3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Revive an Old Motorcycle: Save Money on Gas/Fuel! Cheap Ride!
Motorcycles are a lot of fun. They can also make for cheap and convenient transportation. I will try to describe a few easy steps to revive (salvage) most old motorcycles. You would not believe how many motorcycles are ridden for 5-10 years and then just parked in a shed or barn to rust. In my experience, I've been able to save about 80% of the old bikes I get, with about $25-$75 in parts and 3-6 hours of work. I've been given several old bikes because someone just wanted them out of the way. I've bought others for less than $250, and ridden them thousands of miles. Hopefully this instructable will give you the information you need to do the same.
NEW NOTE: The response to this instructable has been really good. I hope to do another one related to slightly more advanced/unusual issues related to saving old 2-wheelers. I've had a lot of good suggestions (Tires, exhaust,points, etc.) that I hope to include next go round. Thanks for your enthusiasm and your continued patience!!!
Step 1Choosing Your Bike : Better Safe than Sorry!
First of all, any free bike is a good bike, even if you just use it for parts. When it comes to actually buying a fixer-upper, you need to check a few things before you lay your money down. The three things (put simply) that a bike needs to run are fuel, fire and compression. These suggestions are for when you purchase a non-running machine.
1. Is it all there? Many broken parts can be repaired easily and cheaply, but missing parts must (usually) be replaced. Pay special attention to gauges, side covers, carbs, sprockets, and brakes. Lots of these parts "walk away" while a bike is lying around unused.
2. Is the engine seized? A seized engine may or may not be a big deal. If you buy one with a seized engine, only pay scrap prices as the engine MAY (or may not) be ruined. I'll show in a later "Ible" how to deal with a seized engine.
3. Can you shift through the gears? Transmission work is no small undertaking (but not impossible) for the newbie!
4. Does it have compression? If you can kick it over (or crank it), check for compression.
5. Consider buying a semi-classic, as these machines are easiest to deal with when searching for replacement parts.
248 comments
1-40 of 248next »
Jul 27, 2008. 3:15 PMfonz91 says:
Re: Step #4: Some petcock/fuel valves have a vacuum line running to them, and fuel won't flow unless there's a vacuum. Hook up a vacuum pump to test in those cases.
Nov 14, 2010. 3:47 PMcrpt says:
Hi all
For vacuum pump I usualy use a syringe. Works great and it's cheap :)
Apr 1, 2012. 6:59 AMpeaksprt5 says:
Be careful with older carbs. The metal is softer and if you use too much torque on the screws they strip easily. Rebuilt my fist carb which was a 78 Honda Goldwing. I stripped about 5 float bowl screws because I thought they needed to be tight. A good gasket will keep the fuel in. You don't need them super tight.
Jan 31, 2012. 3:31 PM7070x says:
For much less of hassle, it's worth of getting NEW plugs at any case. I used to ride 1962 Vespa (piaggio) two strokes engine that required me to clean dirty plug so often. Real pain in the butt, though actually what I usually did only sand off the poles of plugs and bend it inward somehow makes it easier for it to spark.
When doing this, also check the spark plug cable derived from the coil. Often, connection isn't so free at this point. What I'do: unscrew plug from its house, cut the outer skin of plug cable about 2-3cm. Roll up the bones, make them neat and clean. Put it back on. Check if it fires again (kick start it) and connect it to (-) ground.
Jan 4, 2012. 3:43 PMpotato413 says:
Any advice for places to find bikes to restore under a grand? Im looking for something like a cb750 to fix up but cant find anything on craigslist...
Dec 6, 2011. 10:22 PMjonnyjeas says:
This awesome
Aug 19, 2011. 3:25 AMmrlunna13 says:
Hello,
Do you know, or do you know if there is anything in here about a seized engine, or have you done the "ible" on a seized motorcycle engine?
Thank you,
Jesse M.
Jul 28, 2011. 6:00 PMabadfart says:
o i need some help on parts i cant find any body that caries the o-ring on a pipe that goes between carbs
Jul 29, 2011. 12:05 AMabadfart says:
thanks iv been looking all over the web for some that will work
Jun 11, 2011. 6:38 AMmastermakoko says:
hey im looking forward to buy and restore a honda cb100 is it an good?
Is it recommended for a person with no expertise whatsoever in bikes to take care for it?
Aug 25, 2010. 2:09 PMabadfart says:
how do people feel about bikes with automatic transmissions?
Nov 14, 2010. 10:15 AMWolframite says:
I didn't even know they made them.
Jan 13, 2011. 7:59 AMKevanf1 says:
Both Honda and Yamaha have made them for years. They were similar in looks to a scooter but with slightly larger wheels and more stable for it. They were commonly known as 'step thru's' and came in 50cc, 70cc and 90cc engine sizes. Fantastic and very, very long lived commuter bikes. My grandad had a Honda 50 about 40 yrs ago. Though, to be honest I preferred his Matchless that he rode in the 1950's :-)
Take care.
Kevan
May 19, 2011. 11:14 AMbeltenebros says:
love Matchless. I have a 1959 AJS Model 16 myself ... the original!
May 19, 2011. 12:40 PMKevanf1 says:
They certainly made some amazing machines. I recently had the pleasure of having a little ride on a modern Triumph Thruxton 900cc. Got to say, WOW!!!! It was fantastic. My wife wasn't too pleased as she always says, "you are not having another bike". This is because when I was 17 I was extremely lucky not to have been killed when I hit the rear of a wagon at 90mph. I did not even break a fingernail... Yes, I've had bikes since then but I have also succumbed to very severe arthritis. One day though... one day.
Aug 27, 2010. 8:34 AMabadfart says:
ya but they are asking 125 usd for it im just wondering if its worth the cash
Aug 28, 2010. 2:17 PMabadfart says:
ya the breaks and carbs are gummed up and the tank needs cleaned. its a honda which i have always liked.
Feb 11, 2011. 11:56 PMabadfart says:
i am thinking about flipping motorcycles i am now riding my cb 650 custom but am looking at a 76 goldwing to fix and sell to buy more and do the same. my home town is very scares on jobs and i think i might be able to make a living off of it
Feb 16, 2011. 9:25 AMabadfart says:
ya i have my full automotive stall set up at my parents house with the carb bath an left with a nice big bench so i might as well make use of it
Jan 13, 2011. 8:05 AMKevanf1 says:
Good 'ible' :) I love those old Suzuki GT models. I used to own a 250 that was sadly not as good as the older Hustler and Super Six models. I had mates who had 185cc, 550cc, 750 (kettle) and the 380cc models. I wrecked mine at 90mph 30 yrs ago. Thankfully I came out of it without even a broken fingernail. I'd still love another one now but they are pretty rare nowadays.
One tip with those GT models. Replace the swinging arm bushes. They are only made fo a substance called Tufnell and are dead easy to replace, no presses needed. Make sure the rear shocks are good and replace the fork oil. All fairly cheap but potentially life saving little jobs as they improve the handling no end.
Take care and ride safe.
Kevan
Oct 17, 2010. 10:58 PMabadfart says:
i picked up this 1980 Honda cb650c for $400 and it was running but it stalled on my way home and it turned out that i was only running on three cylinders so i cleaned the carbs and now its only firing on one but i have full compression.
Oct 18, 2010. 8:49 AMxfirexstarzx says:
Hmmm, this might sound stupid, but how much gas do you have in it?
Is fuel flowing out of the lines going into the carbs if you detach them and turn the gas on at the tank?
What did you do to clean the carbs? Did you clean all the jets and blow out the idle circuits with compressed air or carb cleaner?
If all else fails, try new plugs.
Oct 18, 2010. 4:58 PMabadfart says:
i used a bath and soaked the carb parts then put them back together that didn't work so i replaced the fuel line but thats because somebody had trimmed it to nothing at all so i gave in and got 4 new plugs and it is now running but its slow jets are gummed up on the right 2 carbs. i got my bags on today and will be putting a windshield and highway pegs with a stereo on latter and im having my friend paint the tank. and im just going to ride it for a couple of days and see if it fixes the slow idle.
Oct 18, 2010. 7:53 PMxfirexstarzx says:
If the jets are gummed up, the best way to fix it would be to remove the jet, take a small piece of wire (like from a wire brush), and poke all of the crud out of it (be careful not to scrape the brass), then blow it out with compressed air or carb cleaner.
Oct 20, 2010. 10:47 PMabadfart says:
ok its running now but i need to sink the carbs but i don't want to spend the cash on a balancer. i think i see my next instructabul
Oct 24, 2010. 4:01 PMabadfart says:
how do you do it by ear
Oct 23, 2010. 5:39 PMabadfart says:
well i think I'll try this and tune it up
Jul 27, 2011. 11:03 PMabadfart says:
sad day i got it running and balanced but then i sprung a fuel leak and am now waiting on a new set of o-rings from e-bay
Aug 5, 2011. 8:50 PMabadfart says:
well i got new rings at a Yamaha shop and got it balanced using my Frankenstein carb balance but am now having trouble with hard acceleration, if i role on the throttle slowly it works fine but if i crank on it is splutters, pops and smokes. im thinking it could ether be a air leak or the less pleasant bad accelerator pump what would your thoughts be on this?
1-40 of 248next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:skunkbait
I guess I'm one of the "old" guys on this site. I am 39. I've got a wife and 2 sons. We live in the country and due to finances have a serious DIY mentality. We homeschool the kids. When it's no...
more »
