. 7:05 PMsymphonyinmymind says:
Hello:) Lovely pipe, very nice woodworking. i have a question, i'm planning on making this as a gift and the part that holds the tobacco when you drill the hole all the way through do u put some kind of filter or anything between that and the mouth piece or do you just leave it completely open? Thanks!
Nov 24, 2010. 2:56 PMbaronbrian says:
I know that a lot of the higher end pipes don't bother to filter at all. When you're smoking pipe tobacco, you're smoking for the flavor of the tobacco and a filter will change the flavor of the tobacco. So I'd suggest not filtering at all (besides, that'd be one more thing to fit on the pipe :) ).
Nov 24, 2010. 3:51 PMsymphonyinmymind says:
Ahh that makes sense haha, thank you very much :)
Oct 4, 2010. 8:28 AMapapier12 says:
Can i buy that off of u
Jun 3, 2009. 7:39 PMDr_Zhivago says:
How could you drill the hole to connect the stem and bowl on some of the curvier designs like the top left and second down on the right?
Mar 19, 2010. 10:19 PMdominoxiii says:
To put the hole through in the severely curved pipe you have to make it in sections and glue it all together. It can be made with a few seems. The main bowl will be one part and the rest of it could be made with two parts split down the middle.
Sep 8, 2010. 12:30 PMRevquigley says:
You can also steam-bend it.
Oct 14, 2009. 2:45 AMMarvinney says:
Well I was looking for something like this because me too didn't want to spend a lot of money for a tobacco pipe. So wanted to make it at home. Nice technique. Thanks.
Jul 18, 2010. 9:20 PMcorey_caffeine says:
don't use a glass pipe for tobacco
Nov 4, 2009. 7:17 PMHI! says:
Is using Bruyere wood necessary, or will any do?
Dec 16, 2009. 12:28 AMLt. Duct Tape says:
Bruyerre or cherry wood are the best, but any hardwood will do. Don't even THINK about bamboo, though. My first pipe was oak, and it tasted a bit funny at first, but it lasted a couple years....
Oct 20, 2009. 1:37 PMEzmegaz says:
beautiful
Oct 14, 2009. 2:42 AMMarvinney says:
Well I was looking for something like this because me too didn't want to spend a lot of money for a tobacco pipe. So wanted to make it at home. Nice technique. Thanks. But I will suggest you www.greenglassclean.com to make your tobacco pipe clean.
Sep 18, 2009. 8:46 PMLBos11 says:
how do you make the stem
Aug 14, 2009. 4:34 PMHuray4Insanity says:
cherry wood would be perfect
May 18, 2008. 8:02 PMSWV1787 says:
"1 Block of Bruyere wood" Why specifically this type of wood is it better at holding the heat, resisting the tobacco residue, or what??? I would think that the type of wood should not make too much difference since a corn-cob and a cane reed can be made into a satisfactory pipe, But nice carving I really like the finished product. Lengthen the shaft and it might resemble the pipe Gandalf used in Lord of the rings.
Jul 16, 2009. 8:15 PMwenpherd says:
maby theres somthing about corn-cob or cane-reed that is heat resistant
Jun 23, 2009. 6:12 PMstrmrnnr says:
It would resemble Gandalfs pie, although I always thought of his pipe being made of clay. It could be rekilned to burn out the tar if it had to be cleaned. Who knows? The guy was a wizard; there can be pretty near anything.
Apr 5, 2009. 6:05 PMMattandJora says:
The bruyere wood is just a generally used type of wood for tobacco pipes because of it's properties. Bruyere is known for its natural fire retard and the fact that is doesn't really absorb water. The type of wood really doesn't make a difference. I would guess it's just a matter of how long the pipe lasts or how the stain effects it. That's just my thinking and i'm still a teenager i just picked that up on a pipe making website so dont quote me =]
Mar 27, 2009. 12:56 PMsnowfalcon says:
There are other woods that will work. There's several opposites that discuss this. Briar is considered ideal by many for all the reasons stated. Also because it is both porous and *hard*. It has the structure to allow a lot of carving and hold up to a lot of wear. One could get fancier with carving briar than with many other woods. Some woods also used: cherry, apple, maple, walnut, olive. There are more. I have direct experience with pipes of cherry, maple, and walnut. The maple I can't remember but am experimenting with some soon. Walnut makes a decent pipe, I've had not problems with it. Works easier than briar, but tough enough to hold up to carving. Cherry ... for some reason I never thought much of cherry, but came upon an estate pipe of cherry, and smoked it and was *amazed*. It shot from "I'll maybe try this once" to "my favorite pipe" in two smokes. Cool, even smoking. There are other woods, but I'm cautious of them, such as rosewood. I know there are some of the "exotic" hardwoods that have resins which can be toxic or at the very least give a bad flavor.
May 20, 2008. 10:20 PMDrVenture says:
The wood he refers to is also known as Brier or Briar wood, and is more commonly spelled as one of those two (at least where I'm from). The wood actually does make a substantial difference in the construction of a quality tobacco pipe-- Mainly, brier is a lightweight and porous wood that easily dissipates heat, and is remarkably well suited to the purpose. Corncob pipes are similar, being light and very porous. This is a very different type of wood than something heavy and dense like Oak or any type of wood that comes from a tree (in fact, brier "wood" doesn't come from a tree really, it's made from the midpoint between the roots and the body of the plant).
Jul 16, 2009. 8:11 PMwenpherd says:
did you buy the mouth piece, if so than where? or did you make the mouth piece, if so how? NOW ANSWER ME NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 3, 2009. 11:50 PMChiana_Rei says:
I've actually got my hands on some pear wood. I've done pipes out of walnut, cherry, maple, and oak. I have also made one out of clay and used copper for the stem and mouthpiece. And then there was a hookah style pipe made out of a small bole of mulberry with the center hollowed out and 4 "stems" with surgical tubing and mouthpieces added to it. It does not make you a stoner to own or make pipes, I am not a stoner and I still enjoy pipes and good tobacco's.
Jul 1, 2009. 12:23 PMwenpherd says:
how did you make the mouth piece
May 13, 2009. 8:58 AMbaneat says:
You can get pegged as a stoner, which can be undesirable to some and gets some attention from authorities, but glass pipes are better cause they don't impart the wood's flavour on itself, and don't burn. If you could hand-bow one of those, it would be pretty cool
Jun 24, 2009. 7:21 PMbenz_z says:
no way stoners just use trumpet mouth-pieces, they heat them up and shove them into a water bottle the people who buy the glass ones are posers (ask no questions i tell no lies) but thats a great idea and a nice -ible
Jun 26, 2009. 3:00 AMbaneat says:
Wanting a well built piece that doesn't use plastic (hot smoke and plastic long term can damage you) is not posing, it's common sense. These homemade pieces are also a little less efficient and I've found anyone who owns one didn't use it for long. Now a $400 roor, that is a waste when a cheap glass one does the same.
Jun 26, 2009. 4:44 PMbudforum says:
actually dude, a RooR is a great brand of glass bong because in some of em there is what can be referred to as "percolators" which further cool and filter your smoke, thus making for a cooler, and cleaner hit.... any more questions, feel free to ask..... i'm the guy you're looking for when it comes to glass smoking accessories
Apr 29, 2009. 10:08 AMthizzluke says:
so u did this with a hand saw right?
Apr 7, 2009. 2:54 PMDangerDan says:
yea i just made a pipe earlier and it took me about 40 minutes, the mouthpiece is bamboo and the bowl is beach wood, it's pretty crude but it works fine, yours is really nice i should make one like that
Jan 9, 2009. 7:09 PMgumbytig says:
Ok this may be a dumb question but why do you need the ferule? I was inpired by this ible to use some of the scrap pieces of hardwood i had laying around (i try to heat my house on firewood). I'm not sure why you can't just smoke it out of a tip thats just an extension of the bowl. Please enlighten me.
Mar 27, 2009. 12:48 PMsnowfalcon says:
You don't need the ferule. Only if you're going to use a typical pipestem. Strictly speaking you can make it out of a single block of wood. If you do I suggest keeping the length from center of bowl to tip of stem less than 6". That's the length of a standard pipe cleaner. Longer and it's harder to clean. There are many pipes made like this, or in two pieces with the stem fit to a hole in the bowl. They're more "rustic". But work well enough.
1-40 of 75next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:SimonRuben
