Homemade Tracked Vechicle
6,861
25
13
Published
Introduction: Homemade Tracked Vechicle
**** UPDATE ****
Added the electronics and programmed the robot to be controlled by a custom homemade remote control.Added a short video.
You can see the remote control here
This tracked vechicle(Its actually not a robot yet so thats why i'll call it a vechicle for time being) is made using acrylic.The tracks are made using bicycle chains and M3 nylon nuts and M3 bolts.
Currently it has nothing in it except two high torque dc geared motors.
I am planning to control it with a homemade remote control using xbees,some analog joysticks,pushbuttons,etc.
So here are some selected images from the time i started making this tracked vechicle.
Video:
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    13 Comments
    great idea using bicycle chain!!!
    Hello, very cool project, i have a question what is the gear ratio of the gearbox?
    About the chains, are they bicycle chains or roller chains...and im using brushless motors...are they better than the brushed motors you are using?
    Those are bicycle chains.I have never used brushless motors but can say that brushless motors are too much fast so you need to add some kind of gearbox to slow it down.
    Both type of motors have their own advantages.
    The wheels are just screwed to the shaft.The shaft has a hole drilled in it by default.
    Thanks... It's really a good idea. I will try :D
    It's a good job!
    I agree, A step-by-step would be nice! I'm curious about the conection between motors and driver wheels.
    Thanks !
    I have uploaded a image of chassis(second image).Hope that helps you about the mounting of wheels on motors.
    P.S : the final chassis has some minor changes.
    have you adapted or welded the shaft, or use the shaft "as is" from default?
    You should write up a step-by-step of this (or at least use a finished image as your first image to make a decent thumbnail).
    Oh sorry i didn't realize about the image.I have changed it.
    I'll surely write a step by step someday.
    Yeah I'm with Kiteman here. You should write a step by step for this.
