Remove these ads by
Signing UpStep 1What do I need to build a laser?
Basically, you need:
laser diode (LD)
collimation optics
current regulator (aka driver)
power supply
heatsink
something to house all the electronics (project box is ok for a first build)
then you can add other optional things:
safety switch
LED for power indication
cooling fan
etc...
3v,
4v
or +7.2V
Why do you think we have to deal with n00bs crying about their dead Laser Burning Flashlight Hack?"
lol that was funny :D
There's something I don't really understand:
16x...200-250mA...<200mW
22x...300-400mA...250-300mW
In these examples, it means that the diode will run at
U=P/I = 200mW/250mA = 0.80V
U=P/I = 300mW/400mA = 0.75V
Isn't that voltage Really low?
Datasheets say that a dvd burner diode runs at +- 4V ?!
Also, the power (e.g. 200mW) is that electrical or optical power?
And what is the average efficiency value of a DVD burner diode?
(Output power / Input power)
http://www.lasersurplusparts.com/images/LEC_LPC-815-red.png
i did every thing as you did but i can't get the laser to burn, could you please help me? i used the same parts (laser diode, parts for the driver).
2. is the laser focused?
Output: at 5V, max 11A, 85W max
at 12V, 9A max, 160W max.
i have tested at both voltage. and the beam is focused
Actually lilbit confused of what axis module to purchase,in axis store I saw various 12*30mm modules but these have different specs ie,
1>AixiZ 120° Line Generator for 12x30mm Housing
2>AixiZ 38° Line Generator for 12x30mm Housing
3>AixiZ 60° Line Generator for 12x30mm Housing
4>AixiZ 89° Line Generator for 12x30mm Housing
5>AixiZ 9mm Cross Hair Lens for 12mm Casing
donno which one to purchase so that I get a maximum burning with LPC815 Red Laser Diode.
http://www.modwerx.com/shop/laser-modules-spare-lenses-c-12/laser-focusing-module-for-5-6mm-laser-diodes-adjustable-focus-p-11?zenid=9sdhugjbn2mlu9l9iofhho6mf1
and to get the most burning power, you need this AR coated lens:
http://www.aixiz.com/store/product_info.php/cPath/28/products_id/60/osCsid/c2d8dafd1f5eaab5671f0e8ee4d64784
I have some more questions so plz respond
1>I will purchase TrustFire TR-001 Multi-Purpose Lithium Battery Charger but which battery will be best suited for this project plz mention type,made & manufacturer.Plz give the site name if possible,from where shipping is low or free cuz I live in India.
2>I want to use LPC-815 diode with it with asiz module,does glass less increases the efficieny about 10 to 15%
3>U mentioned to use a good heatsink,my heatsink has 2.2cm*1.5cm*1cm is it ok.
4>Is stonetek corporation is good for buying LASER HEATSINK MODULE & LASER DIODE?
5>I want to buy blue laser diode,plz mention which will be most powerful which are commercially avaiable(plz mention the site name if psble)
6>Is LM-350 can replace LM-317 in this project as LM-350 can handle 3amps with same refernce voltage as lm317 as a result less geat will generate n smaller heatsinks can be used,plz give suggestion if I right or wrong
thanks in advance...n sorry for asking out of syllabus qestions
2. the glass lens should be a bit more effective, there are also lenses with AR coating for red lasers that can increase the effectivity with about 10%
3. the point is to make the best contact between the laser module and heatsink. see the "Final phase" step for inspiration on this
4. stonetek is very reputable and has 100% reputation
5. what wavelength (or color) do you want? 405nm (violet) - the most powerful diodes (known as the "12x") can be pushed to 500mW and more; 445nm (blue) are commonly run at 1.2-1.7W. iirc, both can be bought at stonetek but I strongly recommend you that you should first build some low powered cheap red laser, practice diode harvesting and soldering, BUY PROPER LASER GOGGLES and only after that startt building high powered lasers.
6. LM350 can be used, but you must still heatsink it
1>want to know that if I use Li-Ion batteries i.e; 18650 which are 3.7v 2600maH,then I have to use 3 of them connected in Series is that right(about 11.1 v )(since the total consumption will be about 7.2v),but these batteries comes with pcb protection so when I will be using this laser will the pcb should posses any problem.Secondly want to know that if this driver can handle 2600mah.
2>Then in case 14500 which is standard AA(1.5)then have to use 5 of them I guess,plz clarify if I am right or wrong.
3>Can u plz give the names of the chargers which charges these batteries,1 by 1 charging will not be a problem for me.
4>plz suggest the best lion battery manufacturers. I went to this site(http://www.candlepowerforums.com/vb/showthread.php?257543-LiIon-18650-battery-comparison)but cant decide which one to purchase.
Thankx in advance
2. 14500's are 3.7V LiIon's too, so you have to use 2 or 3 of them
3. I'm using this one: http://www.dealextreme.com/p/trustfire-tr-001-multi-purpose-lithium-battery-charger-12594 It's a bit slow but works, this one is quick charger (and can fit some bigger batteries too): http://www.dealextreme.com/p/ultrafire-wf-188-rapid-charger-for-3-2v-3-7v-lithium-batteries-100-240v-44091
4. You don't have to use those $15 AW IMR batteries, in fact those cheap 18650's and 14500's I linked in this step are good enough (I'm using both, drawing 1.5A from 18650 and 0.8A from 2 14500's in series and they preform well)
hope I helped you :)
everybody must start somehow, with something easy to build and understand
