Parts that may need to be ordered online:
Negative Ion Generator (Ionizer) (I bought mine here: http://www.allelectronics.com/ Search for SW-750) UPDATE: It seems that source of ion generators has been depleted. Here is a new one: http://www.goldmine-elec-products.com/prodinfo.asp?number=G1783
Automotive Power Converter (Cheapest here: http://www.amazon.com/gp/product/B004I1LF7O/ref=oh_details_o00_s00_i00 Or find one at an auto parts store)
Parts that can be purchased in a hardware or electronics store (Such as Radio Shack):
Flux Core Solder
2" of Copper Wire
Heat Shrink Insulating Tubing (Optional)
9 Volt Battery (DO NOT USE A LARGER POWER SOURCE! Doing so may be DANGEROUS!)
9 Volt Battery Harness
On/Off Switch (Any type will work, even a light switch if that is all that is available)
Sticky Back Velcro
Dual Sided Velcro (Usually found in the form of cable ties)
Glasses Case
1 Gallon Bottle (Such as a windshield washer fluid bottle)
Hot Glue
Aluminum Soda Can
Duct or Electrical Tape
Tools:
Soldering Iron
Screwdriver
Scissors
Wire Strippers
Hot Glue Gun
Sand Paper
Drill & Bits
File (Optional)
I was inspired to create this video when I read the article posted here: http://fear-of-lightning.wonderhowto.com/how-to/master-power-shock-people-with-your-fingertips-0133360/
That article is based off of the information provided in this even older article: http://afrotechmods.com/cheap/negativeiongenerator/pikashoe7.htm
Both of the above use a design that contains the generator within a pair of shoes, but I decided that it would be better modified into something that could easily be strapped on and off over anything the user happens to be wearing. The design used in the article also has a nasty habit of shocking the bottom of your foot quite frequently.
![How to Make an Airsoft/Paintball Landmine [HD Video Tutorial]](http://www.instructables.com/files/deriv/FXB/1QR5/GQ5QCIVI/FXB1QR5GQ5QCIVI.SQUARE.jpg)
![How to Make a Full Auto Airsoft Minigun [Halo Inspired Mobile Turret]](http://www.instructables.com/files/deriv/FYY/GVFO/GQPNUR7E/FYYGVFOGQPNUR7E.SQUARE.jpg)
![Mini Catapult - Office Survival Trap [HD Video Tutorial]](http://www.instructables.com/files/deriv/FAN/YNM3/GSUT1CZ8/FANYNM3GSUT1CZ8.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
I'm glad you tried it first though to save the trouble. Great project!
I found the 9v,though it works as intended, to be under powered so I am now using a 11.1v 800mah rechargeable lipo made for rc vehicles. It has improved the power greatly and they only cost about $8.
I already had a similar,profesionaly buit, gadget that is designed foragic performance that runs on 12v which is the comparison that made me find the 9v weak.
All that said this was an excelent write up as I have wanted to build myown for some time now. Thank you.
http://www.ebay.com/itm/anion-generator-for-clear-smoke-air-condition-DC12V-input-purifier-cleaner-DIY-/390589310924?pt=LH_DefaultDomain_0&hash=item5af0efe7cc
http://www.amazing1.com/products/Negative-Ion-Generator-12VDC-Input-%252d20KV-Output.html
would this work to replace the sw-750 ?? this is the closes thing i can find.
Say, would an Ionizer found inside a cool-mist humidifier work for this project?
It looks pretty much like the one you have here (Black epoxy filled case), it has two AC input wires and one output wire (Mine has a little brush at the end).
When active, you feel a bit of wind flowing out of the brush, with a very faint ozone smell.
I plugged the ionizer in, and felt the wind, I tried getting the brush close to grounded stuff, but no sparks. Is that because of the brush? should I just cut off the end of the wire and try again?
Got ripped off on ebay, beware everyone...
go to the beach
and turn it on it would b a self sandstorm
I'm currently living in Sweden, which means that the goldmine cant ship it to here. Can you recommend any similar other models I can get shipped to over here?
(Im asking this after searching for several hours)
If you guys can see something that i am doing wrong please respond. Thanks
What happens if the red wire is pinned to the ground and you hold the black wire? I have no idea how the direction of flow might be reversed, but it sounds like that might be what has happened - In which case you will need to extend the red wire and pretend that is the ground, while the black wire leads to your body. Be sure to test and make sure that will work as best you can before going through the trouble to modify it.
http://www.ebay.co.uk/itm/DC-6V-12V-air-ionizer-ioniser-airborne-negative-ion-anion-generator-compact-/120989848269?pt=UK_HealthBeauty_Other_RL&hash=item1c2b8e92cd#ht_628wt_1139
Or could anyone help me find one. what voltage does it need I've seen 100v/200v and 6v/12v
Please help! Much appreciated thanks!
can i try with a 12V batery??, the car inversor is new. >.<
thanks so much! :D
