Benefits of negative ions supposedly include
• freshen and purify the air
• help lift mood
• alleviate depression including winter depression(SAD)
• eliminate most tiny particles suspended in the air (indoors)
CAUTION
- HIGH VOLTAGES present in both devices is high enough to induce a bad case of temporary Tourettes. ie twitching/profanity.
- Be aware of the hazards when working with loose CARBON FIBRE filaments if using this option for high voltage grid instead of pins.
Remove these ads by
Signing UpStep 1Components and Design
- soldering iron and solder.
- screwdrivers, flat and star
- cordless drill.
- hot melt glue gun.
- wire wrapper.
5v to reduce current consumption and noise.
The half wave version uses fewer components and less current, the smaller size is also trickier to build.
In both versions the negative band on the diode must point towards the ac voltage input.
If you follow the green arrows on the component diagrams, you will first encounter the negative side on the diode first, indicated by the white band.
Two questions :
1. Isn't the total voltage too high for these capacitors ?
2. What would happen if I use 100v capacitors?
3. Would I get better performance with higher capacity capacitirs (0.56uf) ?
Thanks
So with tools in hand I first checked the Ioncare usb ionizer which was 2.65kV, the half-wave ionizer popped every diode after playing with ion propulsion so I dont know what its output is.
The full wave ionizer proved a bit tricky to record a voltage level. When at first it touches the output pins I see readings of 12 to 24kV but a steady 4.2kV when I clip the voltage divider resistors to the pins. Im guessing that my 100Mohm resistors place too much load on the ionizer hence the fluctuating readings.
Nice to know is that the usb ionizer uses 26.7ma (milliamp) at 5.26V DC, which works out to about 0.1399 mW which is why you cant see its power draw in the "windows usb power managment".
I dont know any calculations or formula for these devices, but the usb ionizer had roughly 600V after each diode/capacitor pair, with 4 diodes and 4 caps in total giving the 2600kV output....for what its worth.
Do you see a problem? Am I way out in left field on this one?
http://www.blazelabs.com/e-exp15.asp
I know almost nothing about electronics. I ask just in case ...
regards
I want an " negative ion canon" against these damm chemtrails!
Thank you kindly!
Is it wired just like the hand drawn thingy from this site: http://bigclive.com/ioniser.htm ?
Also I'm having trouble finding those capacitors, I'm not even sure what the 2x suppression means :)
Am I just looking for ceramic capacitors like on digikey: http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=131083 ?
For the 10Mohm resistors (1/4W) what kind of film is preffered? (metal, carbon or think film) or can I pick any? :)
Ceramic caps wont do the trick, these class x2 suppression caps, not 2 times, can be connected directly across power lines which is why they are used.
Heres a link to the exact product I bought, http://www.fort777.co.za/index.php?main_page=product_info&products_id=2618
I used carbon film resistors but metal film will also do.
so these caps: http://industrial.panasonic.com/www-cgi/jvcr13pz.cgi?E+PZ+3+ABD0029+ECQU2A104ML+7+WW would work as well?
I'd like to buy things from local stores if possible, as you probably understand :)
The reason for me pasting the link was merely for the item description so you would have something to search for, not to buy per se, but its all good.
Today, our modern homes and offices seal out negative ions. Computer terminals, fluorescent lighting, forced air ventilation systems, and modern building materials generate an over abundance of positive ions. Positive ions make us feel tired, depressed and irritable.
http://www.peakpureair.com/negative_ions.htm (good source of info)
When the amount of Negative Electric Ions contained one c.c. of air inhaled reached 5,000 to 50,000, it strengthens the body's resistance and immunity; and when the amount of Negative Electric Ions contained in one c.c. of air reached 100,000 to 500,000, it relieves illnesses. Negatively Charged Electric Ions in our body are essential in sustaining and improving our health. Whereas 85% of the Negative Electric Ions are absorbed from our skin, only 15% is inhaled and absorbed through our lungs. (quoted from page 56 of Negatively Charged electric Ion Treatment, issued by Youth Publishing)
Window AC s are the most convenient way of getting Cool.
