How to Fix Rust Spots On a Car
 by intoon
Featured
I drive a 1985 VW Golf (diesel), and it's in pretty good condition for being 21 years old. There are three spots on the front left fender that have rust on them. Someone had hit the car and the paint came off, so it became rusty. These spots are not only an eye sore, but they are sure to spread in the salty Nebraska winters.
My goal in fixing these was function, and not so much glamour. The car is kind of a beater, so I wasn't too concerned with making it look perfect. As long as the rust was gone, it would look better, and I wouldn't lose a fender.
Step 1: Assess the Situation/ Remove Wheel
Having never done this, or any other body work on a car, it took me a little longer to figure out what exactly I was going to do. My original plan was to take the entire fender off, but after inspecting it, that would be too much of a hassle and would require me to disassemble a lot of the front of the car.
Instead, I jacked the car up then I pulled the wheel. I unscrewed the plastic thing protecting the wheel well and set it off to the side. That gave me really good access to see up behind the sheet metal on the car. I was originally going to pound out the dent on the upper part of the fender, but space was tight and I couldn't easily do it. Having the wheel well open will help when I'm grinding and painting.
1-40 of 93Next »
vanwazltoff says: Feb 18, 2013. 9:22 PM
i wish things were this easy for me, but i have 6 cancer spots were i had to cut metal out and tack in some new metal and bondo over it, i have a few spots of bubbling rust and of course nothing is in an easy spot
skuishingbugs says: Nov 15, 2012. 7:10 AM
i have a 96 golf that has a few rust spots, im thinking of doing this! it turned out really well.
skimmo says: Jul 2, 2010. 6:51 PM
is there an acids that remove rust, i have a chainmail shirt that i need to de rust and it will that to long to polish every ring
mrlunna13 in reply to skimmoOct 18, 2012. 6:16 PM
I know I am a couple of years late to this post. But....
The best way to derust a chainmail shirt is to do it with electrolisis. You will need A car battery charger, Washing Soda, 1 12 inch or longer Piece steel rod, or rebar.
In a 5 Gal bucket filled with watter put 1 cup of Washing Soda (not bicarbonate sodium), Mix thoroughly, Clamp the Positive side to the Steel rod, Clamp the Negative side to the ChainMail shirt, Drop it on the water, Hang the steel rod from the edge of the bucket making sure that it is close tho the chainmail but not touching. Turn on the charger and watch the rust go up in rusted bubble crust on top of the watter. Give it about six to eight hours.
You are completely done.
Lorddrake in reply to skimmoSep 8, 2011. 9:27 AM
a non chemical way to remove the rust is to put the chainmail shirt into a sealable large container (5 gallon bucket with a lid is great for this) and add some fine sand (in a pinch you could use sifted playground sand) or other abrasive compound.
put the lid on tight, turn the bucket on it's side, and roll the bucket to aggitate the shirt and the abrasive.
after you get the shirt cleaned remove it from the bucket, clean it off, oil it well.
jperez128 in reply to skimmoApr 29, 2011. 11:07 AM
Rust-Oleum/8 oz. rust stripper
bassbindevil in reply to skimmoJul 25, 2010. 4:05 PM
There's also phosphoric acid; you should find some form of it in the auto body supplies section, maybe under a brand name like Ospho or metal prep. Citric acid also eats rust; you can get that in dry form at home brewing supply stores. And, finally, sulphated molasses, from the feed store. Google these things along with rust and you'll find more information.
JerryMopar in reply to skimmoJul 7, 2010. 1:19 PM
Muratic Acid, get it at a hardware store or farm supply
bluebelle says: Mar 28, 2007. 3:35 PM
i was just wondering what to do if the rust is all the way through. can you use bondo for that? the spot is about 14 cm by 8 cm.
SPeacock in reply to bluebelleAug 23, 2012. 8:59 AM
For holes, you can use a backing material for Bondo to stick to. It is Bondo brand wire mesh that has self adhesive glue on back to keep it in place. You can use scissors to shape. Just follow instructions on the package. Prime and treat the back side of the patch if you can.
one_fake_user in reply to bluebelleJun 15, 2009. 1:49 AM
By a tube of rust converter. It converts iron oxide back into a quasi metal. It is a good idea to use it on any rusty area that you are not going to physically cut out and weld a new patch back into. If you don't the rust will most likely come back fairly quickly. Rust is like cancer, even the smallest amount of rust can turn into a horrible tumor. For instance before doing this step of the instructable I would still use rust converter to ensure there was absolutely no rust left. It isn't all that expensive either so it is a worth while investment. Hope this helps.
one_fake_user in reply to one_fake_userJun 15, 2009. 1:50 AM
correction "Buy a tub of"
stinna2 in reply to one_fake_userJun 29, 2010. 3:23 PM
you don't actually need much the rust converter stuff is pretty thin and goes a long way
LeviMan_2001 says: Jul 13, 2010. 2:28 AM
I wouldn't recommend using a grinder, use a wire wheel.
Jeffrey G C in reply to LeviMan_2001Apr 16, 2012. 6:05 AM
Agreed, using a wire wheel would a better choice than a the grinder. sanding is ok, but using a grinder like is done in the next step can cause more problems than it solves. I say this for a couple reasons
1 A wire wheel wont remove too much base metal
2 you can get rust out of pitted metal better with the wire wheel than a grinding or sanding disc
However, I will caution that if you do use a wire wheel that you must wear safety glasses, and if you put the wire wheel on a drill, to always rotate the wheel in the same direction. as the wheel gets worn the wires will bend, reversing direction will cause a lot of wires to break off and go anywhere the drill is throwing them
BrianJone5 in reply to LeviMan_2001Jun 5, 2008. 10:51 PM
The sandblaster wheel is fine for this job. Its not a solid grinding disc that I think you suspected it was, its overlapping pie segments of 'sanding' material.
MilesPerGallon says: Mar 15, 2012. 7:19 PM
Awesome job on the the fender.
I'm curious, how many miles per gallon do you get on your VW Golf? I'm thinking about buying a diesel. Somebody told me they burn cleaner than gasoline and the engines(if well-maintained) can last a million miles.
cplthibault in reply to MilesPerGallonMar 20, 2012. 3:31 PM
I currently drive a volkswagen jetta TDI they do certainly burn cleaner, and once upon a time diesel was far cheaper than gas which is unfortunatly not the case anymore. I get an average of about 50 MPG and it costs me about 60$ to fill from empty i get 800km to a tank easily. HIGHLY HIGHLY reccommend anyone to go diesel. only real downfall to diesel is the cost of maintenance but if you compair that against the life span of the car you end up saving in the end as the life span is nearly double that of a gas car.
spinach_dip says: Sep 9, 2006. 4:39 PM
looks pretty good. I no longer care too much about appearance, because I drive beaters, but whenever I would grind out rust and prime and paint, the rust would return in that same spot within a year. I think the grinding removes all the galvnizing. Although I haven't done any cosmetic bodywork with it, I've had good luck on other things with primer that says it containes zinc. They are also known as cold galvnizing compounds.
hmakori in reply to spinach_dipSep 13, 2011. 6:56 PM
Did you try magic oil.
hmakori in reply to spinach_dipSep 13, 2011. 6:53 PM
I read on another site mercedessource .com and found out that there is magic paint that can stop the rusting right away. Can you try?
Eric Sullivan in reply to spinach_dipAug 19, 2011. 1:18 PM
Galvafroid for instance
robbs says: Jul 6, 2011. 12:23 AM
I need a bit of advice with my rust spots. I have them on the roof and hood. The rust hasn't eaten into the metal yet. So, I need to hurry up before it does. Can someone give me the procedures? I plan on hand painting with roller. Its a '91 Buick Skylark. Not quite a "beater," but its getting there. BTW, I'm a female taking this task on! Thanks for the input!
ac1D in reply to robbsJul 22, 2011. 3:54 PM
Usually, this work:
Sand the rust using normal sand paper, start with something like 150 and end with 2000 (these are the size of the sand on the sand paper)
Then spray paint it.
BrianJone5 says: May 8, 2011. 12:25 PM
For your first body work, this is excellent. Certainly better than my first attempt.
Aerosols can't deliver the flake, so you'll never get a match. If your mask was outside the paint area (i.e new paint over good paint around the repair) you could soften the line with rubbing compound and a microfiber cloth.
One thing to add to your next repair is a degreaser. This is a solvent that removes all the wax and grease and road grime everywhere you want the paint to stick. They sell it where they sell the paint.
My second suggestion would be to 'feather out' your sanding. Try to sand each layer to an inch-wide stripe. This gives you less of a step to deal with in filler and paint. Change to a less aggressive abrasive and smooth it all out.
Most importantly though, you have stopped the rust in its tracks, and from 20 feet, no-one can see the repair. BTW with older cars, one way of assessing their state is in feet: "Its a 20-footer" explains how close you have to get to see noticeable defects. As you might expect, a 10-footer would be in really good shape.
jperez128 says: Apr 29, 2011. 11:07 AM
You could have used Rust-Oleum/8 oz. rust stripper to get some of the rust off also.
http://www.autozone.com/autozone/accessories/Rust-Oleum-8-oz-rust-stripper/_/N-25uj?itemIdentifier=660016&_requestid=550873
braydensucks says: Nov 12, 2010. 3:09 AM
why rust must be removed?
because rust slowly desolves your metal and destories the pain job along with the back metal now i dont know about you but having square cut outs of replaces metal looks worse then a crap paint job
so do it right
hand sandpaper it
then use hole filller prefeerd for cars and undercoast
then hand sandit again.... and then use a sander
until smooth and roughed
put under coat on usualy white
then get car coulour then clear coat
this will make it very pro,d and not like bad or noticable
jcarrier1 in reply to braydensucksApr 7, 2011. 8:12 PM
Do you know how to speak or write? desolves? Destories? Pain job? Replaces metal? Prefeerd? Undercoast? Usualy? Car coulour? This will make it very pro,d? Go back to kindergarten dude
saintofkillerz in reply to jcarrier1Apr 17, 2011. 4:41 PM
Troll! Btw, you didn't put a period at the end of your last sentence. Give useful advice, or go away.
TheDirtyBosnian says: Aug 26, 2010. 7:49 PM
I have a 1986 F150 and to fix the rust spots I just put duct tape over them and then paint over that, because I'm to lazy to actually tend to the rust spots
Not_a_Clue in reply to TheDirtyBosnianAug 31, 2010. 9:20 PM
so how is the duct tape working cuz i got rust rotted holes in my 1986 chevy s10
TheDirtyBosnian in reply to Not_a_ClueSep 2, 2010. 10:57 AM
the duct tape holds but it is slightly noticeable but if u just glance at it you dont really notice it but also my rust spots are on the bottom of the cars fender and side skirts so its not like people just stare at those parts of the car anyway.
kporter says: Sep 24, 2006. 2:23 AM
I need some advice; I think my girlfriend has been cheating on me. At first her phone would ring and I would go to answer it and she'd grab it from me and say its none of my business. Then I answered it once and this guy said hello and then hung up. And she keeps going out at night and she wont tell me where she goes, and when she gets back she walks from around the block as if someone dropped her off and didnt want to be seen. Anyways, last night, I wanted to see who was dropping her off, so I drove around the corner and parked in a driveway and hid behind my car and waited. There, I noticed a little rust on the inner wheel well of my car, so would you recommend taking it into an autobody shop, or just buying the spray on stuff and doing it myself?
rebel48 in reply to kporterJul 2, 2010. 8:18 AM
Well thank her or you would have never found the rust!What does all that have to do with your rust? Get a new girlfriend or pay more attention to her and your car! Go to any auto parts store for canned paint since it want show they will recommend paint repair products. As for the first of your I need advice those are life lessons learn as you go
intoon (author) in reply to kporterSep 24, 2006. 9:32 PM
Well, if you did it yourself you would save some money. Your girlfriend might also think you were a bit manlier and decide that she should stop cheating on you. Either way, make sure you get the rust out, not just cover it up. Rust spreads like SARS in China, and will come back if you don't elimanate it.
Goat Chaser says: Aug 27, 2008. 7:22 PM
I have my eye on a 69 GTO. It had a vinyl top and there are some little holses in the roof from the rust. The wind shield and and back window look unstable. The rest of the car is solid and was a CA car. Can anyone give me advise on the cancerous roof? Can it be fixed and stabilized? I can send pictues. any comments are welcome since I am new to this muscle car thing.
rebel48 in reply to Goat ChaserJul 2, 2010. 8:11 AM
all cars are painted completely at the factory the top must have damage which allowed water under the vinyl top. The water under the top probably collected under the chrome trim around the windows causing rusting. Removing the trim and old top repair the body damage replace the top and trim. A good upholstery person specializing in vinly tops would be your best shot. or repair and repaint leave vinyl top off.
bartpeeters says: Jul 2, 2010. 1:57 AM
Always heartwarming to see someone showing so much care and respect for a small old car and not just taking part of our disposable society.
zack247 says: Jun 28, 2010. 3:38 PM
hey dont forget that pacthing the rust will help keep your car on the road longer.
leandrop7 says: Jun 25, 2010. 10:43 PM
paint the whole fender so there will be differences in painting!
1-40 of 93Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
