How to Surface Mount Solder Using Solder Paste
Introduction: How to Surface Mount Solder Using Solder Paste
Quick tutorial showing how to solder a Attiny85 package type SOIC-8 using a hot air tool and solder paste.
SOIC is just one of the many types of standarized packages that integrated circuits such as the Attiny85 can come in. The package type just indicates the components will look different and have the chip's legs accessible in different styles.
This is a free hand soldering paste technique using a Hot Air Soldering Rework Station but you are more than welcome to make a stencil from OSH Stencils!
Questions, Concerns , Compliments, Feedback all welcomed:
Step 1: What You Will Need
1. SMD291SNL ‑ Chip Quik Solder Paste (recommended to use because it comes w/ a fine tip syringe)
2. PCB board (I'll be using Adafruit's SOIC-8 breakout board)
3. Components being soldered (I'm using the ATtiny85)
4. Fine tip tweezers
5. Hot Air Soldering Rework Station/ Or a skillet,oven you feel comfortable using for SMD work
Step 2: Find Something to Hold Down the PCB
I'll be using my favorite vise the PanaVise 350 Multi-Purpose Work Center.
However , use whatever works best for you (small vise, tape, wood,clamp etc)
Step 3: Dispense Solder Paste Onto the Copper Traces
Squirt a line that spreads over the golden pads (copper pads)
Don't worry about getting the solder paste on the blue part of the PCB (solder mask)
Once the board is heated the solder mask will repel the solder paste to shrink & harden onto the copper pads
Step 4: Apply Heat to the Board
I used a the Hot Air Soldering Rework Station - Quick 957D under low air control at about 370°C
Alternatives include kitchen : skillets and small ovens just use with caution and continuous monitoring
The solder paste go through transitions from liquid-->dusty-->shrinking till it finally hardens
Step 5: Finished!
Here is the finished Attiny85 SOIC 8 pin package type soldered into the breakout board
-Happy soldering!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Pro Tips Challenge
    Pro Tips Challenge
Would that be too much solder paste for an SSOP or QFN package?
This old electrical engineer just learned something new!
Wonderful, and thanks NemesisC!
Most of the smd device datasheets I have seen state a max of 250C in the reflow oven settings. I have a reflow workstation with adjustable airflow and temp settings, and have to mount a SOT-23 on a DIP breakout adapter. I'm wondering if I need to go up to 370C, so I'll be trying 250C. I think the trick will be to set the airflow at just enough to melt the solder but not strong enough to push the breakout board out of my panavise.
I would also like to mod a toaster oven, but do not have a source for used ovens, so if anyone has an article on modding current-ish model toaster ovens, I would really appreciate it. Tia!
Definitely I'm mostly very impatient and want instant melting -however not always a good idea! Yes having a low airflow helps a lot expecially when the component begins sliding around. Have you tried to use silly putty/tape to hold down the component? I've been told it works wonders
Awesome instructable! Personally i prefer the skillet method but this is mostly due to the fact that ive been doing it forever, i do all my PCBs 100% SMD. A cheap skillet on the stove sure beats trying to solder 50 components by hand lol.
Thank you Chris! Would you recommend any nice quality affordable skillets?
To be honest just about any skillet will work. Im using an old one we had in the house (my mom burned chicken in it so she didnt want to cook with it anymore) the one im using has teflon which is great because the boards are easy to slide around. If you can find one at a thrift store that has a pretty good surface i would buy that and experiment with it. The hot plate method is great with parts containing a lot of plastic. Hot air tends to melt the plastic on things such as usb ports really easy. Hope this helps :)
True, for this type of component it is not worth using this method.
To save time it is.
