3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Hack a computer atx power supply
Hi everyone, this is my first instructable and it's about how to Hack an ATX computer power supply and then put it in a nice little case so it's ready for use. I have made several of these before and decided to make an instructable about it. I will try to include as much detail in this instructable so sorry if I'm abit too wordy.
Yes i am aware that there are plenty of other hacks of this type but mine will be in lots of detail for anyone who has never hacked one before. This hack is paticularly useful when experimenting with motors, arduino or other mico controller circuits, to power a battery charger and any other electronic project that requires external power. I used the first one I made for about a year and it is still going strong, this is just V2.
First of all I would just like to say that the steps in this instructable are based around an Eagle DR-A350ATX power supply, unless you are useing the same power supply then the information in the instructable should be used as a guide only. I also take no responsibility for any injuries, property damge caused by steps given in this instructable, however if you follow the steps correctly you shouldn't have any problems. Also one final not you are working with potentially high voltages (paticularly inside the PSU its self) don't make the same mistake as me and work inside the PSU case while it is switch on or you may get a nasty shock.
TOOLS:
philips head screw driver
wire cutters
wire strippers
soldering iron
crimpers
files
drill with drill bits
Dremel (Optional)
MATERIALS:                                              COST
1 ATX switching power supply                $20 for a used one or pull one out of an old comp
1 switch                                                  $2
12 banana plugs                                    $ 14 (at jaycar)
1 project box/ tupaware container          $ 5 (at jaycar)
heat shrink tube
crimping connectors
various bit's of wire
zipties
superglue or epoxy
all of these materials can be bought online at jaycar.com.au
Plese forgive my spelling it is rather bad :(
Thanks and have fun
Step 1Removing the power supply from a computer case
  • last photo ←
You can skip this step if you already have your PSU out of the computer case if not then read on.
Firstly  you will need to remove the side pannel of your computer which is usually held in place by several screws on the rear of the case. Once these screws have been removed  slide the panel towards the rear of the case and then lift it up and out (Your case may be different). Next identify the PSU and disconnect all of the wires leading from it, now remove the four screws that hold the psu in place on the rear of the computer case. Now just pull the power supply out and your done.
17 comments
May 14, 2012. 1:57 PMLectric Wizard says:
Unless it is a very old supply the green wire is always the power on control. grounding it to the negative (black) wire tells the ps to turn on. It doesn't really provide a "Load" to the supply. Old supplies don't have a power on wire,they just sense the load.
May 14, 2012. 1:49 PMLectric Wizard says:
The 10 ohm resistor provides a .5 Amp load on the 5v supply. Some PSs will not start without a load & all Switch mode power supplies do not like running without some sort of load on them. (prevents that ka-boommmm sound) . If your are hooking more than one power supply in series, say to get 24v you need to "lift" the ground on all but the first supply, so that the grounds don't short out the supply below. This usually is as easy as putting nylon washers & screws in the mounting holes for the circuit board . BUT remember you no longer have the protection of a grounded output on that supply. Cheers!
Feb 6, 2012. 6:11 PMqazxsw21000 says:
So, let me get this right.
All we want to do is use a switch to short a black wire and the greed wire. Then we make it easier to connect stuff by replacing the disc plugs with whatever? If I am correct, which I am assuming I am, then I can go ahead and start hacking.
Feb 12, 2012. 8:49 PMpro5200 says:
I have a PSU from my old computer pentium II, I think you are way more simple than in other instructions that I have tried, without success, there is described using a 10 ohm resistor power> 10W, I have connected the red and black wires to the power resistor, and green wire to black wire I connected to the switch, but the psu still would not start, can you help me?
Feb 14, 2012. 8:41 PMpro5200 says:
Thanks for the comment,
as a refrence a 10 ohm 10 W power resistor, I found from this instructions :
1. http://www.instructables.com/id/Convert-A-Computer-Power-supply-to-a-Bench-Top-Lab/step2/Wiring-It-all-Up/
2. http://www.instructables.com/id/Converting-a-computer-ATX-power-supply-to-a-really/
I am a beginner in electronics, so I just follow their guidelines
BTW, I've let go of the resistor and just connect the green wire and black, as you say, but I still did not turn on the PSU, the PSU fan is not running. After I connect to the 220 V AC there is electric current coming out of each cable
I do not have a multimeter to test the voltage coming out, I've just check with the screwdriver test pen.
I am still confused so, to more clearly, if I had time I'll post my PSU photo : )
Feb 6, 2012. 6:00 PMqazxsw21000 says:
"(Make sure you unplug the PSU before you do this!)"
'Cause there is always that one person. I have seen something similar happen to my physics teacher. I had a transformer in reverse to a 12V linear supply. He didn't cut the power before touching the transformer. He took a slight shock and litteraly said, "Bad words."
Dec 7, 2011. 10:12 AMruss_hensel says:
On most of these supplies the ground is really the ground ( the wall ground ). Keep this in mind, as putting these supplies in series can result in a surprize.
Dec 9, 2011. 7:12 AMruss_hensel says:
Right 2 supplies. The ground may also ground circuits you meant to be floating. Still good and useful supplies.
Dec 6, 2011. 11:41 AMMarcaine Art says:
It does thanks :-)
Dec 5, 2011. 5:07 PMrimar2000 says:
Very useful, thanks for sharing. I am using one of these to move a cooler in my dorm.
Dec 5, 2011. 7:59 AMMarcaine Art says:
I'm curious what kind of applications this could be used for?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:HACKER_PRO
