How to Convert Water Into Fuel by Building a DIY Oxyhydrogen Generator
1,198,170
3,089
885
Published
Introduction: How to Convert Water Into Fuel by Building a DIY Oxyhydrogen Generator
About: Random Weekend Projects
Here's how to build a sexy looking generator that uses electricity to convert water into an extremely powerful fuel!  In this project, you'll learn how to build an OxyHydrogen generator from scratch.
Step 1: What Is an OxyHydrogen Generator?
An oxyhydrogen generator, like this one, uses electricity from your car battery to split water into hydrogen and oxygen gasses.  (Electricity + 2H20 --> 2H2 + O2)  Together, these make a fuel that is much more powerful than gasoline, and the only emission released is—water!
Of course, to be a completely clean fuel, the electricity used to generate the gas needs to be from a clean source.  Solar, wind, or water power could be a few examples.
This video shows step-by-step how to make one.
NOTE: The amount of electrical energy required to make the gas is more than the energy you can obtain from it.  This is NOT an energy generator so much as it is an energy converter.
Step 2: Getting Metal for the Generator Plates
For this project, you're going to need some stainless steel and some ABS pipe fittings. I visited a local fabrication company, and not only did they have plenty of scrap metal to choose from, they were even willing to help me cut it to custom sizes. A job that would have taken me hours with a pair of tin snips and a hacksaw took only a matter of minutes with their equipment.
I used 20 gauge stainless steel, and with the help of their hydraulic punch, cut precise holes in the tops and bottoms of the plates. When finished, I had 12 plates measuring 3" x 6", 4 plates at 1-1/2" x 6", and three 1" connector bands that were 6", 4-1/2", and 3 1/4". A belt sander was used for smoothing down the jagged edges around the hole.
Step 3: Increasing the Plates Surface Area
Next I used 100 grit sandpaper to sand each of the plates diagonally. You can see the "X" pattern I sanded into both sides of the plates. This increases the surface area of the plate, and will assist in producing more gas.
Step 4: Configuring the Plate Assembly
The plates are joined in a configuration so that the 2 inner plates are connected to one electrical terminal, and the 2 outer plates connected to the other terminal.  Plastic rods, plastic washers, and stainless steel nuts help to form the proper electrical connections.
The generator plates are assembled in the order of plate, plastic washers, plate, stainless steel jam nuts until 8 plates have been connected.
To see a step-by-step of the generator plate assembly, watch that specific portion of the video here.
When the plates are assembled, a 4" ABS clean out plug is attached at the top with some stainless steel bolts.
Step 5: Making the Generator Body
The body is made from two 4" ABS clean out adapters, with a 4" plug inverted and cemented into the bottom. A 4" tube of acrylic or ABS makes the body, and the generator plates and cap screw down into the top.
A water bubbler is made in a similar fashion out of 2" clear acrylic tubing, but needs a way to clip onto the side.
Step 6: Making Clips for the Bubbler
Clips can be made from scrap acrylic or ABS tubing, and glued to the side of the body.
To make these clips, I cut 3/4" off the 2" tubing I used to make the bubbler, then cut the top 1/3" off to form a claw.  These were then cemented to acrylic rods, and attached to the side of the generator body.
Step 7: Adding a Check Valve
Some poly tube, and a one-way check valve is added to the top elbow, making sure the valve will let gas out, but nothing back in.
Step 8: Making the Electrolyte
The electrolyte is distilled water and about 2-4 teaspoons of KOH (potassium hydroxide). Salt or baking soda could also be used, but may dirty and corrode the plates over time.
I stirred the KOH flakes into the water, then used a coffee filter to strain the solution into the generator casing (after it had been cleaned thoroughly).
Note: Potassium Hydroxide is caustic and can burn the skin.  Avoid direct contact!
Step 9: Finishing Touches
Water is added to the bubbler, then the cap is put back on, and the poly tubes are hooked up.
I tested it out with a 12 volt car battery and some jumper cables. The gas formed is collected it in a small water bottle, and ignited with a flame.
On 12 volts, this produces about 1.5 LPM.  I also hooked it to 2 car batteries in series, and on this higher 24 voltage, the system produced over 5 LPM and filled up a gallon milk jug in 38 seconds!
Note:  Higher voltages allow more current to flow through the system, and it heats up quickly over time.  If allowed to continue, there is a risk the plastic casing will melt from prolonged exposure to high temperatures.
Step 10: How Powerful Is the Gas?
This system was not designed for use in a vehicle, but more as a device to demonstrate the electrolysis of water and what the gas can do.
To see some experiments where the gas was ignited, and some useful features of the generator, check out the video.
If you liked this project, perhaps you'll like some of my others.  Check them out at www.thekingofrandom.com
SciStarter Citizen Science Contest
Grand Prize in the
2 People Made This Project!
  • Oil Contest
    Oil Contest
  • Creative Misuse Contest
  • Water Contest
    Water Contest
885 Discussions
Can this hydrogen water gas be used on School buses instead of diesel.or will they have to convert diesel to that fuel diesels use.
I am confused with the reaction plate arrangement. your system has 16 plates exclusive of the connector plates; but according to the washer and bolt setup you show in the video only 2 plates get positive and 2 plates get negative connection from the battery. Is it supposed to be like that? What is the use of the remaining plates? Are they just to increase the surface area for the system?
I think that their called floater plates. They act like resistors or something and helps with the production of the gas.
All I'm doing is repeating what I've heard. In my generator, just as much gas comes from the "floater" plates as the plates that are electrically connected. I made my own version of this generator and used 20 non-connected plates and it produces enough gas to fill a 1-gallon milk jug in ten seconds. My other HHO generator with no floater plates produces a lot less. (1gal. = 2-5 min.) So the extra plates make a huge difference.
No water is formed when hydrogen is burned in the presence of oxygen. No such thing as HHO or hydroxyl gas or oxygenhyrogen gas.
Don't be stupid! Oxygen and hydrogen will only create water at critical mass which requires a hell of a lot of pressure
I'm not sure what was the purpose of that outburst. Critical mass simply means there is enough hydrogen to burn (oxidize) and enough oxygen to support the process. Put a lot of hydrogen in the presence of a lot of oxygen and it will produce a lot of energy and water as a by-product. As in a hydrogen burning automobile engine...or the Hindenburg. Except in the case of the Hindenburg I suspect most of the water was vaporized.
I'm sorry, but all 3 of your answers are wrong, uneducated guesses...
1-Oxyhydrogen *IS* the proper name of the gas produced by water electrolysis: https://en.m.wikipedia.org/wiki/Oxyhydrogen
2-"Hydroxy"gas *IS* indeed a proper nickname for said gas: https://en.m.wikipedia.org/wiki/Hydroxy
3-Water (vapor) *IS* indeed a byproduct/result of burning said gas: http://hydroxyenergy.com/index.php?dispatch=pages.view&page_id=7
(It is also just about the cleanest burning fuel there is).
Although I already knew all of these, a quick 15 sec Google search confirmed them. Please at least attempt to research before making bold statements that could be (embarrassingly) false. :-)
Well, if it isn't a gas, then what is it? Has to be either a solid or a liquid. There's not but the three choices. LOL
Oh, I know, it is a figment of the imagination of some uninformed folks who believe in magic.
HHO is a mixture of 2:1 ratio of hydrogen to oxygen. They exist in a
gas state until heat is applied then the oxygen bonds to the to
hydrogen molecules and forms H2O. Have you thought about using your brain before commenting?
Actually yes I did and I also know a little chemistry. HHO is the formula for water written incorrectly it should be written H2O. A mixture of anything has no single formula. It is possible to have a mixture of hydrogen and oxygen, HHO as you have written it and seem to believe, a gas on its own simply does not exist. The formula for a mixture of hydrogen and oxygen would be written as H2+O2. It is not a compound and has no properties on its own different than simply hydrogen and oxygen. A compound of two molecules of hydrogen and one molecule of oxygen is water and cannot be anything else.
Chemistry does not change just for the folks who want to make up new compounds. These new compounds must follow ordinary chemistry. And when H2 and O2 combine they form water, sometimes heavy water, H3O, not some made up a compound. Brown's gas or HHO gas simply does not exist. It was made up by a person named Brown who was tried and convicted of fraud in the matter.
You might want to check into the meaning of mixture and compound. Sand and water is a mixture. The sand is still there in the form of sand and the water is still there in the form of water. SiO2 is sand and H2O is water. Sometimes sand itself is a mixture of different compounds.
when did i ever say that HHO is a compound? I clearly stated it is a mixture of 2:1 ratio of hydrogen to oxygen.
That's the point. There is no such thing as a mixture HHO. There is a mixture of hydrogen and oxygen. And since both exist as binary molecules it would be H2 + O2, not HHO. It could be two parts hydrogen and 1 part oxygen, but that would just be by weight or volume or however you want to measure. When you write HHO you are actually saying a molecule of water. (A compound). So you say mixture and write compound. The only compound of HHO that exists is water, not some make believe gas fuel. It's a hoax.
"Oxyhydrogen is a mixture of hydrogen (H2) and oxygen (O2) gases." from wikipedia you abselute insane person to call everything a hoax. It clearly states it is a MIXTURE. Seriously
I don't care what Wikipedia says. There is no such thing as oxyhydrogen other than a made-up name for something that doesn't exist unless someone measures by volume or weight the two gases. It cannot be made chemically. If made by measuring it is useless. HHO cannot represent this mixture since that is the chemical formula for the compound water. The use of this "mixture" as a fuel is a hoax.
Wikipedia is written by citizens with no attempt by anyone to validate. It is not proof of anything. The article you referenced could have been written by you or another person who believes in the hoax.
If you could read I've never said it was anything other than a mixture. I've always insisted it was a mixture. But it cannot be made with a chemical reaction, just by physically measuring. If you want to call me insane at least quote me more carefully.
