The idea is to build a replica of the Daft Punk Table sold at Habitat, very nice, but, as long as I know not sold anymore. The building process is not...
Ok! As many people has written me after watching the youtube videos, interested in the construction of the table, i'll write a quick'n'dirty guide exc...
The second thing I made was to buy the plexiglass, just the same dimension as the squares. These are the first tries with leds in the squares. The ple...
The inner structure of the table, from wich the glass will be suspended is made in MDF in my replica. If anyone has the intention of constructing one,...
So the joints where these typical wood joints, with some screw reinforcements… Combined with wood glue they make a quiet robust joint, so the structur...
Well… so I will explain briefly how I made this part… Each square has 8 red hight brightness leds inside no oriented upwards so the light difusses bet...
Maybe one of the riskiest parts of the construction. I covered the table with grey 10mm glass. All the glass was about 180 euros with the sharp edges ...
I recorded this video with the table connected to winamp, as you can se the table is synchronized with the music...
The idea is to build a replica of the Daft Punk Table sold at Habitat, very nice, but, as long as I know not sold anymore. The building process is not very complicated, the hardest part is to decide everything when your starting point is zero. I could get some ideas about the construction of the table like the use of "carton pluma" from Mathieu, a french guy that made one before I made mine. You can see Mathieu's table at: http://www.dailymotion.com/miniDaftPunkTable This is one picture of the table i constructed myself. You can get more info on http://mrgalleta.wordpress.com/
Step 1: Let's get started...
Ok! As many people has written me after watching the youtube videos, interested in the construction of the table, i'll write a quick'n'dirty guide excuse my English, but I'll write this very fast and English is not my native language.
So let's begin constructing the daft punk table replica. The materials i used for the table where MDF and 10mm grey. They produce an overall impression very similar to the original one, if not better. Under the glass there is a red plexiglass square and the 5x5 division are made of "carton pluma".
Its a good idea to put a sheet of difuser like thick onion paper on top of these squares so the light of the leds difusses through the red plexiglass.
Step 2: The red plexiglass...
The second thing I made was to buy the plexiglass, just the same dimension as the squares. These are the first tries with leds in the squares. The plexiglass still had the plastic protection. Probably the plexiglass is one of the most expensive materials to buy (apart from the glass, of course). I think I got this piece for about 35€(I was lucky the had some cut rests I could use) in a Madrid shop.
Step 3: Inner structure...
The inner structure of the table, from wich the glass will be suspended is made in MDF in my replica. If anyone has the intention of constructing one, I would recommend a less dense wood, since MDF is extremely heavy. It was 19mm thick MDF, i think. I bought it at C/Madera in Madrid City and it was quite cheap. So after taking all these to home (the hardest part) I verified the dimensions of all the parts joining the elements with adhesive tape.
Step 4: Joining and Painting
So the joints where these typical wood joints, with some screw reinforcements… Combined with wood glue they make a quiet robust joint, so the structure can support the glass weight… You have to consider that if you use 10mm glass you can get a final weight from about 40 Kg just in glass….
After this, the next is painting it in black. I used a water based paint that doesnt smell with matt appeareance. The paint is not a critical point since it wont be perceived through the glass.
Step 5: Electronics
Well… so I will explain briefly how I made this part… Each square has 8 red hight brightness leds inside no oriented upwards so the light difusses better. It makes 200 total leds, it’s a bit boring to solder so many leds… The control of these leds ia made with a PIC 16F876A Microcontroller. The control software is in C and I made a software in order to design the sequences. The sequences are changed via RS232 communication when I play music on Winamp I programmed a PlugIn that synchs the table with the music bpm’s… Maybe all the software stuff was one of the easiests and fastest to develope as I have long experience with the subject.
So… the PIC receives the signal via RS232 (I will make this communication via Zigbee when I get some Xbee modules) and transmits them thorugh I2C to PCF8574 that make use of the ULN28003 in order to get enough current to feed the leds…
So here are some pictures of the soldering process (It was quiet boring and the results are not very well looking, but none will see the soldered board):
Step 6: The glass
Maybe one of the riskiest parts of the construction. I covered the table with grey 10mm glass. All the glass was about 180 euros with the sharp edges rounded. The original table has some parts of the glass joined with glue, i think, but as my table was becoming so heavy i wanted a system to suspend the glass so you could unmount it. I made this modifying some coat adhesive hangers and painting them in black, there are four hangers for each vertical glass i think the result was quiet good .Now there are some pictures of the table without the glass and with it:
Step 7: So here it is!
Thanks for your attention, i hope it's useful for someone...
Step 8: The table in action...
Is there any chance that you could put up a link or something of the scematics you used to build your boards both for the control side and the LED side?
Hi - nice table! I'm looking to build one from your instructions - do you have the winamp plugin and circuit diagrams available. Any help very much appreciated.
Making your own? Want a head start? I have 25 LED boards for sale that I built in surplus supply to build a few of these. There are 8 on each PCB board and are 70000 mcd each. Worth a bit of cash and also time. Grab yourself a bargain... Follow this link.
What about using an LEDWiz to control it? I think that'd make this pretty easy, and just use the "LEDBlinky Animation Editor" to control its animations. You could also use the "Luminaudio™ Engine" software for the LEDWiz to make it beat to the music. I know that kinda takes part of the "homebuilt" aspect out of this project, but it'd get it running until you can make your own controller.
is it possible to detect the beats of the music with a microphone or something like that, or just connect a jack to the computer or whatever is playing music? My friend has a flashlight with LEDs that when you clap or make a noise, it turns on, you clap again and it becomes brighter and brighter, etc... so i was thinking of using something like that since I don't want the table always connected to the computer every time :\
Yes, you could make a circuit like some kind of sound activated light, maybe with a low-pass filter to filter everything but the rythmic section od the song and send a signal to the controller board in order to change the sequence at that time.
Bonjour, ou est posé la plaque de plexi? juste en dessous de la plaque en verre? sert elle juste a bien diffuser la lumiere? faire des "beaux carrés? merci de vos reponses
et bien il faut être calé pour pouvoir construire cette table... Surtout au niveau du contrôleur. Peux tu m'éclairer un peu plus sur la manière a procéder pour un néophyte? merci
Hi folks, I need your help here I have an original daft punk table and the RTA switch (pictured) has burnt out. does anyone know the correct indexing and switch function I need to order a new part? Any help would be appricated as Habitat no longer deal with the supplier and I need to fix this myself. I have also attached the pdf for the company who supplies the RTA switch. So far I think the order code I need is: RTA - P - 3 - ???? - ? - 25N - S Thanks folks.. Trevor
Now THAT'S the perfect fusion of art and technology! Great job! I'm not sure if I could build this given the missing details in this instructable, but I don't think I would anyways due to all that soldering I'd have to do!
great instructable, I always thought that it would be nice to build one of these, but I worried about the finish. Looks like you have done a fantastic job of that though.
I finally finished building this and the one problem I am having is the brightness of LED's. I am using 6 LED's in parallel. They are 12000mcd. When I tested them with a 9V battery they are super bright, but because I am scanning the matrix with the PIC and bcs of PWM, they become dimmer. I would really like them to be brighter. Did you use any reflective coating on the inside barriers to spread the light better? I am currently trying aluminum foil
aluminum foil won't help, and actually may hinder the propagation. best bet is mylar, and white (titanium white) paint is a good choice too. i know it's counterintuitive... get a light meter and check it out! peace.
Hi, No, I didnt, but that maybe help, the inside of my cells is just white paint (not very shiny finished), and one fold of diffuser thick paper (called "onion paper" in spain) just bellow the plexiglass...
What is "Carton Pluma" in English? Cardboard box? And are these LED lights, the kind with pins, or the "bullet" type with a brass metal base that holds the resistor? Sorry, I don't understand electrical stuff, much less the programming. Anyone?
Wow, I can't believe I missed this instructable! I thought I've seen most of the -ibles on this site, guess not! Very nice table, are you still using it?
Also, I'm working on making thomas' helmet from Daft Punk. Thought you might want to see it when its done..
I made a similar table a few years ago. but not with the reactive lights. mine had boring lights that were basically individual flashlights hooked up with a centralised control pad/switch board powered by a AC adapter. I had no money so I went mega cheap and used 16 milk crates. bolted them together. plywood around the outside. Found a sheet of shop window glass - i.e. thick - which I cut to shape with a diamond angle grinder disc (really rough cut - use safety goggles and really really clean up after) then with black PVC tubing cut and glued around the edge of the glass. - otherwise it would have been a vein opening experience within minutes. painted the underside of the glass with "stain" paint for color cost me $12. No where as elegant as this puppy. your table is very very very cool. very very very professional. my hat goes off to you Mrgalleta
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Has pensado en poner Leds RGBs.???
Nice job.
Is possible to share the schema and Hex ( or MiKroC source file)
My best regards,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250464782332
http://www.zebramelody.com/artist/#Daft%20Punk%20vs.%20U2----Around%20the%20World%20On%
20New%20Year%27s%20Day----idAddjRBpEg
