Remove these ads by
Signing UpStep 1Picking the Right Pencil
To make a spiraled pencil you will first need the right pencil. Shown here are three different types of pencils. The first is a six sided pencil. Sounds simple enough, but could prove itself to be difficult for the beginner. The second one is a Ticonderoga pencil, also six sided. Appaently the world's best. The wood on these are sometimes a little bit harder thus being tougher to whittle, if you have a sharp enough knife then go for it. The last is a colored pencil. It is completely round. Its shape will make it easier for beginners to practice on, although the hardness of the wood differs.
After you pick your pencil, you should decide whether or not you want it sharpened. If so, do it before whittling.
With that said, you're ready to start whittling!
would be great for 3D lettering or if you put several together putting lines on blank paper (removing the graphite from every other pencil could be good for makeing multiple copies of the same line maybe for cutting up later) a lot more stable than just a couple of rubber bands)
So far I've only done that with a candle :D Got to try with a pencil, when I have too much spare time :D
Keep them coming this is cool
This should give you perfect spirals every time.
Wanna share this with you, I think this particular show on History channel called "SLICED" is an offense to all engineers, showing the behavior of a spoiled child on a grown man, destroying valuable machinery and equipment.
PS: Nice instructable, very creative.
Wrap the pencil with masking tape, in a spiral pattern.
One edge of the tape JUST touching the opposite edge, on the next row.
Then, scribe in the line between the edges using your hobby knife.
Now, when you whittle away the groove, your edges remain "perfect".
Forgot to mention, using ONE piece of tape for the spiral layout will change the spiral a bit. It will leave you with no land (technobabble for the flat piece of the pencil left un-cut). Instead it will give you more of a screw shaped finished piece.
TO get this trick top produce the original results, bifurcate the tape and remove half. The part not covered by tape then is where you carve. It may be easier to mark the tape's centre BEFORE applying to the pencil.
On the larger scale, a hand saw and a mitre box are the easiest way to make them.
To do this sort of spiral work on a lathe, you need a VERY specialized setup, with a router on the tool post, gear driven feeds, and head rotation. In fact, the lather isn't used as a lathe at all, but instead uses the head and tail stock as mounting points..
http://www.creativespotlite.com/woodworking/spiral-wood-turning.htm
As you can see it is actually quite complex, as fast as wood turning goes.
