Step 10Aerodynamics and Modification
*Blocking your grille has proven to be effective - just remember that your radiator (and grille opening) were designed for the worst case cooling scenario. So monitor your engine temps and adjust your grille opening accordingly.
- Fold your mirrors. If you can, fold your rear view mirrors in. Just be sure to stay in compliance with local laws.
- Belly Pan - A significant amount of resistance comes from the open areas under your car. Covering them with corroplast or some other material can reduce your drag coefficient (Cd)
- Wheel skirts - covering your wheel wells to keep your cars body one contiguous object can help
- Air Dam - see image, if you car doesn't have one already, this can help
- Always Drive with your windows up
If those are the conditions you always drive in - you potentially can't afford to cover. Otherwise, if you're driving in 20C weather - the thermostat is going to stay mostly closed to reduce coolant throughput.
From a heat transfer standpoint - you want to keep the engine at a relatively static temperature over a dynamic range of environments. In hot conditions, you'll need high airflow and high coolant flow. In "normal" conditions you can either have lower airflow or lower coolant flow. In cold conditions, you want both lower airflow AND lower coolant flow. Unless you're in that desert/high load class - you don't need 100% efficacy (mind you, that's not efficiency).
"youre often running at 3000 rpm, and it generates even more heat, and if you block the air intake, the air coming through the radiator wouldn't be enough to cool the engine as designed."
Firstly, heat generated is independent of RPM. Heat and load are correlated. It's a minor caveat - yes, on the highway, you will have more load than when idling.
Secondly - my earlier post stands. The cooling system is way overbuilt to handle desert conditions running all of these accessories (a/c, carrying people, cargo, etc.). If you're not in a hot climate - you don't need all of the cooling capacity that the factory installs.
I operated my cars in South Florida where temperatures would frequent 35C - I had no problems. My car warmed up faster and temperatures leveled off around 95C (within the operational zone of specified by the mfr - in my case, Volkswagen)
I, among others, have not had issue. Blocking off the front of the car does not hermetically seal off the entire system ;) You still have some flow ;) As I said in the instructions - monitor your coolant temperature and adjust accordingly :)
yes, but you force the fan to push more air than expected. The air cavities are designed to make a correct air flowing.
"Firstly, heat generated is independent of RPM. Heat and load are correlated. It's a minor caveat - yes, on the highway, you will have more load than when idling."
no. at more RPM, the more strokes you make, more explosions in the cam. that's why injection cutting was invented, to prevent overheating due the high RPM (yes you won't cut injection all the time, i'm talking about an emergency issue) and is more dangerous 3000 rpm when idling than on the highway (you have the fresh air that cools the engine to run properly)
"Secondly - my earlier post stands. The cooling system is way overbuilt to handle desert conditions running all of these accessories (a/c, carrying people, cargo, etc.). If you're not in a hot climate - you don't need all of the cooling capacity that the factory installs."
not so overbuilt as you think. people that live in the desert usually have issues of that. If you see tv show Extreme Trucking, all the grilles are blocked up to keep some warm inside. too much warm will be harmful for the engine
"I operated my cars in South Florida where temperatures would frequent 35C - I had no problems. My car warmed up faster and temperatures leveled off around 95C (within the operational zone of specified by the mfr - in my case, Volkswagen)"
you say 95C? 100C is the temperature of boiling water!. Agree with the coolant could handle 120C but is better have a little margin. That's why coolant is designed this way. the perfect temperature is around 80-85C
"I, among others, have not had issue. Blocking off the front of the car does not hermetically seal off the entire system ;) You still have some flow ;) As I said in the instructions - monitor your coolant temperature and adjust accordingly :)"
agree, but all of this will harm your engine. maybe not today, maybe not tomorrow, but the engine is not designed to handle this. sometimes is better spend a little more fuel that a brand new block
Heat is not independent of RPM. They don't change linearly with respect to each other, but at the same load a higher RPM will cause more heat... although you might have to swap in different gear ratios to achieve this in the same vehicle for testing.
That the cooling system is overbuilt is not a proof that it will stay within margins when it is altered. It is certainly possible, since the fans would be running more often or faster (or 2nd fan kicks on in cars with two fans), but each vehicle design including different engine configuration per, would need tested.
Driving slowly should be the emphasis here. Folding in your mirrors may make you feel cool, but I doubt you could even measure the difference in fuel usage due to that. In fact, maybe you should try to measure.
http://www.youtube.com/watch?v=GC6FbiiTSec
Which is why boat tailing wasn't mentioned ;)
