How to Make a Wooden Flower
38,007
432
19
Posted
Introduction: How to Make a Wooden Flower
You need a decorative element on a present? Follow the instructions in this post to create a great looking wooden flower.
Please also watch the video on YouTube about this build and subscribe to my channel!
Step 1: Materials
  1. A hand plane. For example a Stanley No.4.
  2. A hot glue gun with glue sticks.
  3. A pair of scissors.
  4. A piece of wood.
Step 2: Create Shavings
Set your plane up for creating relative thick shavings. Try to keep the
thickness consistent. You will need between 15 and 20 usable pieces. The rest of the scrap wood will be used as a base later.
Step 3: Cut the Petals
Take your pair of scissors and the shavings.
Now cut the shape of a petal out of each shaving but instead of a pointy
end cut a flat edge which we will used for gluing later. The grain and curl should run along the width of the petal. Do not try to be too accurate. Imperfections and different size will let it look more natural. You will need about 15-20 petals for one flower.
Step 4: Glue the Flower
Next take one of the smaller wooden petals and roll it. This will be the
centre of your flower. Use a blob of hot glue and stick the first piece to the base. You can cover the base with tape to keep it more simple to separate the flower and the base later.
Repeat this with as much petals as you need to get nice big flower. The
bigger the flower gets the bigger the petal pieces and the more flat the angle should be. In some cases you can secure the petals with an extra beat of hot glue. Adjust the pieces as you go and as I said imperfection makes it even more realistic.
Step 5: Enjoy the Flower
You should finish the flower with spray lacquer to protect it and keep
it stable. Otherwise the petals will curl unevenly when the moisture changes. You could also spray it with a colour to get an even more natural look.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
19 Comments
Do you have plans for any other type of flower(specifically Carnation)? COOL Idea.
What type of wood did u use?
It was just a scrap piece of spruce from a 2x4.
Ooooh something that doesn't require major investment in tools and materials. Will have some cut offs when ive finished my book case so will have a go. Thank you
Well made and explained true!
Well made and explained! Will have to give this a try when I'm in wood shop or whenever I find my planer (too many times moving)! I wonder how it'd look with some of the exotic woods!
I love this idea! Wish I had a hand-plane so I could try it.
I think this is so cool.
Love it , Looks so real
Great idea! Very easy and simple. Would you paint it to make it look more real?
