It is important to know that these procedures will NOT void warranty. However, if your phone has been water damaged, there is a large chance your warranty is already void! On newer phones, there is usually a sticker in the battery bay that is used to tell the manufacturer when a phone has been "water damaged" which allows the manufacturer to then cancel the warranty. This sticker is usually round in shape, and starts off white when it is not wet. Although, I think my samsung a900M started with brown and went to black.
If neither of these methods work, and your sticker is still it's original color, try to have your phone serviced under warranty.
CAUTION: Before attempting ANY method in this instructable, remove the battery, battery door, and SIM card if applicable, and place them in a safe location!
DISCLAIMER: I am not responsible for any damages to your phone as a result of you attempting any of these methods, do so at your own risk.
Remove these ads by
Signing UpStep 1Understanding the problem
This is due to the conductivity of water (It's ability to have electrical current pass through it.) This moisture can bridge certain connections in your phone, causing these behaviors.
Even though your phone may behave fine at first, it is better to dry the phone before use anyways, as the water that remains inside can be moved around, and cause issues later.
So what to remember, is that after exposing your phone to moisture, you want to nullify the moisture inside.
You need to dry it out more, it still has some water in it...
Longer answer:
Hmmm, if you can make/receive calls I assume your screen is displaying, but the capacitive touch screen is not receptive to input. Here's a quick illustration to understand what's happening. With my palm, if I swipe, or touch the screen it works perfectly. However, if I put my thumb in the corner of the phone while manipulating the touch screen it does not respond. My phone gets confused if more than one input is attempted via the touch screen. In your case you probably still have some water left in the phone. When it was left overnight the (conductive) water condensed, or dropped into an area where it could change the capacitance of the screen, and thus mimic'd my clumsy thumbs. When my phone stops responding I remove my thumb...when yours does, you need to remove the excess water.
1. Took back off of phone
2. Removed battery and SD card
3. Soaked phone, battery, and SD card in 91% Isopropyl Alcohol for two minutes. (that may have killed the battery for good...I'm not sure...but the battery did not survive.) The idea is that the alcohol will displace the water and then evaporate quickly from all the conductive parts.
4. Shook phone back and forth for a minute or two to work the excess alcohol out of the phone.
5. Used a vacuum with a very tiny nozzle to suck up moisture that I could see.
6. Used a blow dryer on the back of the phone while switching between low/med/high so as to not overheat the phone circuitry and whatnot.
7. While I don't think I needed to do this, I unscrewed the 6 screws on the back and to closer to the phone circuitry (I found a video online showing me how to do this properly.) To my amazement, by this time, I could see no visible moisture.
8. Seeing the success of the oven idea above...I figured I stick the phone on a hot pad in the toaster oven on 125...I got nervous about it and took it out after 5 minutes or so.
9. I considered the rice...but I felt too impatient. I decided to throw the spare battery in it and see what would happen.
10. IT WORKED!!!! Perfectly. Swyping the screen worked. The touch screen had no degradation. Camera worked just fine. Phone calls worked. No degradation of sound quality. Missed text messages starting rolling in.
Hope this helps somebody else out there!
After removing the battery and simm & memory cards, I first rinsed it in water and put it into the oven at 150 for 20 minutes. No luck. Saw moisture on the touchpad, so I tried it again for 40 minutes, but still no luck.
Then today I froze it and it worked till it thawed out and then it stopped again.
Finally I took it apart enough to loosen a circuit board to give it some breathing room. Then soaked it 70% isopropyl (I know you said 91%, but all I had was 70), and then put it back in an electric oven at 150 degrees for an hour to dry out the alcohol. I let it cool in the oven and then reassembled it. Viola - it all works except the camera, which I hardly ever use anyway. My main use is for calls and my schedule calendar. All data is still there - wheew!
I priced out a replacement and phones would have started at $150.
I successfully baked my wet cell phone on 125 for 40 minutes and the phone is now fixed. Thanks for your methods the unverified baking method in now verified.
Great site
Carol
++++=sticky
like this:
so that it won't delaminate :D
Then there's my other phone... went in the washing machine for about half a hour... Yep..... not comin back either...
*Frowny face*
